(?) on fixing bootmgr is compressed
  • Thread starter Thread starter slee95
    Compressed
The discussion revolves around the issue of a compressed boot manager (bootmgr) on a computer, which prevents the operating system from booting properly. Participants explore various methods to resolve this problem, including recovery options and external tools, while sharing personal experiences and suggestions.
  • One participant reports receiving a "bootmgr is compressed" message after attempting to compress files on their hard drive.
  • Another asks if there is a way to access the operating system to fix the bootmgr issue.
  • Several participants suggest searching online for recovery methods, with links to resources for recovering bootmgr.
  • EasyBCD is recommended by some as a tool for managing boot loaders, particularly for Windows 7.
  • There is a discussion about accessing a hidden recovery partition on the hard drive, with caution advised against restoring to factory settings.
  • Participants share experiences of upgrading operating systems without a CD drive and discuss the use of external drives for installation.
  • One participant mentions the possibility of using Bootrec.exe commands to fix bootmgr if they can access a Windows recovery environment.
  • There is a suggestion to use Ubuntu in live mode to back up files before reinstalling Windows.
  • Another participant questions the feasibility of copying bootmgr from a working computer to the affected one.
Participants do not reach a consensus on the best method to resolve the bootmgr issue, with multiple competing views and suggestions presented throughout the discussion.
Some participants express uncertainty about the specific recovery options available for different laptop brands, and there are mentions of potential risks associated with recovery processes that could lead to data loss.
  • #31
Ok thanks i'll try the disk when my friend brings in his external.
Computer science news on Phys.org
  • #32
on a separate issue, you said your actual dvd drive does not work in the laptop, if it doesn't show up in bios its definitely a hardware issue or firmware, i have had issues in the past of a dvd drive not showing up in windows and usually its due to a recent software installation that gives you a virtual drive of some discription, like norton 360 live update, majority of usb internet dongles ect. there is a simple fix through regedit.exe to fix the registry errors, depending on the laptop and if it is still in the warranty period they should replace the drive, if not there should be firmware updates online, i know this doesn't actually help you at the current time due to not being able to load windows but for future reference.
the upper and lower filters that are in the registry that can cause your dvd/cd drive to magically disappear are here
Open regedit.exe (windows key + R) type regedit and push enter/ok
Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
you really only need to look for the first 4D entry.
on the right you may see upper filters and lower filters, delete both and restart your computer.
upon restarting you will see your dvd drive has magically come back to your my computer.
This is a common issue and cause for dvd drives to go limbo
  • #33
r4z0r84 said:
on a separate issue, you said your actual dvd drive does not work in the laptop.
It's not clear if there is a cd/dvd drive and it's broken, or if this lap top never had an internal cd/dvd drive.
  • #34
i was going off the "cd driver" comment from the first page, I am just assuming it does have a physical drive there and the driver/firmware/hardware is failing. unless it was a typo and there is no cd drive. so yes i agree it is unclear although those troubleshooting steps would help figure out exactly what is wrong with the drive if it is physically there.
  • #35
It never came with a eternal and it can't have one which sucks :(
  • #36
You two know your computer a lot better then i do.
  • · Replies 16 ·
  • · Replies 20 ·
  • · Replies 17 ·
