| New Reply |
Do virtual particle pairs interact gravitationally? |
Share Thread | Thread Tools |
| Sep13-12, 08:40 PM | #1 |
When two virtual particles appear through pair creation, does their brief presence present a gravitational influence on the surrounding universe?
If so, then after they self annihilate, does that gravitational influence remain or disappear? The external gravitational influence of black holes is often attributed to the mass that was present before collapsing to the singularity... does the gravitational influence of virtual particles remain in a similar way after they are "gone"? And if so, how much "extra" gravitational influence in the universe might be attributed to this vs dark matter? It is usually posed that observations imply missing mass for the gravitation observed, but might it just as well be "too much" gravity not associated with existent matter? |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Sep13-12, 10:56 PM | #2 |
Recognitions:
http://www.physicsforums.com/showthread.php?t=442266 |
| Sep13-12, 11:28 PM | #3 |
| Sep14-12, 12:27 AM | #4 |
Yes, vacuum fluctuations... and since this is happening everywhere all the time, if the gravitational influence remains, it seems there would be a kind of accumulation of "extra gravity" not accountable to present mass...?
Am I overestimating the magnitude of this effect? It would seem by HUP to have to be universal in space and time... at the resolution of the Planck length literally "everywhere" and continuously "always" for the last 13B years or so...? Even the lowest possible vacuum energy level must have these fluctuations, yes? |
| Sep14-12, 12:36 AM | #5 |
Recognitions:
One might try to quantize gravity perturbatively; then there would be virtual gravitons producing gravity, and virtual particles could exchange virtual gravitons as well. Unfortunately this approach fails due to non-renormalizibility of perturbative gravity. |
| Sep14-12, 04:52 AM | #6 |
Mentor
This whole thing starts on a faulty premise. There is no "when". You can't say "there used to not be a virtual particle pair here and now there is". That ascribes properties to virtual particles that they do not have: it's like asking what is the color of the invisible man's hair.
| Sep14-12, 06:20 AM | #7 |
o The source of gravity is the stress-energy tensor, and it is locally conserved. You simply cannot create energy and/or destroy it, even in a virtual process, and despite whatever you think you know about the Heisenberg uncertainty principle. There is no cosmic bank account where energy can be borrowed, even short-term. So virtual particle pairs cause no gravitational disturbance.
o The vacuum state is time-independent. Remarks you see in the popular press about virtual particles "popping in and out", or having a "fleeting existence" is an attempt to picture classically what is essentially a quantum feature - the vacuum is a superposition of states with various virtual particles present. But they are always there - they don't pop in and out! o Virtual particles may be off the mass shell. This means that an electron-positron pair may be present without costing the 1.02 MeV that a real pair would have. The energy of a virtual particle may be positive, or zero, or even negative. Since the energy of the vacuum is zero, the virtual particles must add up to zero energy - if one virtual particle has positive energy, some other virtual particle will have negative energy to make up for it. |
| Sep14-12, 09:56 AM | #8 |
I seem to be reading both yes and no answers to these questions:
Is their existence temporary? Simon Bridge - yes Vanadium 50 - no Bill_K - no Wiki - yes Do they have a gravitational influence? Simon Bridge - yes tom.stoer - no Bill_K - no Wiki - looks like yes, but not listed in the field interactions If so, does this influence remain? Simon Bridge - yes Wiki - can't tell Wikipedia's Virtual Particle page's first paragraph states, "In physics, a virtual particle is a particle that exists for a limited time and space. The energy and momentum of a virtual particle are uncertain according to the uncertainty principle. The degree of uncertainty of each is inversely proportional to time duration (for energy) or to position span (for momentum)." In the Manifestations section it states that, "For the gravitational and electromagnetic forces, the zero rest-mass of the associated boson particle permits long-range forces to be mediated by virtual particles." But then lists a dozen "field interactions which may be seen in terms of virtual particles" none of which seem to produce a gravitational influence. |
| Sep14-12, 10:12 AM | #9 |
| Sep14-12, 06:43 PM | #10 |
Recognitions:
