Using Forms to Define Orientation of Curves.
by WWGD
Tags: curves, define, forms, orientation
WWGD
WWGD is offline
#1
Nov13-12, 11:18 PM
P: 391
Hi, All:
There is a standard method to construct a nowhere-zero form to show embedded
(in R^n ) manifolds are orientable ( well, actually, we know they're orientable and
we then construct the form).
Say M is embedded in R^n, with codimension -1. Then we can construct a nowhere-
zero top form by selecting the vector N(x) normal to the manifold ( say, using the Riemann metric inherited from R^n), and choosing an orthonormal frame {v1,v2,..,v(n-1)} for M . Then the form:
w:=Det | N(x) v1 v2....vn-1 | ,
where we write the vectors as columns, is nowhere-zero, since any two vectors are
perpendicular, and so the collection is linearly-independent.
**Now** how do we construct a form when:
i) M is embedded in R^n, and the codimension is larger than 1.
ii) For a curve, say a smooth curve.
iii) Can this be done/does it make sense when M is not embedded?
Thanks.
Phys.Org News Partner Science news on Phys.org
Going nuts? Turkey looks to pistachios to heat new eco-city
Space-tested fluid flow concept advances infectious disease diagnoses
SpaceX launches supplies to space station (Update)
quasar987
quasar987 is offline
#2
Nov14-12, 07:43 AM
Sci Advisor
HW Helper
PF Gold
quasar987's Avatar
P: 4,768
Well, for any immersed or embedded curve c(t), just take the vector field c'(t) (immersed precisely means c'(t) never vanishes). Then take it's dual (co)vector field and this is your nowhere vanishing globally defined top form.
Vargo
Vargo is offline
#3
Nov14-12, 08:41 AM
P: 350
I am confused about your construction for codimension 1. What about a Mobius strip? You are assuming orientability, and you want to show that implies the existence of a volume form? Also your construction with the determinant doesn't quite make sense to me, though I think I get what you mean. But actually I am still confused because if you assume that the manifold is orientable, then there is no need to use an embedding into Rn, a volume form exists without that.
Nevertheless, for higher codimension you could generalize your same idea: At each point p of the manifold pick an orthonormal basis N1, ..., Nd for the orthogonal complement in such a way that if v1.....vm is a basis for TpM with positive orientation, then v1 ..... vm, N1, ...., Nd has positive orientation in Rn. Then for any m vectors w1,...., wm in TpM, define
Omega(w1,....,wm) = det(w1, ..., wm, N1, ...., Nd)
You then have to prove smoothness. Fill in the details for that part and check whether you had to use the embeddedness.
quasar987
#4
Nov14-12, 09:46 AM
Sci Advisor
HW Helper
PF Gold
quasar987's Avatar
P: 4,768
Quote Quote by Vargo View Post
I believe that the procedure as you describe it is ill-defined... the problem is that you are working locally, picking a local basis of the normal bundle and extending it to a positively oriented basis of the total space. But notice that if you pick a basis of the normal bundle with a different orientation, this will yield a different orientation of the submanifold. So there is no guarentee that this local construction patches to a globally well-defined orientation.
What you need is to start with a globally defined frame for the normal bundle. I.e. you need the normal bundle to be trivial for the construction to work. In codimension 1, normality of the trivial bundle is equivalent to the submanifold being orientable, so that's why it always work.
In higher codimension, the construction works if the normal bundle is trivial. Orientability does not imply triviality of the normal bundle however.
Vargo
Vargo is offline
#5
Nov14-12, 01:07 PM
P: 350
I'm not sure I follow you. I think you misunderstood my language. Let N_pM denote the orthogonal complement of T_pM. I did not say to choose an arbitrary orthonormal basis for N_pM. Rather I said choose an orthonormal basis N1,...., Nd according to the restriction that
v1, ..., vm, N1, ...., Nd
is oriented (as a basis for R^n) for any oriented basis v1,....,vm of TpM.
For any fixed point p, that is a well defined construction when you are a priori given orientations on R^n and T_pM (which is true here). In the special case that d=1, there are two possible orthonormal bases for N_pM . But only one of them satisfies the restriction that I posed.
