New Reply
What is the coalescence factor?
Share Thread Thread Tools
Nov8-12, 08:21 AM   #1
I am reading an article on experimental nuclear physics. The article is about deuteron and triton production in Pb + Pb collisions. In the article they mention the coalescence factor which is given by:
[itex]B_{A}=A\frac{2s_{A}+1}{2^{A}}R^{N}_{np}\left(\frac{h^{3}}{m_{p}\gamma V}\right)^{A-1}[/itex]
The coalescence factor has something to do with the formation of light clusters A(Z,N). So A is the mass number of the cluster, the R_np thing is the ratio of neutrons to protons participating in the collision, gamma is just the lorentz factor related to the velocity of the cluster and V is the volume of of particles at freeze-out (after hadronization, when there are no more strong interactions between the nucleons). I don't know what s_A is though. I have worked out the units for A = 2 to be:
[itex]s_{A}\cdot \frac{ev^{2}s}{m}+\frac{ev^{2}s}{m}[/itex]
But i don't know the units of s_A. I was hoping for this to turn out unit-less, since it could then be interpreted as a sort of probability of a cluster A(Z,N) to form. Now i'm not sure what it is.
I apologize if this post was supposed to go in homework. Technically it is a sort of homework question, since i am supposed to present the article as an exam tomorrow. But i figured that there was a bigger chance that someone could help me with this on the HEP board.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Nov8-12, 08:34 AM   #2
Mentor
It has to be unitless, since you add 1 to it.
Nov8-12, 09:35 AM   #3
Of course, i didn't even consider that. Okay, so i guess the coalescence factor has dimensions of:
[itex]\frac{ev^{2}s}{m}[/itex]
I'm still not sure exactly sure about what the coalescence factor is though.
Nov8-12, 11:19 AM   #4
mfb
Newcomer 2012
Mentor
Where does your formula come from? I found a similar one in Coalescence and flow in ultra-relativistic heavy ion collisions (pdf, equation 6.2), but that uses (2pi)^3 in the nominator of the brackets.
I don't see how masses cancel in the equation.
A cross-section (1/m^2) or a dimensionless fraction would be a nice result, and I think c=1 is implied.
Nov8-12, 01:57 PM   #5
I probably did something wrong when i tried to find the dimensions and yes i think you are right that c = 1 is implied. I got the equation from an old article called "Deuteron and triton production with high energy sulphur and lead beams". It's from 2001, so you might not be able to find it on the internet anymore.
Yes a cross-section or a fraction would be very nice, however, i found a plot later in the article where B_2 has dimensions:
[itex]Gev^{2}c^{-3}[/itex]
Which is mass times momentum. Weird.
New Reply
Thread Tools
Similar Threads for: What is the coalescence factor?
Thread Forum Replies
Factor a in Van der Waals equation of state off by a factor of 0.1? Classical Physics 0
Utility of Form factor and Crest factor in an AC waverform Classical Physics 2
Electrostatic Coalescence... General Engineering 0
Electrostatic Coalescence? Introductory Physics Homework 0