I don't think the usual vaccuum fluctuation model has a gravitational component (iirc: we need quantum gravity to pull this off) ... can someone clarify this for me? I would maintain that virtual particles are an artifact of perturbation theory[*] ... steps in a calculation. If the underlying equation being solved includes gravitational effects then the intermediate steps would be expected to reflect this. If not then no. ... either way, however, current ideas do not lead us to expect that we'd find any such cosmological contribution from them. ------------------------- [*] the wikipedia article takes the other POV: that conservation of energy can be violated for sufficiently short times... allowing quite massive particles to shift energy and momentum around short distances. |
| Sep14-12, 07:40 PM | #11 |
Recognitions:
| Sep15-12, 11:32 AM | #12 |
Any particle with a finite lifetime also has a finite width, and consequently ventures off the mass shell. Do you consider just those particles that live long enough to form a visible track real, and the others artifacts? Is a W-boson, with a lifetime of 10-25 sec and a width of 2 GeV merely "an artifact of perturbation theory"? Or a photon emitted from the sun and absorbed 8 minutes later on Earth - slightly off the mass shell. Real or artifact? |
| Sep15-12, 12:44 PM | #13 |
Recognitions:
technically speaking real particles are Hilbert space states whereas virtual particles are propagators
| Sep15-12, 01:43 PM | #14 |
Ok, but even if you don't do perturbation theory, you still have propagators, don't you? The place where perturbation theory comes in is when you expand a full propagator in terms of free propagators. So it's not virtual particles that are the mathematical artifacts, it's the bare virtual particles.
| Sep15-12, 04:46 PM | #15 |
Recognitions:
But a propagator and a Hilbert space state are always different mathematical entities
| Sep15-12, 09:46 PM | #16 |
Recognitions:
I would have taken as a rule of thumb that the real particle is the one that we detect in Nature. The rest are some sort of math.
Has anyone detected the particle-pairs from vacuum fluctuations? It is an artifact of the calculation process when it is something we calculated ... ergo, it has whatever properties that we allow it to have within the model we are using to do the calculation in. We do this in classical physics when we, say, neglect the gravitational force between two charges while still allowing them to have inertia. Ergo: Coulomb charges don't have gravity.... but real-life electrons and protons do. The virtual particles of Field Theory are a bit more complicated than that though aren't they? They occur as intermediate steps in a calculation which start and end with real particles. However, we don't just get to use any old virtual particles in the intermediate steps, and we can produce them in particle accelerators and, again, not just any old mass particles. (How it is that you cannot pair-produce matter with any arbitrary mass is for another thread.) Perhaps it would help to examine what may happen in terms of gravity in something like the beta decay of a neutron in free space? Looking at the intermediate stage you have a large mass gain in the W boson, lasting for a short time ... a student may imagine that this would result in a small gravity pulse. Presumably the real, in-Nature, particle, with mass, has a gravitational effect. The Universe can work this out because the Nature knows more physics than we do right? Maybe Nature has a working version of quantum gravity or maybe it's something else. The question, though, was about the cosmological significance of vacuum fluctuation particles having gravity. |
| Sep16-12, 05:37 AM | #17 |
And any neutral particle whose presence is only known through missing mass. Quarks and gluons too go in the bin, having been deduced indirectly but never detected. None of these are real particles, by your definition, only math.(EDIT: With the exception of ghosts, which I grant are fictitious.) Obviously you can't reach inside a Feynman diagram and detect one of the intermediate particles (whatever "detect" means). But you can do something very similar. You can select a subgraph of the diagram, and by merely adjusting the momenta of its legs, make it "real". |
| New Reply |
| Thread Tools | |
Similar Threads for: Do virtual particle pairs interact gravitationally?
| Thread | Forum | Replies | ||
| Do virtual particles interact? | High Energy, Nuclear, Particle Physics | 4 | ||
| Uncertainty principle, virtual particle pairs and energy | Quantum Physics | 3 | ||
| Hawking Radiation – Empty space virtual antiparticle-particle pairs | Astrophysics | 1 | ||
| Does a Photon interact with a quantum vacuum or creation of virtual particle pair? | Quantum Physics | 0 | ||
| Orientation of virtual particle pairs in local fields? | General Astronomy | 6 | ||