The construction of Omega is done pointwise and is entirely independent of the choice of the vectors N1,...,Nd (as long as they are orthonormal and oriented correctly). If you locally construct smooth vector fields N_1(p),....,N_d(p) in such a way that they are orthonormal basis for N_pM at each point p in some neighborhood, you conclude that Omega is smooth. Whether the vector fields N_i(p) extend globally is irrelevant because their only role is to establish local smoothness of Omega. You could argue that their wedge product extends globally, and that is essentially the crux of the issue because it is really the wedge product of those vectors which is being substituted inside the determinant.
quasar987
#6
Nov14-12, 02:49 PM
Sci Advisor
HW Helper
PF Gold
quasar987's Avatar
P: 4,768
Oh, yes sorry, I got confused with the situation in which we are trying to prove orientability of the submanifold by constructing a volume form for it from a volume form on the ambiant manifold and global sections of the normal bundle.
But here the submanifold is known to be orientable, so of course the procedure you describe works. Again, I apologize for wasting your time.
lavinia
lavinia is offline
#7
Nov14-12, 03:55 PM
Sci Advisor
P: 1,716
For compact manifolds without boundary - this excludes the Mobius strip - a codimension 1 manifold - i.e. a hypersurface - of Euclidean space is orientable although I am not sure how to prove that. The volume form is easily constructed by contracting the volume form on Euclidean space with the unit normal to the hypersurface. The two possible orientations are obtained by contracting in adjacent slots.
A codimenion 1 submanifold of another manifold may not be orientable even if the ambient manifold is orientable. For example the real projective plane inside projective 3 space.
An orientable codimension 1 submanifold may not have a well defined unit normal if the ambient manifold is not orientable. For instance take the equatorial circle in the Klein bottle. It is oriented by a parameterization but is does not have a unit normal field.
For higher codimensions in Euclidean space, submanifolds may not be orientable and so will not have volume forms. In fact any non-orientable manifold can be embedded in some Euclidean space.
If the manifold and the ambient manifold are both orientable then one can always find a differential form that is Poincare dual to the fundamental class of the manifold. One should be able to find the volume form from this dual form - not sure how off the top of my head.
Vargo
Vargo is offline
#8
Nov14-12, 04:09 PM
P: 350
Oh I see what you mean. No need to apologize, we just interpreted the original post in two different ways :) Actually, your interpretation would clear up all the points I was confused by in my original answer.
lavinia
lavinia is offline
#9
Nov15-12, 03:53 PM
Sci Advisor
P: 1,716
So here is a proof of orientability for hypersurfaces, one that I am not happy with but it works. See Milnor's Characteristic Classes for details.
The proof shows that the normal bundle is trivial by showing that its Whitney class is zero - it only has one Whitney class, the first, since it is a line bundle.
Over Z2 the normal bundle is orientable and the maps H[itex]^{1}[/itex](R[itex]^{n+1}[/itex],R[itex]^{n+1}[/itex]-S) -> H[itex]^{1}[/itex](R[itex]^{n+1}[/itex]) ->H[itex]^{1}[/itex](S) maps the orientation class into the first Stiefel-Whitney class of the normal bundle. This fact is a special case of a theorem that applies to a normal bundle of any dimension. The two maps are the restriction in cohomology and the pull back of the inclusion of the surface as the zero section of the normal bundle. The image of the orientation class is the top Stiefel-Whitney class of the normal bundle.
Since the cohomology of Euclidean space is zero in all positive dimensions, the image of the orientation class is zero so the normal bundle of a hypersurface has zero first Stiefel-Whitney class and is therefore orientable.
I would love to see a more constructive proof.
Register to reply
Related Discussions
Orientation Forms in Different Codimension. Differential Geometry 7
Orientation of Receiver Antennas given orientation of transmitter Introductory Physics Homework 1
Caustic curves and dual curves Differential Geometry 3
Calc I problem regarding orthogonal curves and families of curves Calculus & Beyond Homework 13
Null curves vs. straight curves on Minkowski space Special & General Relativity 3
