| New Reply |
Work done by a spring & its potential energy |
Share Thread |
| Nov14-12, 07:50 AM | #1 |
According to work - mechanical energy theorem ,
W = K(final) - K(initial) + U(final) - U(initial) . . . . (1) as we define Potential energy as negative of work done by conservative force and assuming that the only force in this situation is Spring force then , W(spring) = K(final) - K(initial) As work done is calculated by finding component of spring force in direction of displacement. How can we say that U(final) - U(initial) applies for all possible conditions of extension of spring as displacement may not be in direction of force ? Spring force = 0.5kx2 |
| Nov14-12, 09:17 AM | #2 |
Recognitions:
First of all, your equation (1) defines the external work done by/on a system. If no energy is added or lost (Wext = 0), Kf + Uf = Ki + Ui. Second, your question is not clear. What do you mean when you say U(final) - U(initial) applies? U(final) - U(initial) is not a mathematical statement. Finally, your statement: Spring force = 0.5kx2 is not correct. F = -kx. AM |
| Nov14-12, 03:23 PM | #3 |
[tex]W = \frac{1}{2}k{e^2}[/tex] W = work, e = extension, k = spring constant Refers to the work done in extending a spring = potential energy stored in that spring on extension. |
| New Reply |
| Tags |
| mechanical energy, spring force, work energy |
Similar discussions for: Work done by a spring & its potential energy
| Thread | Forum | Replies | ||
| Spring Potential/Work Energy Questions | Introductory Physics Homework | 0 | ||
| potential energy and work by spring. | Introductory Physics Homework | 8 | ||
| Work-Energy Theorum: Spring potential energy vs Kinetic Energy | Introductory Physics Homework | 4 | ||
| Work/Potential Energy of a Spring | Advanced Physics Homework | 1 | ||
| Work and Potential/Kinetic Energy (spring problem) | Introductory Physics Homework | 2 | ||
