New Reply
Thermal Insulation Of Hydraulic Cylinders
Share Thread Thread Tools
Nov15-12, 11:35 PM   #1
Hi All,
I'm working on a Hydraulic Tire Curing Press Project.There are Hydraulic cylinders in many regions of the press.Steam @ 220 deg c is used to heat the tire to bring about vulcanization process.The press earlier supplied to the customer had thermal insulation problems due to which the structure got heated and the heat was transferred to the cylinders (Which has been rectified in the present design) by which the seals of hydraulic cylinder failed frequently.The customer now demands thermal insulation for all hydraulic cylinders even though we have satisfactory insulation design.
The question is readymade thermal insulation available for hydraulic cylinders? or has anyone read or heard of insulating the hydraulic cylinders?
Note: I have done some searching in internet and i couldnt find any results.
Sorry if I have mis-stated or understated something and thanks in advance for your support.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
New Reply
Thread Tools
Similar Threads for: Thermal Insulation Of Hydraulic Cylinders
Thread Forum Replies
thermal-hydraulic codes for cores and thermal-hydraulic codes for systems Nuclear Engineering 3
Engineering - working out a problem with thick and thin hydraulic cylinders Engineering, Comp Sci, & Technology Homework 0
