New Reply
Why is the age of the Universe the reciprocal of the Hubble constant?
Share Thread Thread Tools
Sep10-12, 09:26 AM   #1
According to the wikipedia entry, the latest values for the Lambda-CDM model parameters for the age of the Universe, [itex]t_0[/itex], and the Hubble constant, [itex]H_0[/itex] are
[itex]t_0 = 13.75 \pm 0.11 \times 10^9 \mbox{ years}[/itex]
[itex]H_0 = 70.4 \pm 1.3 \mbox{ km s}^{-1} \mbox{Mpc}^{-1}[/itex]
If you combine the errors this implies the following relationship
[itex]t_0 H_0 = 0.99 \pm 0.02[/itex]
Why is the age of the universe the reciprocal of the Hubble constant to within experimental error?
Is this just a coincidence?
It almost seems that the entire Lambda-CDM model could simply be summarized by
[itex] a(t) = H_0 t [/itex].
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Sep10-12, 09:58 AM   #2
Mentor
Quote by johne1618 View Post
Re: Why is the age of the Universe the reciprocal of the Hubble constant?
Short answer: it's not in general, but in the standard LCDM model, they're pretty close.
Yeah, as far as I know.
Not even remotely. This relationship doesn't hold true in any reasonable Friedmann world model. You need to solve the Friedmann equation to get the dependence of scale factor with time, and it's certainly not linear.
Sep10-12, 11:54 AM   #3
As pointed out above, it is just a good approximation to the age of the universe.
In simple terms this is due to the Hubble parameter not being constant, varying depending on whether the universe expansion accelerates, decelerates or neither one thing nor the other.
Simplifying, this is also the main reason the L-CDM cannot be summarized as you propose, and the scale factor is not a linear function of time, because Ho is not a constant.
Sep11-12, 04:51 AM   #4
Quote by cepheid View Post
The linear relationship
solves the Friedmann equations for [itex]k = 0[/itex] and [itex]\Lambda=0[/itex]
provided one has the equation of state
[itex] p = -\frac{\rho c^2}{3} [/itex]
Thus when applied to the Friedmann equations the linear expansion solution requires the existence of a kind of dark energy with repulsive gravity.
Sep11-12, 04:54 AM   #5
Quote by TrickyDicky View Post
But the linear scale factor equation
does not assume that the Hubble parameter is constant.
In this model the Hubble parameter is given by
[itex] H = \frac{\dot{a}}{a} = \frac{1}{t} [/itex]
which is not constant.
Sep11-12, 05:54 AM   #6
Recognitions:
Gold Membership Gold Member
Actually H0 is constant. It is H, the Hubble parameter that is not constant, H0 is the present value of that parameter.
The coincidence referred to in the OP is the equality within observational error bars of the present value of the inverse of H, 1/H0 or present Hubble Time, TH, and the present age of the universe, t0.
Without DE and with Ω =1 the age of the universe t0 would be the 2/3TH, if Ω < 1 then t0 would lie between 2/3TH and TH, depending on the value of the actual density parameter and the coincidence would not be remarkable.
However if we add DE to the 'cosmic mix' then t0 could be anything from 2/3TH → ∞, depending on the amount of DE you add.
Why is it then that in the observed universe there is just enough DE for t0 = TH in the present epoch?
Some consider this might point to any alternative cosmology which does linearly expand so that t1 = TH1 in every epoch. (Where the subscript 1 refers to the values of H, TH and t at that epoch), so in the last post by johne1618 should read:
The linear relationship is:
[itex] a(t) = Kc t[/itex] where K is some constant that can be normalised by choice of units to 1.
i.e. [itex] a(t) = c t[/itex]
and then
[tex] H_{1} = \frac{\dot{a}}{a} = \frac{1}{t_{1} } [/tex]
Such a cosmology is generally called A coasting cosmology (Astrophysical Journal, Part 1 (ISSN 0004-637X), vol. 344, Sept. 15, 1989, p. 543-550.) and some who have looked at it find that it might be concordant with observation. ( A Concordant “Freely Coasting” Cosmology)
Also you may enjoy The Cosmic Spacetime.
One advantage of such a model (in which the equation of state ω = -1/3) would be that it would not require Inflation to resolve the horizon, flatness, or smoothness problems of the standard model as they would not exist in the first place.
Just a thought...
Garth
Sep11-12, 10:35 AM   #7
Mentor
Hold on a minute. You said, and I quote:
LCDM refers to the standard or "concordance" model of cosmology, which is so-named because its parameter values (Ωm = 0.27, Ωλ = 0.73) are consistent with multiple sets of observations, and it is the one that we think most closely corresponds to reality. Therefore, that is what everyone in this thread has assumed you have been referring to. The statement quoted directly above is patently false for Lambda-CDM, which is why I objected. Now you try to justify it by proposing a totally different cosmological model that has no Lambda, and no matter! How is that even remotely the "Lambda Cold Dark Matter" model?
