Equation of State: Understanding f(P,v,T)=0
  • Context: Undergrad
  • Thread starter Thread starter Outrageous
    Equation of state State
The discussion revolves around the equation of state represented as f(P,v,T)=0, specifically questioning why this function equals zero rather than a constant. Participants explore the implications of this formulation in the context of ideal and non-ideal gases, as well as the definitions and assumptions involved in the equations.
  • Some participants express confusion about the meaning of f(P,v,T)=0 and why it is not equal to a constant.
  • One participant suggests that any constant could be used in the function without changing its nature, indicating that zero is a convenient choice.
  • Another participant provides an example using the ideal gas law, showing that f(P,v,T)=Pv-nRT, which equals zero for ideal gases.
  • There is a mention of non-ideal gases having more complex relationships, but the underlying concept remains similar.
  • Some participants emphasize the importance of defining variables and the number of moles in the context of the equations discussed.
  • There are discussions about the units of the gas constant R and how they relate to the equations presented, with some participants questioning the omission of variables in certain contexts.
  • One participant references historical learning experiences related to the gas constant and its application in the ideal gas law.
Participants do not reach a consensus on the interpretation of f(P,v,T)=0, with multiple competing views on the implications of using zero versus a constant. There is ongoing debate about the definitions and assumptions underlying the equations discussed.
Some participants note that the discussion may depend on unstated assumptions regarding the definitions of pressure, volume, and temperature, as well as the context of ideal versus non-ideal gases. There are also references to potential inconsistencies in the application of the gas constant R and its units.
Outrageous
I know Pv=RT, but I don't understand why my book said f(P,v,T)=0 mean?
Why the function of P,v,T equals to zero? Why not equal to a constant?
Thank you.
Science news on Phys.org
You could use any constant (with a modified function), it would not change anything. f(P,v,T)=0 implies f*(P,v,T)=c where f*=f+c.
=0 is chosen as 0 is a convenient value.
I am sorry.
I still don't understand why f(P,v,T)=c=0 ?
Can you give simple example which did not involve f()... or normal equation that show c=0?
Thank you.
For ideal gases, Pv=nRT and therefore Pv-nRT=0
That is a simple equation, and it shows that there is a function f with f(P,v,T)=0, namely f(P,v,T)=Pv-nRT.
There is another function f* with f*(P,v,T)=1:
f*(P,v,T)=Pv-nRT+1
As you can see, that function does not help - it just gives an additional constant.
Non-ideal gases have more complicated laws, but the idea is the same.
Edit: Oh, forgot to add n.
Thank you.
Please define you variables. From the definitions I am familiar with, you expression is wrong, unless you have made an unstated assumption.
Since you know PV= RT where R is the gas constant, with P, V and T variables, you know that
[tex]\frac{{PV}}{T} = R = {\rm{a}}\;{\rm{constant}}[/tex]
We can rearrange this
[tex]\left( {\frac{{PV}}{T} - R} \right) = {\rm{0}}[/tex]
Isn't this now in the format you seek?
However noting your other threads about Van der Waal's equation I wonder if your book was leading up to some more complicated function of P, V and T such as VDW.
Incidentally the answer to your question about P, is that P is the real pressure exerted by the gas, not some equivalent pressure of an ideal or other gas.
Studiot said:
Since you know PV= RT where R is the gas constant, with P, V and T variables, you know that[tex]\frac{{PV}}{T} = R = {\rm{a}}\;{\rm{constant}}[/tex]We can rearrange this[tex]\left( {\frac{{PV}}{T} - R} \right) = {\rm{0}}[/tex]
Are you talking about the universal gas constant R? If so, you units are off.
R = universal gas constant = 8.3145 J/mol K
http://hyperphysics.phy-astr.gsu.edu/hbase/kinetic/idegas.html#c1
http://hyperphysics.phy-astr.gsu.edu/hbase/hframe.htmlYou need to specify the number of moles.
Only if you are talking about a number of moles.
In which case you would use the equation PV = nRT.
Thank mfb ,I totally understand.
Thank you Hetware, I wonder what is the definition.
Studiot said:
However noting your other threads about Van der Waal's equation I wonder if your book was leading up to some more complicated function of P, V and T such as VDW..
Thanks. What do you mean by more complicated ? VDW=van der Waals?
VDW=van der Waals?
Of course
What do you mean by more complicated ? van der Waals?
Isn't van der Waals complicated enough for you?
What are you actually seeking to know?
Understand already . Thank you
Your units don't come out right if you use the standard definitions. Feynman makes that mistake in Vol 1, eq. 54.13 where it is of little consequence, but he uses the same flawed understanding in the discussion preceding Vol 1, eq. 47.24 where his statements are simply wrong. It's sloppy to omit variables without justifying doing so.
The proper approach would be [itex]PV \propto T[/itex]. ##PV=RT## where ##R## is the universal gas constant is simply an incorrect proposition. One could also write ##PV=CT## declaring ##C## to be a constant.
Yes, these things do matter. I recall reading that chapter in Feynman back when I was first learning about thermodynamics and sound propagation. I was stumped by ##PV=RT##. I didn't understand the justification for omitting the number of moles. I now realize that is because he never gave a justification for it.
##[R]=\frac{J}{mol K}##
##[PV]=\frac{J}{m^3}m^3=J##
The units match, if n is given as "x mol".
You can use the more fundamental Boltzmann constant, of course:
##k_b=\frac{R}{N_A}## with the Avogadro number NA.
##PV=Nk_bT## where N is the number of molecules.
All equations are for ideal gases.
Thank you for supporting my position.
Perhaps I should have specified R more thoroughly, but my excuse is that I was taught, nearly fifty years ago, that the gas constant, R is
Strictly R is the molar gas constant
(Formula edited to add missing index.)
R = 8.31 Joules °K-1 moles-1
and have been using it successfully ever since.
I see no inconsistency, perhaps you are referring to a different constant?
The dimensions of R have no bearing upon the answer to the original question which is why did the book state that a function of pressure, volume and temperature is zero rather than a constant.
I have shown a very simple mathematical manipulation of the ideal gas law to achieve this.
A physics motivation for this would be that R is the intercept on the PV/T axis of the PV/T v T graph ie the value of the constant at absolute zero. We cannot, of course, measure at this value but have to infer it from measurements at other temperatures an extrapolate back to the axis.
  • · Replies 23 ·
  • · Replies 0 ·
  • · Replies 0 ·
