New Reply
used oil reused
Share Thread Thread Tools
Aug21-12, 01:32 AM   #1
used oil reused
l am trying to use used oil to gasoline engine l make geet reactor to vaporized petrol diesel but no success to oil how can l convert used engine oils and food oils to gas or flamable liqiuds thanks jonathan
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> NASA: Austin, calling Austin. 3-D pizzas to go
>> Research suggests modular design competence can benefit new product development
>> Army ground combat systems adopts tool for choosing future warfighting vehicles
Aug21-12, 02:49 AM   #2
l want to generate electricity from waste oil if someone can help
Aug21-12, 07:59 AM   #3
Think external combustion. Burning oil to make steam.
Steam runs your power plant.
The real advantage, is it will burn just about any fuel.
It is why all of our early heat engines were external combustion.
As to the best way to burn oil, look up some of the oil fired boilers.
If you are making steam anyway, you might also look at steam injection cooling.
Aug21-12, 08:32 AM   #4
used oil reused
thanks for reply but l want to change used oils to gas to run a gasoline engine l have 5 petrol engines in garage if you heat oils to flash point can l use that gas for cocker or engine intake thanks
Aug21-12, 08:44 AM   #5
l want to biuld something like wood gasifier but l want to use used oil to run small gasoline engine can someone help me thanks or where l can buy a system to change oils to gas
Aug21-12, 10:10 AM   #6
Recognitions:
Gold Membership Gold Member
Quote by jonathangauci View Post
Engine oil is not "crude" oil, and can't be separated into components e.g. gasoline, diesel, etc. Burning the oil directly will cause a lot of smoke and pollution. It's best to recycle the oil through to allow it to be reprocessed for other lubrication applications.
Aug21-12, 10:16 AM   #7
I can see two problems with what you are trying to do; used engine oil is a complex mixture which will not vaporise at a constant temperature so you'll need a sophisticated process to vaporise all the components, also some of the mixture will probably give off some fairly noxious pollutants. You can burn used cooking oil in a diesel engine, see old episodes of Top Gear or Mythbusters.
Aug21-12, 10:17 AM   #8
thanks my friend did you ever listened the geet reactor of pantone is it a scam because he told me that work with used oil its plans is 300 $
Aug21-12, 10:20 AM   #9
ok l read about used oil in diesil engines but did old engines work thanks
Aug21-12, 10:28 AM   #10
ok thanks every one or can someone help me to make wood or plastic gasifire l want something simple just for experimental thanks
Aug21-12, 11:36 AM   #11
You can boil the oil and the vapors can be made to burn cleanly. But then you end up with a lot of crappy left over that does not boil off.
Many over the road trucks burn oil mixed with diesel fuel and meet all EPA requirements.
Diesel engines sold as "heavy fuel" will even burn roofing tar cleanly.
Aug21-12, 11:44 AM   #12
yes thats good pkruse what tempreture l want to boil the oil ? can u send me some simple picture thanks
Aug21-12, 12:42 PM   #13
I experimented with this more that 4 decades ago. Sorry, I have not kept any data from that. In small gas engines, I found that if I got them good and hot running on gasoline, then I could switch over to oil and they would run just fine, with no black smoke. Heavy fuel diesel engines, like those common on large ships do the same. They start up on #2 diesel, and switch to bunker fuel after everything is hot.
Go ahead and post your pictures. That should be interesting.
Aug21-12, 12:56 PM   #14
ok thanks my friends for help you heat gasoline engine and put oil to gasoline engine or you are saying for vapors and what type off oil thanks
Aug22-12, 02:57 PM   #15
sorry l mean do you heat gasoline engine and put oil in it or you put vapors and do you remember your experiment what type of oil u use food oil or engine oil thanks
New Reply
Thread Tools