I will grant you that if P = -ρ/3, then the Friedmann acceleration equation says that ##\ddot{a} = 0##, which implies that ##\dot{a} = \textrm{const.}## But from this, one CAN'T presume that H = const., since ##H = \dot{a} / a##. In any case, what you have done is tried to assume a priori a Friedmann world model in which ##\dot{a}## = const. and therefore a is linear. What we have been trying to tell you in this thread is that this is NOT true in general for any Friedmann world model, and it is not true for the one corresponding to LCDM. Here's a link that shows how the scale factor evolves with time for various models, including LCDM (credit to marcus, another member here, for posting this): http://ned.ipac.caltech.edu/level5/M...s/figure14.jpg
Note: I severely edited my post, because I saw that I made and error and that some of what you were saying in (esp in #5) is right, but again, it bears no relation to LCDM.
Sep11-12, 05:38 PM   #8
Quote by Garth View Post
Thanks for the reference - very interesting!
I'm definitely a fan of Fulvio Melia's R = ct cosmology.
Sep11-12, 06:21 PM   #9
I agree that I shouldn't have asserted that a linear expansion model "summarized" the Lambda CDM model.
Basically I'm saying that if one accepts Fulvio Melia's justification for a linear expansion model then the fact that the age of the Universe is the reciprocal of the Hubble parameter is not surprising.
Sep11-12, 07:00 PM   #10
What do people think of Fulvio Melia's R = ct model described in The Cosmic Spacetime ?
By arguing that the Hubble radius is equivalent to the radius of a gravitational horizon he derives a very simple linear model of the Universal expansion.
He has demonstrated in a number of arXiv papers that such a model could explain many cosmological observations on its own without the need to assume inflation etc.
Sep12-12, 12:31 AM   #11
I don't think people take it very seriously. One thing about some theories is that they fall into the category of "so broken no one bothers arguing against it". I think this falls into that category. The papers are publishable because he manages to come up with some "smoking gun" observational signatures of his models. I'd bet a substantial amount of money that those observations will come up the other way.
Yes. The trouble is that you then have to explain why gravity works in such a way to set up that rate of expansion. If expansion is linear then gravity doesn't exist.
Yes. If you slow the expansion rate of the universe, you no longer have the horizon problem. You've thrown away general relativity in the process.
But for every cosmological thing that he does explain, there are a dozen big ones that he doesn't. The two big ones are big-bang nucleosynthesis and the galaxy power spectrum. Those calculations are not difficult to do, and if you put in a(t) is proportional to t, then everything falls apart. The fact that he hand waves those away leads me to strongly suspect that he's done the calculations himself and he can't make it work. If he runs a(t) proportional to t, and gets the right amount of He4, I'm pretty sure that he would use that as evidence for his model.
But the papers are publishable because he's come up with a "smoking gun" test for his theories, and if God is in a good mood, then when people see that smoking gun, they'll take his ideas seriously and give him a Nobel prize.
Sep12-12, 12:40 AM   #12
Also, this is a good example of how to present an "nutty" idea in a way that people will take you seriously. One thing that you get from "cranks" is that the idea that anything that goes against the prevailing wisdom won't get a fair hearing. In this situation, the idea that R=ct is "nutty" but it's presented in a way that passes peer review.
The reason it's a useful paper is that its more than "I've got this crazy new idea for how to set up the universe" but rather "I've got this crazy new idea for how to set up the universe and here are the consequences of that idea, one of which is a "smoking gun" that shows that I'm right or wrong."
Sep12-12, 02:38 AM   #13
Recognitions:
Sorry if this is getting OT, but it is actually quite common that crackpot papers contains falsifiable predictions (usually by some experiment that is conveniently dated a good interval of time into the future).
The cranks then bang the drum, produce a conspiracy theory about how the establishment is keeping them down and violating their own principles and how their own theories are more 'scientific' than some of the non falsifiable papers that the establishment produces etc
What is typically lost in translation and what many well intentioned laymen don't understand about physics (and especially theoretical physics), is that the falsifiable part really only comes at the end of the journey, not the beginning. Theoretical physicists aren't interested in theory A b/c it makes some random prediction in an experiment: eg "my trinity particle has mass x". People are interested b/c the detailed arguments seem to follow from preexisting mathematic lore in a novel, selfconsistent and interesting way.
Once that interest is established, only then do people look for ways to scythe the theory in such a way as to be able to rule it out. Sometimes this isn't possible even in principle, for instance "the interpretations of quantum mechanics", but that doesn't stop scientists from exploring their consequences.
Sep12-12, 06:55 AM   #14
Recognitions:
Who are you calling a crank?
Fulvio Melia is not a crank, he is Professor of Physics and Astronomy at the University of Arizona, and is a member of the Theoretical Astrophysics Program. He is also the Series Editor for Theoretical Astrophysics with the University of Chicago Press.
