What kind of engineering involves the most physics?
In summary, the conversation discusses the different engineering fields that involve modern physics and the varying levels of focus on physics within each field. It is suggested that if one is interested in applying modern physics to design, then materials science, electrical engineering, or applied/engineering physics would be suitable options. However, if one is interested in cutting-edge research in modern physics, it is best to pursue a degree in physics. It is also recommended to take extra courses in physics if pursuing an engineering degree and interested in these areas. The strengths and differences of various engineering courses are also mentioned.
qpzm77gg
What kind of engineering involves the most physics? It focus on modern physics is the best.
It's not easy to answer this question with regard to broad fields. It generally depends on the specific situation. For instance, an Electrical Engineer could be working on an embedded systems problem that poses more programming/computation challenges than "modern physics" ones. On the other hand, they could be working on how to reduce chip size without allowing quantum tunneling to affect reliability.
Are you looking for an engineering field to study? More specifics about what you're curious about would be helpful in answering your question.
No easy answer. It depends on the job I'm sure. If you like physics go into physics.
If you are interested in doing physics, then as sandplasma says, go into physics.
If you are interested in applying modern physics to design new materials, devices, etc., then the primary options I can think of are:
materials science - much of materials science is effectively applied solid state physics. Some modern materials science academic research involves designing materials starting with quantum mechanics.
electrical engineering - semiconductor physics, materials design, device design. Lasers and quantum optics are sometimes in EE departments.
applied / engineering physics - can do similar work as all of the above, depending upon department.
Of course, here I am assuming by "modern physics" you mean that in the traditional sense where quantum mechanics is important. Cutting edge research in "modern physics" will only be found in physics departments.
If you decide to do engineering and are really interested in these areas, I recommend taking extra courses from the physics department (unless your engineering department is unusually strong with quantum mechanics courses).
best of luck,
jason
It depends on exactly what areas of physics/mechanics you are interested in. For instance if you're interested in condensed matter or optics, a Physics Degree will probably suit you most. In terms of Engineering though, the foundations for Mech or Aero Engineering Degrees are generally structural mechanics, aerodynamics, control theory, propulsion and design. They vary between institution as the strength of the course structure relies on the academic staff in the university faculty. I hope this has helped in answering your question.
The Jericho.
1. What is the most physics-heavy engineering discipline?
The most physics-heavy engineering discipline is typically considered to be mechanical engineering. This field involves the study and application of physical principles to design, analyze, and manufacture mechanical systems. Subjects such as mechanics, thermodynamics, and materials science are heavily utilized in mechanical engineering.
2. Is there a difference between the physics used in different engineering fields?
While the fundamental principles of physics are the same across all engineering disciplines, the specific applications and focus may vary. For example, electrical engineering may use more principles from electromagnetism, while civil engineering may focus more on mechanics and materials. However, all engineering fields require a solid understanding of physics.
3. Can you specialize in physics within an engineering discipline?
Yes, many engineering programs offer concentrations or specializations within a specific discipline that focus on physics-related topics. For example, a mechanical engineering student may choose to specialize in aerospace engineering, which involves a significant amount of physics principles.
4. Are there any engineering fields that do not involve physics?
No, all engineering fields involve some level of physics. Even fields such as computer engineering or software engineering require an understanding of physics concepts such as electricity and magnetism.
5. How important is a strong background in physics for engineering?
A strong understanding of physics is crucial for success in engineering. Many engineering problems and designs require an understanding of how physical forces and principles will affect a system. A solid foundation in physics is necessary to make accurate calculations and design decisions in any engineering field.
  • General Engineering
  • STEM Academic Advising
