| New Reply |
Old Mini Van to power and heat house. |
Share Thread | Thread Tools |
| Nov16-12, 03:22 PM | #1 |
Hello, I have been thinking about using my old mini van to power and heat our home. We live in Canada and hydro prices have gone up allot over the past few years. Anyways the idea is to park the van beside the workshop, run the radiator lines to large water tank in the garage area that would hold heat, maybe 500 or 1000 gallons. I would also hook up 12 volt and 120/220 volt generators on the v belt system for power to charge batteries that power lights and small electronics. Also thinking the heat from exhaust could be caught with water jacket system, I get propane fairly cheap here so maybe I would run on propane, I already burn propane to heat house so why no get power and heat from hopefully the same amount of propane, thus eliminating my hydro bill altogether. The van would be put on blocks and would never move again, duck work from car heater could also heat the shop.
Any advice would be much appriciated. thank you Jay |
| Nov16-12, 03:48 PM | #2 |
Mentor
Welcome to PF!
You'll have to run the numbers on the economics: How much propane do you use in a season? How much does it cost? How much hydro (electricity?) do you use in a season? How much does it cost? You are making one major mistake though: the propane bill will go up. Your propane heat is at worst about 80% efficient and if you use your car's radiator and try to recover some of the heat from the exhaust as well, you might be able to get 50% heat and 30% power. |
| Nov16-12, 04:04 PM | #3 |
Recognitions:
Another issue is that unless you put some mechanical load on the engine, you will only be able to run it at low power (even if the engine revs are at the maximum) so you won't be burning very much fuel.
Of couse your could build a dynamometer brake for the engine and extract the waste heat from that as well, but that's heading away from this being a "simple" project. |
| Nov16-12, 04:40 PM | #4 |
I burn about $250 to $300 in propane over the winter months plus about same in electricity. I figure if I was able to have the engine start and run for 1 hours say 4 times every 24 hours to heat the system and power batteries. The current propane burner we use appears to burn allot and is constantly firing up, I can see the engine burning more.
Later on I would *** a gasifier boiler that will burn pellets. |
| Nov16-12, 04:42 PM | #5 |
| Nov17-12, 08:51 AM | #6 |
Best way to save money on heating is to turn the thermostat down and to spend some money on suitable insulation methods. |
| Nov17-12, 09:01 AM | #7 |
Mentor
A quick calc, though: Gasoline and propane have similar heat capacities, of around 48 MJ/kg (higher heating value). Based on watching my car's fuel flow in realtime, I would guestimate that your minivan will burn about 2 kg/hr. That's 96 MJ/hr or 26 kWh (also a rate of 26 kW). Recovering half of that as heat would mean you could get 13 kW of heat. That's actually a decent amount of heat, so this is probably viable from the heating side. Check the capacity of your existing heating against that. Now, if you could simultaneously recover half that much electricity (note, we're at idle here, so probably not...), that's 6.5 kW. I'd be shocked if you could use anywhere close 6.5 kW of in the winter. And since my gut tells me the cost of your generation of the electricity is probably higher than the electric company is selling it to you for, that will probably destroy your economics. |
| Nov17-12, 09:03 AM | #8 |
Mentor
Still, the biggest problem with cogen is whether the electrical and heat outputs are matched to the load. In the winter, the heat requirement is almost certainly going to dwarf the electrical requirement, but you can supplement the fuel-fired heat with electric heat...if you can generate the electricity cheaply enough for that to be economical. |
| Nov17-12, 09:28 AM | #9 |
I can see that the attractive feature of this scheme is the 'free mini van'. Do not get too hung up on that aspect because the other costs will soon become appreciable - even just mounting the engine or getting power off the shaft in situ. Combined heat and power systems have been tried all over the place and can be quite effective, I believe, in the right circs. But you need to do a total costing and bear in mind that you never get anything for nothing.
BTW, what sort of generator(s?) were you planning to link to? If you need to buy one then it could cost you. For AC power, you would need to control (regulate) the engine speed fairly well and that wouldn't be easy on a road engine. If you were really interested in being self sufficient for power, you would probably be better off buying a second hand water cooled diesel generator. You don't want to land yourself with a 90% built system that never actually delivers. |
| Nov17-12, 09:38 AM | #10 |
I can't say for sure but I would guess it will cost you 5 to 10 times what you pay for commercial power to generate it on your own. That may be a conservative guess as it depends on what you pay. About 15 years ago I did some calculations on this during an extended power outage. I came up with 50 cent per KWH just in fuel to generate it with a gas powered generator. This was an average over a number of days. The generator did not run unless necessary. It was easy to calculate because there was little electrical load compared to being on the grid since everything that was not necessary was turned off.
| Nov17-12, 11:29 AM | #11 |
Thanks for all the replies everyone, propane is cheaper then diesel here so I do want to go propane CHP, I have seen a few units out there that would fit the bill but pricy and not available here in canada, I been thinking a liquid cooled propane generator could easy be used to both heat and power house. Pellets are another cheap option for me, I found one stove maker who claims to have adapted a steam turbine for power, interesting. I will start by getting my electric system in place, battery bank and inverters, then eventually ill find the best way to charge them,
| Nov17-12, 12:10 PM | #12 |
I am now thinking of going with an outboard boat motor, 4 stroke converted to propane connected to an industrial electric motor for power, engine heat recovered through cooling system and exhaust system. I figure around 200cc would do it all, this could all be built into my shop beside the house and have lines running to the house.
| Nov17-12, 01:58 PM | #13 |
| Nov17-12, 02:34 PM | #14 |
Also, what you asking about is sometimes called cogeneration, or CHP, which is an abbreviation of "Combined Heat and Power". A google search of cogeneration here at the forum yields 64 references. Several of which provide relevant information of currently existing products: Lichtblick, Honda. |
| Nov17-12, 06:10 PM | #15 |
The time when you really do better 'on your own' is when you have a free source of energy - like regular wind or good Solar. You could find you put a lot of effort and bruised knuckles into your project and either barely break even or lose out. That would be disappointing so get the spreadsheet out and do your sums very carefully before lifting a single spanner. |
| Nov18-12, 01:48 PM | #16 |
And don't forget to factor in the oil changes.
| Nov18-12, 01:49 PM | #17 |
And the bloody noise!
| New Reply |
| Thread Tools | |
Similar Threads for: Old Mini Van to power and heat house.
| Thread | Forum | Replies | ||
| Heat transfer, energy needed to heat house | Introductory Physics Homework | 3 | ||
| car heater to heat house?? | Classical Physics | 3 | ||
| Power a House | General Engineering | 2 | ||
| House Color and Heat | Classical Physics | 8 | ||
| heat loss in a house | Introductory Physics Homework | 1 | ||
