Two Empty Sets
by Xidike
Tags: sets
Xidike
Xidike is offline
#1
Nov6-12, 12:07 AM
P: 72
I want to ask that, are you empty sets equal ????
Phys.Org News Partner Science news on Phys.org
Better thermal-imaging lens from waste sulfur
Hackathon team's GoogolPlex gives Siri extra powers
Bright points in Sun's atmosphere mark patterns deep in its interior
haruspex
haruspex is offline
#2
Nov6-12, 12:14 AM
Homework
Sci Advisor
HW Helper
Thanks ∞
P: 9,154
Quote Quote by Xidike View Post
I reply, therefore I am not an empty set.
Yes, two empty sets are equal, even if you regard them as subsets of entirely different beasts. So any two power sets have a nonempty intersection.
Xidike
Xidike is offline
#3
Nov6-12, 09:09 AM
P: 72
How can two Empty Sets be equal ???
take a look at this example..
1st set: Number of trees in the forest
2nd Set: Number of Student of in the class
suppose that these are empty sets.. how are they equal ??? they both have different description..
haruspex
haruspex is offline
#4
Nov6-12, 03:33 PM
Homework
Sci Advisor
HW Helper
Thanks ∞
P: 9,154
Two Empty Sets
You've defined two numbers, not two sets, but passing over that...
"A whole number between 1 and 3." "Positive square root of 4." Two descriptions, equal answers.
Erland
Erland is offline
#5
Nov6-12, 04:34 PM
P: 302
Two sets are equal if every member of the first set is also a member of the second set, and vice versa. If two empty set were not equal, there would be one element in one of the sets which is not a member of the other set, and this is impossible, since an empty set has no member at all, whether member or not member of another empty set.
Bacle2
Bacle2 is offline
#6
Nov6-12, 06:01 PM
Sci Advisor
P: 1,168
If two empty sets were different, one of them would contain an element
not contained in the other....
HallsofIvy
HallsofIvy is offline
#7
Nov7-12, 07:12 AM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 38,879
Just to put my oar in: two sets, A and B, are equal if and only both statements
"if x is in A then x is in B" and "if x is in B then x is in A" are true.
If A is the empty set, then "if x is in A" is false so the statement "if x is in A then x is in B" is trivially true. If B is the empty set then "if x is in A" is false so the statement "if x is in B then x is in A" is trivially true. Therefore, if A and B are both empty, then they are equal.
stauros
stauros is offline
#8
Nov7-12, 07:43 PM
P: 35
The empty set is unique and the following proof ascertains that.
Suppose that there is another empty set denoted by ##\emptyset'## ,then we have:
1)##\forall A[A\cup\emptyset =A]##
2)##\forall A[A\cup\emptyset' =A]##
In (1) we put ##A =\emptyset'## and we get: ##\emptyset'\cup\emptyset =\emptyset'##
In (2) we put ## A =\emptyset## and we get :##\emptyset\cup\emptyset' =\emptyset##
But since ,##\emptyset'\cup\emptyset = \emptyset\cup\emptyset' ##
We can conclude :##\emptyset'=\emptyset ##
Hence all the empty sets are equal
stauros
stauros is offline
#9
Nov7-12, 08:45 PM
P: 35
Here is another proof that the empty set is unique:
Suppose again that there is another empty set denoted by,##\emptyset'##
Then we have:
1) ##\forall A[\emptyset\subseteq A]##
2)##\forall A[\emptyset'\subseteq A]##
In (1) put : ##A=\emptyset'## and we get : ##\emptyset\subseteq \emptyset']##..................................................................... 3
In (2) put : ##A=\emptyset## and we get : ##\emptyset'\subseteq \emptyset]##..................................................................... 4
And from (3) and ( 4) we conclude :,##\emptyset' = \emptyset##
Bacle2
Bacle2 is offline
#10
Nov7-12, 09:23 PM
Sci Advisor
P: 1,168
Quote Quote by stauros View Post
I don't get it: you showed ##A\cup\ B=B\cup\ A## for A,B being (supposedly)
different copies of the empty set. But
this is true for any two sets, since union is commutative; I don't see how
this shows that A=B.
