| New Reply |
Neutrino arrival time |
Share Thread |
| Aug30-12, 07:58 AM | #1 |
If you produce a lot of neutrinos over a short period of time, and then let them travel a distance long enough that their rest mass makes an appreciable difference in their travel time compared to photons emitted at the same time:
Will they arrive: 1) At 3 separate periods of time because the 3 mass eigenstates each have a different rest mass, speed and arrival time, or 2) At the same time, because each neutrino oscillates through all 3 mass eigenstates, and over several oscillation periods has a single average speed and a single valued average rest mass? |
| Aug30-12, 08:25 AM | #2 |
Mentor
It depends on what exactly you mean by "If you produce a lot of neutrinos over a short period of time".
| Aug30-12, 08:33 AM | #3 |
Mentor
You can always describe the time-evolution in terms of the independent mass eigenstates (neglecting interaction with matter on its path). The production is a superposition of those 3. If you somehow manage to produce a neutrino with a very precise, well-defined energy and production time, I would expect separation of the mass eigenstates with flight distance.
However, I do not see any way to test this - even with low-energetic neutrinos from fusion processes, the gamma factors are somewhere at ~10^9, giving v=(1-10^18)c or 1ns separation after several years (and light-years!) of flight. |
| Aug30-12, 11:13 AM | #4 |
Neutrino arrival timeHundreds of millions to a few milliard lightyears are typical distances to gamma ray flashes. Do gamma ray flashes emit any neutrinos? |
| New Reply |
Similar discussions for: Neutrino arrival time
| Thread | Forum | Replies | ||
| Expected time of arrival with uncertainty | General Physics | 2 | ||
| Finding the time of arrival between two balls in air using kinematics | Introductory Physics Homework | 5 | ||
| Neutrino diffusion time-scale in NS | High Energy, Nuclear, Particle Physics | 0 | ||
| does neutrino oscillation from electron neutrino to muon neutrino conserve energy? | High Energy, Nuclear, Particle Physics | 4 | ||
| time for a photons arrival | Advanced Physics Homework | 1 | ||
