New Reply
converting joules into a measureable mass (lbs of weight)
Share Thread Thread Tools
Oct17-12, 09:50 AM   #1
It has been a long time since I have emersed myself in physics but I am trying to write a labview program that takes into account distance, speed, mass to calculate the KE of an activity such as running a mile or shorter distances like 40 yards. With the KE I am having trouble figuring out how to convert the joules from calculating KE into mass (lbs of weight) which I will use the mass to develop a structured weight training program to test upon myself. Do you have any suggestions?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> A quantum simulator for magnetic materials
>> Atomic-scale investigations solve key puzzle of LED efficiency
>> Error sought & found: State-of-the-art measurement technique optimised
Oct17-12, 04:20 PM   #2
Recognitions:
Gold Membership Gold Member
I'm not clear just what your objective is.
KE has nothing to do with distance....KE = 1/2mv2......nor does it take into
account acceleration in which I suspect you may be interested.
You know from experience running up hill is very different from running downhill....that's because potential energy as well as KE is involved....is that a consideration for you? Even a sloped treadmill is more difficult to run.
Biological activity, if that is what you seek, is often measured in calories.....related of course to joules since both are measures of energy.
KE is not quite the measure unless you make adjustments you want because sitting still you'll still burn calories. I seem to recall an average adult gives of about 400 BTU per hour...whatever the figure, it's sometimes used to calculated air conditioning requirements in large rooms ..
try here...and see if any of the links are helpful.....
http://en.wikipedia.org/wiki/Calories
New Reply
Thread Tools
Similar Threads for: converting joules into a measureable mass (lbs of weight)
Thread Forum Replies
Converting joules to newtons Classical Physics 5
joules and mass Engineering, Comp Sci, & Technology Homework 5
Lose weight (mass) or train? -- effect of losing weight (mass) on power Introductory Physics Homework 1
joules required to accelerate 1kg of mass Introductory Physics Homework 1
Converting to joules Introductory Physics Homework 1
