| New Reply |
Relativistic escape velocity |
Share Thread |
| Oct20-12, 08:17 PM | #1 |
Why is there an inherent presumption imbedded in the field of physics that gravitational force is exempt from the rules of relativity?
The presumption is based on the non-relativistic expression for escape velocity: v=(2MG/r)^.5 Thus, with a very large mass or a very small radius velocity can exceed the speed of light. This expression is, of course. derived by setting the expression for kinetic energy equal to gravitational potential as follows: (mv^2)/2=mMG/r Our physics textbooks, however, define relativistic potential kinetic energy as: mc^2(γ-1) where γ=(1-v^2/c^2)^-.5 If, however, you set the relativistic version of potential kinetic energy equal to gravitational potential, after a little algebra you find that: v=c(1-((rc^2)/(MG+rc^2))^2)^.5 This expression yields nearly equivalent results to the non-relativistic version for observed planets and stars. For example the non-relativistic expression predicts the escape velocity at the surface of the earth is 1.1178839 X 10^4 m/s whereas the relativistic expression predicts 1.1178840 X 10^4 m/s. For theoretical planets and stars however, the difference between the non-relativistic prediction and the relativistic prediction can be significant. If for example the earth's mass were 5.97 X 10^36 kg versus 5.97 X 10^24 kg the non-relativistic prediction is 1.1178839 X 10^10 m/s (or approximately 37 times the speed of light) whereas the relativistic prediction is 2.9979215 X 10^8 m/s (or just under the speed of light). In fact, no matter how large the mass or how tiny the radius, the relativistic version will never predict a velocity that exceeds the speed of light. The equation for relativistic escape velocity described above seems to be a very reasonable and natural extension of relativity theory. Escape velocity predicts the speed that objects and particles must achieve in order to escape the force of gravity. On the other side, however, it also predicts the speed that an object or particle achieves as it is attracted by gravitational force. Since the relativistic form of the equation predicts that gravity cannot accelerate an object or particle to a speed equal to or greater than the speed of light, it also casts a shadow on theories which depend on speeds reaching the speed of light such as black hole theory. I would be interested in input from anybody on the above analysis. |
| Oct20-12, 08:40 PM | #2 |
Whenever you get a significant difference with Newtonian gravity, you should use general relativity. In particular this predicts that a mass of 6.97*10^36 of the size of the earth will be a black hole, and you can't escape from it at all from closer than 8.87 * 10^6 km.
Why do you think black hole theory predicts a speed greater than light? |
| Oct20-12, 09:26 PM | #3 |
I assume that your calculation of the point of no escape at 8.87 X 10^6 km is based upon the fact that the non-relativistic calculation of escape velocity predicts that an object or particle will achieve the speed of light at such distance. The relativistic calculation, using the formula I described, however predicts that an object or particle will achieve a velocity of about .75 the speed of light at such distance and will never get to the speed of light. Perhaps my statement that black hole theory predicts a speed greater than the speed of light was not well worded, however, it seems to me the conclusion is the same.
| Oct20-12, 11:35 PM | #4 |
| Oct21-12, 12:49 AM | #5 |
Thanks for the correction re kinetic energy.
For gravitational potential I am using: (mMG)/r |
| Oct21-12, 01:05 AM | #6 |
| Oct21-12, 01:09 AM | #7 |
| Oct21-12, 01:11 AM | #8 |
I forgot to respond to this:
| Oct21-12, 02:28 AM | #9 |
Perhaps my opening sentence was overstated.
The point remains, however, that the field of physics has embraced a non-relativistic expression for escape velocity which, in my humble opinion, has led to incorrect speculations such as the existance of black holes. |
| Oct21-12, 04:27 AM | #10 |
Recognitions:
You might find such arguments in a few not-so-good popularization - I doubt you'll find them in a serious GR textbook. For instance, here's what Caroll has to say in his lecture notes on GR. |
| Oct21-12, 07:49 AM | #11 |
Mentor
| Oct21-12, 12:45 PM | #12 |
| Oct21-12, 05:22 PM | #13 |
Let me throw caution to the wind here, and quote the actual general relativistic answer!
