New Reply
Example for divergent probability distribution ?
Share Thread Thread Tools
Nov13-12, 05:38 AM   #1
Sometimes it is said that the probability distribution which does not add up to 1 still can be used to find relative probabilities.
For example, consider probability distribution [itex]p_n = 1/n[/itex] for all natural numbers. Does it make sense to say [itex]n = 1[/itex] is twice as probable as [itex]n=2[/itex], even if total probability does not add up to 1? Or does probabilistic description necessarily require that total probability is 1?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Nov13-12, 10:23 AM   #2
mfb
Mentor
If the sum of all values is finite (!), you can normalize the values to get a meaningful probability distribution. ##p_n=\frac{1}{n^2}## would allow that, for example, with normalization factor ##\frac{6}{\pi^2}##.
If you do not care about absolute probabilities, you can ignore that prefactor and work with relative probabilities.
Nov13-12, 11:41 AM   #3
Thank you. I was thinking mainly of the case when the distribution cannot be normalized. Can I work with relative probabilities given by [itex]p_n = 1/n[/itex]?
In quantum theory, it was suggested that divergent probability distribution still gives relative probabilities correctly. But I am unsure about this concept of "relative probability". Does it make sense for divergent distribution?
Nov13-12, 12:19 PM   #4
mfb
Mentor
I don't think this works for countable sets. There is no probability distribution with those ratios.
It can work for uncountable sets as a probability density function, if the integral is bounded.
Nov13-12, 01:42 PM   #5
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Quote by Jano L. View Post
I'm sure it makes sense if you define things properly. Defining a probability [itex]\mu[/itex] on [itex]\mathbb{N}[/itex] with [itex]\mu\{n\}=1/n[/itex] will not give you a probability distribution and cannot be renormalized to give you one. However, if you want to interpret it as a probability distribution and if you want to say that 1 is twice as probably as 2, then you can do that. You can interpret most definitions and theorems for this "infinite" distribution (however not all theorems are going to hold). So there is nothing wrong with interpreting [itex]\mu[/itex] as an probability distribution (however,strictly speaking it is not one). How useful this interpretation is depends on the context. It might make things a lot clearer, or it might not.
New Reply
Thread Tools
Similar Threads for: Example for divergent probability distribution ?
Thread Forum Replies
Probability question ,Random variables and probability distribution Calculus & Beyond Homework 2
Probability question; Conditional probability and poisson distribution Precalculus Mathematics Homework 1
Probability: joint probability distribution problem? Calculus & Beyond Homework 8
distribution of a random variable , pdf vs probability distribution Set Theory, Logic, Probability, Statistics 1
Derivation of the probability distribution function of a binomial distribution General Math 2
