New Reply
Cooling Air Fluids/Thermo Help
Share Thread
Aug23-12, 09:39 AM   #1
I am looking to cool my air supply before applying it to an application in a temperature chamber. The chamber will be at cold the air supply from outside the chamber will be ambient temperature. I want my supply air to be cooled to match the chamber before it enters my application, so pressure is constant. I was thinking simply routing the air through coiled copper would do the trick in the chamber but I was hoping to have some assurance via equations( length and size of tube needed to ensure all heat has been removed) I am thinking this should be simple but I keep finding stuff in books over complicating the process(I think)
Please Help.
PhysOrg.com engineering news on PhysOrg.com
>> Mathematical algorithms cut train delays
>> Researchers design software to detect changes in colour vision
>> Trend study identifies potential for humans and technology to interact in a manufacturing environment
Aug26-12, 11:10 PM   #2
Wherever you want to remove heat you must have some temperature difference. Simply passing the air through a copper coil would not serve your purpose. You have to pass some cold fluid to achieve the cooling process otherwise you can use water and a combination of fan to cool the air by using latent heat of vaporization of water. That's exactly like Chiller system. To find out heat removed in the process you need to know the overall heat transfer coefficient of the copper coil. And temperature difference between the coil and ambient air. Then you can find out exactly the heat removed in the process...
New Reply
Similar discussions for: Cooling Air Fluids/Thermo Help
Thread Forum Replies
Thermo: Newtons law of cooling for radiation Introductory Physics Homework 2
pressure at a centroi thermo fluids Engineering, Comp Sci, & Technology Homework 1
Thermo/Fluids Research Paper Idea Introductory Physics Homework 1
Thermo: how should enthalpy change during cooling/heating? Classical Physics 8
Thermo and Fluids Academic Guidance 2
