Do the premises of a theory have to be empirical?
  • Context: Graduate
  • Thread starter Thread starter Cinitiator
    Theory
The discussion centers on whether the premises and elements of a theory must be empirical, exploring the relationship between theoretical constructs and empirical data. Participants examine examples from cognitive psychology and physics, considering the implications of non-empirical premises in the formulation of theories.
  • Some participants argue that premises do not have to be empirical as long as the theory is consistent with observed data, citing cognitive psychology as an example where non-empirical concepts are used.
  • Others question how premises can be considered empirical, suggesting that they can be inspired by experiments but not directly observed, using the constancy of the speed of light as an example.
  • One participant emphasizes that while premises do not have to be empirical, it is generally more sensible for them to be based on reality, as theories must ultimately be tested against empirical evidence.
  • Another participant notes that a theory can explain data without being grounded in reality, highlighting cognitive and evolutionary psychology as examples of this phenomenon.
  • Some participants propose that a good physical theory is one that makes testable predictions, regardless of how its premises were conceived, but also mention that simpler theories can render more complex ones obsolete if they make the same predictions.
  • There is a discussion about the relationship between complexity and explanatory power, with references to general relativity and Newton's gravity as an illustration of how more complex theories can supersede simpler ones.
Participants express differing views on the necessity of empirical premises in theories, with no consensus reached on whether they must be empirical or not. Multiple competing perspectives remain regarding the role of empirical data in the formulation of theoretical premises.
Some participants highlight the importance of testing theories against reality, while others suggest that non-empirical premises can still yield valid theories. The discussion reflects a range of assumptions about the nature of scientific theories and the role of empirical evidence.
Cinitiator
Since there's no board dedicated to the methodology of science, I thought that this board would be the best fit. Here's my question:
Do the premises and elements of a theory have to be empirical? Or do they not have to be, as long as the theory is consistent with the observed data? By consistent I mean that the conclusion seems to be true, but the premises aren't empirical.
I'm asking because from what I've seen, cognitive psychology relies on mental "modules" to explain empirical data. These modules can't actually be observed empirically, but the results put forward by the theories which rely on these non-empirical concepts seem to be more or less consistent with the evidence up to date.
How can premises be empirical? They can be inspired by experiments, of course.
One example:
"The speed of light is constant for all observers". How can you ever observe this? You cannot measure the speed of light in any possible reference frame. You can measure it in many, and assume that it is true for all (and check it with more measurements).
No, they don't HAVE to be empirical, but it wouldn't make a lot of sense for them NOT to be since the FIRST thing you have to do with a theory is test it against reality.
I mean, the first step in a theory is a guess and you could just make some wild guess, but it's not likely to reflect reality if it isn't in some way based on reality and as soon as you take the next step and COMPARE it to reality, most times, you won't have a theory any more, you're just back to having a guess that's wrong.
EDIT: look up the on-line video of Feynman talking about the scientific method.
Thanks for the video suggestion, I will watch it.
A theory can explain the data and yet not be based in the real world, though. It can be logically equivalent for a given moment with our data. Cognitive and evolutionary psychology is a good example of this.
No. You can postulate whatever you want. If it makes predictions which are testable and agree with experiment it is a good physical theory, no matter how you came up with that stuff.
However:
1) Only the postulates that affect the quantitative predictions are physics.
2) A simpler theory, with less postulates, making the same predictions, makes a complicated one obsolete.
And likewise a more complicated one that explains more of the real world can make a less complicted one obsolete. E.G. GR vs Newton's gravity (may not the BEST example, since Newton isn't exactly obsolete, just known to be very limited).
  • · Replies 47 ·
10K
  • · Replies 105 ·
17K
  • · Replies 23 ·
  • · Replies 58 ·
  • · Replies 0 ·
