New Reply
quartz crystal oscillator
Share Thread Thread Tools
Nov9-12, 05:39 PM   #1
Quartz crystals are used in clocks to regulate time measurement.
Does a quartz crystal convert heat energy to AC electrical energy?
Duordi
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Nov9-12, 07:24 PM   #2
Recognitions:
Gold Membership Gold Member
Quote by duordi134 View Post
Duordi
Duordi, Welcome to Physics Forums!
Quartz crystals do not convert heat energy to AC electrical energy. They are piezoelectric, which means they convert mechanical energy (say vibration) into electrical energy. Interestingly, they work in the reverse, also. When an electrical signal, say a voltage, is applied, the crystal deforms mechanically.
You can learn all about them if you want to. May I suggest you begin with these two sites?
http://www.electronics-tutorials.ws/...r/crystal.html
http://en.wikipedia.org/wiki/Crystal_oscillator
Cheers,
Bobbywhy
Nov15-12, 06:10 PM   #3
So if a crystal was immersed in a gas which would strike the crystal every so often
causing it to remain vibrating then the crystal would constantly provide an electric current.
This may not be a useful condition because of its minute capacity but it would be a direct conversion of heat energy (motion of the gas molecules) to electrical energy.
durodi
Nov15-12, 06:39 PM   #4
Recognitions:
durodi, Interesting hypothesis, but I don’t think it works the way you propose. Did you visit the two sites I recommended? There the physical deformation of a crystal and the resultant charge generation is clearly described.
A quartz (piezoelectric) crystal must be deformed along a particular axis in a well-defined direction in order to produce a voltage.
A quartz crystal immersed in a hot gas will be bombarded by rapidly moving molecules. But they will impact on the crystal from all directions, and therefore exerting a force on the crystal in all directions. The result will not be any vibration, deformation, or voltage generated. So there would be no conversion of heat energy to electrical energy.
Nice try, durodi. I encourage you to continue your searching. This is how new discoveries are made.
Cheers,
Bobbywhy
New Reply
Thread Tools
Similar Threads for: quartz crystal oscillator
Thread Forum Replies
is there an ideal n/s polarity point on a quartz crystal Introductory Physics Homework 0
Quartz crystal microbalance General Physics 15
What is the breaking point of quartz crystal General Physics 1
Crystal Oscillator General Engineering 2
Quartz crystal oscillator problem Advanced Physics Homework 1