![]() If you start off a test particle at rest at infinity and let it fall inward, it will follow a radial geodesic. Its velocity at any point turns out to be (remarkably!) the same expression as for the Newtonian case: dr/dτ = √(2GM/r), where M is the central mass and r is the Schwarschild radial coordinate. This can also be written dr/dτ = c √(2GM/c2r) = c √(rS/r) where rS is the Schwarzschild radius. Thus as you approach the surface of the black hole, the escape velocity approaches c. What distinguishes the general relativistic result from the Newtonian one is that the time derivative is with respect to τ, the particle's proper time. One might want to also look at the coordinate escape velocity dr/dt. The relationship between the two is dτ/dt = 1 - 2GM/r. This says that "time slows down" as you approach the hole. That is, the particle's proper time runs at a slower rate than coordinate time (= time measured at infinity). Combining, we get dr/dt = (1 - 2GM/r)√(2GM/c2r), which goes to zero at the Schwarzschild surface, where "time is frozen", and the particle appears to an outside observer to no longer move. |
| Oct21-12, 06:06 PM | #14 |
| Oct21-12, 06:16 PM | #15 |
Recognitions:
I'll start off with saying I agree with everythign Bill K has said so far, it's just that there's even more to the story... If one considers a fall from a height other than infinity, the equations of motion become (dr/dtau)^2 = (E^2 - 1) + 2M/r So depending on E (which is a constant of motion and equal to 1 iif the object is falling from at rest from infinity, and can be thought of as a normalized energy parameter ) dr/dtau can be almost anything. Furthermore, intervals of dr don't have unit length, because of the metric, ds^2 = dr^2 / (1-2M/r). To get around these issues, one might ask a different question - what is the velocity of the infalling observer relative to a co-located "static observer" who is accelerating to maintain a constant radial coordinate (and a constant distance from the event horizon)? To perform this measurement, the static observer and the falling observer both use their own local clocks and rulers - and they both get the same answer. After a rather lengthly calculation (http://www.physicsforums.com/showthr...558#post602558 posts 29 and 30) one comes up with said relative velocity being [tex]\frac{1}{E} {\sqrt{E^2 - (1 - \frac{2M}{r})}}[/tex] This sort of velocity (which I regard as the most physical of the various sorts computed) approaches uity (i.e. the speed of light) as the object approaches the event horizon - regardless of the value of E. Static observers don't exist at the event horizon. One can measure relative velocity of the event horizon and an infalling observer , and find it will be equal to 'c', but some caution in interpreting this is needed. The infalling object is not actually reaching the speed of light. What' s happening is that the event horizon is essentially moving outward at the speed of light. Technically, the event horizon can be called a "trapped null surface". You can think of the event horizon as being marked by a trapped beam of light, forever travelling outwards, but never changing it's r coordinate. Because it's like a beam of light, it doesn't have a "frame of reference" of its own. Any newer readers who are still with us at this point might want to consut the FAQ on this point if it isn't obvious. The free-falling particle does, however, have a frame of reference, and in this frame of reference the "trapped light" moves at the speed of light relative to the particle. Which is only to be expected, as c is always a constant when using local clocks and local rulers. |
| Oct21-12, 06:21 PM | #16 |
| Oct21-12, 06:30 PM | #17 |
Recognitions:
| New Reply |
Similar discussions for: Relativistic escape velocity
| Thread | Forum | Replies | ||
| Escape velocity | General Physics | 5 | ||
| Escape velocity/orbit velocity | Introductory Physics Homework | 1 | ||
| relativistic escape velocity | Special & General Relativity | 10 | ||
| escape velocity | General Physics | 49 | ||
| escape velocity | General Astronomy | 2 | ||