He has 186 refereed publications to his name, this year's being:
The Astrophysical Journal (Letters), submitted (2012): "The Inevitability of Omega_m=0.27 in LCDM," F. Melia
The Astrophysical Journal (Letters), submitted (2012): "High-z Quasars in the R_h=ct Universe," F. Melia
Monthly Notices of the Royal Astronomical Society, submitted (2011): "Two-Body Dark Matter Decay and the Cusp Problem," K. McKinnon and F. Melia
Monthly Notices of the Royal Astronomical Society, submitted (2011): "Anisotropic Electron-Positron Annihilation at the Galactic Centre," T. M. McClintock and F. Melia
The Astrophysical Journal (Letters), submitted (2006): "Periodic Modulations in an X-ray Flare from Sagittarius A*," G. Belanger, R. Terrier, O. de Jager, A. Goldwurm, and Fulvio Melia
Monthly Notices of the Royal Astronomical Society, submitted (2012): "Proper Size of the Visible Universe in FRW Metrics with Constant Spacetime Curvature," Fulvio Melia
Monthly Notices of the Royal Astronomical Society, submitted (2012): "CMB Multipole Alignment in the R_h=ct Universe," Fulvio Melia
Monthly Notices of the Royal Astronomical Society, submitted (2012): "Angular Correlation of the CMB in the R_h=ct Universe," Fulvio Melia
Monthly Notices of the Royal Astronomical Society, submitted (2011): "The Rh=ct Universe Without Inflation," Fulvio Melia
Journal of Cosmology and Astroparticle Physics (JCAP), in press (2012): "The Cosmic Horizon for a Universe with Phantom Energy," Fulvio Melia
The Astrophysical Journal (Letters), 757, L16 (2012): "Diffusive Cosmic-ray Acceleration in Sagittarius A*," Marco Fatuzzo and Fulvio Melia
The Astronomical Journal, 144, 110 (2012): "Analysis of the Union2.1 SN Sample with the R_h=ct Universe," Fulvio Melia
Australian Physics, 49, 83 (2012): "The Cosmic Spacetime," Fulvio Melia
Monthly Notices of the Royal Astronomical Society, 422, 1418 (2012): "Cosmological Redshift in FRW Metrics with Constant Spacetime Curvature," Fulvio Melia
The Astrophysical Journal, 750, article id. 21 (2012): "Assessing the Feasibility of Cosmic-Ray Acceleration by Magnetic Turbulence at the Galactic Center," M. Fatuzzo and F. Melia
Monthly Notices of the Royal Astronomical Society, 421, 3356 (2012): "Photon Geodesics in FRW Cosmologies," Ojeh Bikwa, Fulvio Melia, and Andrew Shevchuk
Monthly Notices of the Royal Astronomical Society, 419, 2579 (2012): "The Rh=ct Universe," Fulvio Melia and Andrew Shevchuk
Monthly Notices of the Royal Astronomical Society, 419, 2489 (2012): "Polarimetric Imaging of Sgr A* in its Flaring State," Fulvio Melia, Maurizio Falanga, and Andrea Goldwurm
You might also want to discuss his paper Angular Correlation of the CMB in the Rh = ct Universe published in Monthly Notices of the Royal Astronomical Society, submitted (2011). The linearly expanding model cannot be dismissed as a "nutty idea", if you are going to do that then some people might want to argue that the standard LCDM model is "nutty" as it depends on Inflation, Dark Matter and Dark Energy, all hypothetical concepts that have no laboratory confirmation whatsoever.
Garth
Sep12-12, 07:27 AM   #15
First you need a constant to have a linear equation.
Also see Garth's correction, H is not a constant, Ho is H at the present time, you cannot simply assume that H at the present time has always been and will always be the same. The L-CDM model certainly doesn't assume it and that's one reason it can't be summarized with a linear equation.
Sep12-12, 08:01 AM   #16
I know H is not constant.
In the linear model it is given by
[itex] H(t) = \frac{1}{t} [/itex]
Sep12-12, 08:33 AM   #17
I have a question about Fulvio Melia's derivation of a gravitational radius around any observer in a homogeneous and isotropic Universe in The Cosmic Spacetime.
He says that if you consider a spherical region of mass centered on the observer A then an observer B on the surface of this mass will experience a gravitational acceleration relative to and towards observer A.
But if the Universe is homogeneous and isotropic then the gravitational potential at each point should be the same.
Thus there is no difference between the gravitational potentials at A and B and thus there should not be any relative acceleration between them.
I think Fulvio Melia's argument only works if the Universe is spherically symmetric about observer A. Of course this would go against the Copernican principle as it would put observer A in a priveleged position. The Universe is homogeneous and isotropic rather than being spherically symmetric about a unique point.
(I personally think his R = ct Universe is still valid but that it has to be derived by assuming that the gravitational potential has the value [itex]-c^2[/itex] at every point. Thus every particle's rest mass energy [itex]m c^2[/itex] is balanced by its gravitational potential energy [itex]-m c^2[/itex] giving a zero-energy Universe. The radius of the spherical mass around each point required to produce this potential is what Melia calls the gravitational radius.)
New Reply
Thread Tools
Similar Threads for: Why is the age of the Universe the reciprocal of the Hubble constant?
Thread Forum Replies
Hubble Constant and Age of the Universe Introductory Physics Homework 6
Constant Hubble parameter -> accelerating Universe? Cosmology 4
What is the critical density of the Universe using hubble's constant? Cosmology 1
accelerating universe, decreasing hubble constant Cosmology 8
Determining Hubble Constant and Scale Factor of Universe Cosmology 14
