New Reply
[Fortran90] how to write several output into one file
Share Thread Thread Tools
Sep10-12, 01:30 AM   #1
hi all,
Currently I am doing 2d fdtd (TMz mode) modeling. I expect to have output for Ez, Hx and Hy in one file, which is mean that the output will be in 3 column. But I don't have any idea how format it. Anyone can help me? Below is the code
Code:
!problem 3.9, Taflove chapter 3
!to model 2d TMz mode fdtd Simulation using Yee grid.
!time step deltat = (1/sqrt(2)*delta/c) is used
subroutine fd2d
implicit none
double precision                   :: f0               !frequency
double precision                   :: miu
double precision                   :: miur             !permittivity
double precision                   :: miu0
double precision                   :: E0
double precision                   :: delta
double precision                   :: deltat
double precision                   :: deltax
double precision                   :: deltay
double precision                   :: sigma
double precision                   :: sigmastar
double precision                   :: Eps
double precision                   :: Eps0
double precision                   :: Epsr
double precision                   :: lambda
double precision                   :: lambdax
double precision                   :: lambday
double precision                   :: nlambdax
double precision                   :: nlambday
double precision                   :: omega
double precision                   :: S
double precision                   :: k
double precision                   :: c
integer                            :: i,j
integer                            :: m,p
integer                            :: mlast,plast
integer                            :: n
integer                            :: iinit
integer                            :: ilast
integer                            :: jinit
integer                            :: jlast
double precision,dimension(202,202):: Ez
double precision,dimension(202,202):: Hy
double precision,dimension(202,202):: Hx
double precision                   :: EzAmp
double precision                   :: HyAmp
double precision                   :: HxAmp
double precision                   :: Ca
double precision                   :: Cb
double precision                   :: Da
double precision                   :: Db
double precision, parameter        :: pi = 3.14159265
character(len=20)                  :: filename
f0 = 100.0
miu0 = 1.0
miur = 1.0
Eps0 = 1.0
Epsr = 1.0
!delta = 1.e-3
delta = 0.1
!lambda = c/f0
lambda = 1
 c = 1.0
E0 = 1.0
deltat = 1/sqrt(2.0)*(delta/c)
k = 2*pi / lambda
omega = c*k
nlambdax = 5
nlambday = 5
lambdax = lambda
lambday = lambda
deltax = delta
deltay = delta
S = 1.0001
iinit = 1
ilast = 100
jinit = 1
jlast = 100
mlast = 2*ilast-1
plast = 2*jlast-1
print*, 'see me?'
!initialize Ez, Hx,Hy to zero at t=0
do p = 1,2*jlast
 do m = 1,2*ilast
  if (Mod(m,2) == 0) then
   if (Mod(p,2) == 0) then
      Hx(m-1,p+2) = 0
      Hy(m,p+1) = 0
      else
      Ez(m-1,p+1) = 0
   end if
  end if
 end do
end do
print*, 'see me?2'
!medium's properties
 Ca = 1.0
 Cb = deltat/(1-0.5*deltax)
 Print *,'Ca=',Ca,'Cb=',Cb
 Da = 1.0
 Db = deltat/deltax
 Print *, 'Da=',Da, 'Db=',Db
!initiate sinusoidal wavepulse at center
do n = 1,200
  write (filename, "('ez',I3.3,'.dat')") n
  open (unit=130,file=filename)
  Ez(101,101) = sin((n+1)*omega*deltat)
  do m = 2,2*ilast-1
    do p = 2,2*jlast-1
      if (Mod(m,2)/=0) then
	if (Mod(p,2)/=0) then
	  Ez(m,p+2) = Ca*Ez(m,p+2)+Cb*(Hy(m+1,p+2)-Hy(m-1,p+2)+Hx(m,p+1)-Hx(m,p+3))
          write (130,1) Ez(m,p+2)
          !print *, Ez(m,p+2)
        end if
      end if
    end do
  end do
  do m = 2,2*ilast-1
    do p = 2,2*jlast-1
	  Hy(m,p+1) = Da*Hy(m,p+1)+Db*(Ez(m+1,p+1)-Ez(m-1,p+1))
          Hx(m-1,p+2) = Da*Hx(m-1,p+2)+Db*(Ez(m-1,p+1)-Ez(m-1,p+3))
          write (130,1) Hx(m-1,p+2)
          write (130,1) Hy(m,p+1)
        end if
      end if
     end do
  end do
1 format (130(3E15.6))
  close (unit=130)
end do !n
end SUBROUTINE fd2d
Anyway, format I used to write file is not working.
Thank you
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Sep10-12, 06:01 AM   #2
Math 2012
Recognitions:
Each WRITE statement in Fortran starts a new line. To write three values on the same line you would do something like
write (130,1) Ez(m,p+2), Hx(m-1,p+2), Hy(m,p+1)
If might be easier to have a separate DO loop (or nested loops) for the write statement, after you have done all the calculations.
Also, your format statement should probably be just
1 format (3E15.6)
I'm not sure what you thought the "130" was for, but it actually means you could write 130 sets of three values all on one line, if you had one WRITE statement that output all 390 values. From yuor OP, that's not what you wanted to do.
Sep10-12, 08:25 PM   #3
Thank you, alephzero.
I did as what you said and it's work! Btw, 130 is the filename, which I think will not effect the output.
Sep11-12, 05:37 AM   #4
Good.
By the way, Alephzero was talking about the 130 in your format statement:
Code:
  close (unit=130)
that's a multiplier right there to write 130 times, 3 fields of 15.6.
New Reply
Thread Tools
Similar Threads for: [Fortran90] how to write several output into one file
Thread Forum Replies
fortran90: read file with variable name ( character) Engineering, Comp Sci, & Technology Homework 0
Fortran90 reading in a formatted input file Programming & Comp Sci 11
fortran90: read xyz file Programming & Comp Sci 5
Fortran 95: WRITE to screen changes output to WRITE to file Programming & Comp Sci 13
VBA Excel::Write to Output File w/out Overwriting Everytime? Programming & Comp Sci 7