stauros
stauros is offline
#11
Nov8-12, 03:54 AM
P: 35
Quote Quote by Bacle2 View Post
WE have :
##A\cup B= B\cup A## for all A,B
Then put :##A=\emptyset ## and ## B=\emptyset'## and we have:
##\emptyset\cup\emptyset' = \emptyset'\cup\emptyset ##
But ,##\emptyset\cup\emptyset'=\emptyset ## and ##\emptyset'\cup\emptyset =\emptyset'## as i have shown in my previous proof
Hence ##\emptyset'= \emptyset ##
Preno
Preno is offline
#12
Nov8-12, 07:30 AM
P: 159
Those proofs strike me as a bit convoluted. The fact that all empty sets are equal is a consequence of the axiom of extensionality, which is literally the most fundamental property of sets, which says that sets are equal if and only if they have the same members. If the set A has no members and the set B has no members, then by extensionality A = B.
stauros
stauros is offline
#13
Nov8-12, 11:08 AM
P: 35
Quote Quote by Erland View Post
This is wrong as the followinf argument shows:
WE know that:
##A=B\Longleftrightarrow [(A\subseteq B)\wedge(B\subseteq A)##.
Hence:
##A\neq B\Longleftrightarrow[\neg(A\subseteq B)\vee \neg(B\subseteq A)]##.
OR
##A\neq B\Longleftrightarrow[\exists x(x\in A\wedge \neg x\in B)]\vee[\exists x(x\in B\wedge \neg x\in A)]##
Now if we put : ##A =\emptyset## and ##B=\emptyset'## ,we get that:
##\emptyset\neq \emptyset'\Longleftrightarrow[\exists x(x\in \emptyset\wedge \neg x\in \emptyset')]\vee[\exists x(x\in \emptyset'\wedge \neg x\in \emptyset )]##
And if we assume :##\emptyset\neq \emptyset'##, then
##[\exists x(x\in \emptyset\wedge \neg x\in \emptyset')]\vee[\exists x(x\in \emptyset'\wedge \neg x\in \emptyset )]##.That implies :
##[ (x\in \emptyset\wedge \neg x\in \emptyset')]\vee[(x\in \emptyset'\wedge \neg x\in \emptyset )]##.Which in turn implies:
##[ (x\in \emptyset\vee x\in \emptyset')]##
MLP
MLP is offline
#14
Nov8-12, 04:12 PM
P: 31
This argument is fallacious. You cannot infer that one and the same x is referred to by the two existential quantifers. If you could, it would be easy to prove that something is a Dodge and something is a Toyota implies that some one thing is both a Dodge and a Toyota. Maybe it would help to see this if you make the variable used in the second existential claim 'y'.
stauros
stauros is offline
#15
Nov9-12, 08:11 AM
P: 35
Quote Quote by MLP View Post
Let : A= {1,2}, and B={1,2,3}.
Can you prove that :## A\neq B## , using the axiom of extensionality??.
Then you will find out that using the same or different quantifiers makes no difference
MLP
MLP is offline
#16
Nov9-12, 10:01 AM
P: 31
I am not saying that the use of the different quantifiers makes a difference, it does not. I am saying that Existential Elimination does not allow you to assume that the x referred to in the first existential claim is one and the same x as the x referred to in the second existential claim.
It is not legitimate to instanciate the first quantifier to x and then instanciate the second one to x and act like they are one and the same thing.
Erland
Erland is offline
#17
Nov9-12, 03:12 PM
P: 302
Your argument shows that I was right, but perhaps that is what you meant?
To be clear, you should have written the two last lines as
##\exists x[ (x\in \emptyset\wedge \neg x\in \emptyset')]\vee[(x\in \emptyset'\wedge \neg x\in \emptyset )]##
and
##\exists x[ (x\in \emptyset\vee x\in \emptyset')]##.
Then, the argument is correct, since
##\exists x(P(x)\vee Q(x))## and ##\exists x \,P(x)\vee\exists x\,Q(x)## are logically equivalent.
stauros
stauros is offline
#18
Nov9-12, 10:12 PM
P: 35
and
Can you support that ,by writing a complete formal proof??
Because i know that it will be useless to ask you ,where did you get the:
"and ##\exists x[ (x\in \emptyset\vee x\in \emptyset')]##" ,part, e.t.c ,e.t.c
Register to reply
Related Discussions
Union and Intersection of empty class of sets.. Set Theory, Logic, Probability, Statistics 1
An empty collection of sets Set Theory, Logic, Probability, Statistics 4
Union of non empty sets Calculus 7
empty family of sets General Math 4
Dense sets and the empty set Set Theory, Logic, Probability, Statistics 32
