New Reply
Mixing water at different temperatures
Share Thread Thread Tools
Nov15-12, 09:35 AM   #1
Hello all,
I'm having trouble solving the given problem.
"Assuming that no heat is lost to the surrroundings, what will be the final temperature when 1 kg of water at 10°C is mixed with 5 kg of water at 80°C"
Taking the mean of the 2 fluids will not help here since their mass is different.
I don't know any other formula regarding such problems.
Thank You,
~MoniMini
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Study provides better understanding of water's freezing behavior at nanoscale
>> Soft matter offers new ways to study how ordered materials arrange themselves
>> Making quantum encryption practical
Nov15-12, 10:59 AM   #2
Rap
Quote by MoniMini View Post
Hello all,
Thank You,
~MoniMini
You can say that the specific heat of water is constant. This is not exactly right, but it will be very close. That means the change in internal energy is proportional to its change in temperature. Its also proportional to the amount of water you have. So [tex]\Delta U_1=K M_1 (T_1-T) [/tex] and [tex]\Delta U_2=K M_2 (T_2-T) [/tex] where [itex]\Delta U_1[/itex] is the change in internal energy of the first case (which you don't know), [itex]T_1[/itex] is the initial temperature for the first case (10°C) , T is the final temperature for the first case (what you are trying to find), and [itex]M_1[/itex] is the mass in the first case (1 kg). Also, [itex]\Delta U_2[/itex] is the change in internal energy of the second case (which you don't know), [itex]T_2[/itex] is the initial temperature for the second case (80°C) , T is the final temperature for the second case (what you are trying to find), and [itex]M_2[/itex] is the mass in the second case (5 kg). K is some constant, but don't worry about it, it cancels out. Notice that the final temperature is T in both cases, because when you mix them together, they both go to the same temperature. Finally, you know that no heat was added or subtracted, so the total change in internal energy has to be zero. That means [tex]\Delta U_1+\Delta U_2=0[/tex] Now you have three equations and three unknowns [itex]T[/itex], [itex]\Delta U_1[/itex] and [itex]\Delta U_2[/itex] and you can solve for the final temperature. [tex]T=\frac{T_1M_1+T_2M_2}{M_1+M_2}[/tex] Its just a "weighted average" of the two temperatures. If both the masses were equal, you would have just the average, [itex](T_1+T_2)/2[/itex]
Nov15-12, 12:34 PM   #3
I found the specific heat capacity online. http://www.engineeringtoolbox.com/wa...ies-d_162.html
The heat capacity barely changes from 10 to 80 degrees.
But if you wanted to factor the heat capacity change, you could integrate the heat capacity across temperature to get internal energy versus temperature per mass. Then add up the initial energies and this is equal to your final energy.
Nov19-12, 01:42 AM   #4
Quote by Rap View Post
Thanks a TON! You explained it really well.
I got the correct anser. I don't know how to type in the mathematical symbols and all, but on paper I calculated and the result was 63.8°C which is the correct answer.
Thanks again :)
~MoniMini
New Reply
Tags
thermodynamics
Thread Tools
Similar Threads for: Mixing water at different temperatures
Thread Forum Replies
Formula: final temperature when mixing water with water Introductory Physics Homework 5
Entropy of Mixing for Two Ideal Gases at Different Temperatures Advanced Physics Homework 2
mixing three water quantities at different temperatures General Physics 4
Mixing different temperatures of water...? Introductory Physics Homework 1
Formula for mixing liquids of different temperatures? General Physics 4
