| New Reply |
What is the physics behind quantum tunneling |
Share Thread | Thread Tools |
| Nov21-12, 07:58 AM | #1 |
Hi, My friends! According to quantum mechanics books ,a particle has some probability hop through the potential even when the potential is large than kinetic energy. They all explain the phenomenon by solving Schrodinger equation. Indeed, the wavefunction doesn't equal 0 behind the potential. But I want to know how the particle go through the potential? What is the physics behind quantum tunneling? I can't accept the explaination in books! Everyone who says something about quantum tunneling would be highly appreciated.
let us talk about it!! best wishes!! PS: I read something about STM. the book says that because of tunneling ,the electron of metal are not confined the inner of surface,that is to say ,electron density don't fall to zero at the surface,but attenuation exp(), I want to know why the electron leaves the metal ,and they have pass the potential barrier!!! |
| Nov21-12, 08:13 AM | #2 |
The physics IS the Shrodinger Equation. There is a lot to think about, but there is no Classical explanation, which is what it sounds like you are looking for. I understand your ambivalence, but Nature does not care what you are willing to accept. The physics behind it is quantum mechanics which does not require localized particles as the system evolves. Sorry.
| Nov21-12, 04:35 PM | #3 |
I think its Heisenbergs uncertainty principle. The smaller a particle is, the less its position in space can be known. As a result, it exists in multiple locations in space.
| Nov21-12, 06:59 PM | #4 |
| Nov22-12, 08:29 AM | #5 |
Mentor
| Nov22-12, 09:11 AM | #6 |
Mentor
Zz. |
| Nov22-12, 10:59 AM | #7 |
Probability function drops sharply inside the barrier but never zero. Then only physical explanation can be made this way: The particle somehow interacts with the potential barrier. In microscopic world this interaction is possible, but not in macroscopic world. |
| Nov22-12, 07:41 PM | #8 |
| Nov22-12, 07:45 PM | #9 |
thank you all!!is this ture? when particle is confined in the barrier,according to Heisenberg's uncertainty principle, the momentum will become larger than the potential barrier,even though it doesn't large than the barrier at first!! so in essence, the particle's energy still is larger than the potential,so it can hop through the barrier!!
PS: the question is if particle's energy increases because of Heisenberg's uncertainty principle, what form of energy is decrease? energy conservation!! |
| Nov22-12, 09:39 PM | #10 |
| Nov23-12, 06:42 AM | #11 |
It's not that the particle has enough energy to get through the barrier,energy fluctuations in the barrier can push the particle through it(by absorbing and emitting).
| Nov23-12, 11:44 AM | #12 |
| Nov23-12, 12:54 PM | #13 |
Drakkith
If it's the particle itself that has the uncertainty then:- Are you saying that 2 protons in the vacuum of space,have the same chance of tunneling through the barrier,as 2 protons in the middle of the sun? |
| Nov23-12, 01:37 PM | #14 |
| Nov23-12, 03:45 PM | #15 |
Well it certainly isn't classical physics. Someone mentioned the uncertainty principle and the different principles of quantum physics. The difficulty lies in accepting that atoms are more like processes and much less like rocks(i am still struggling as this must hold for larger objects too, but so was Heisenberg and everyone else): "In modern physics, atoms lose this last property, they possess geometrical qualities in no higher degree than colour, taste, etc. The atom of modern physics can only be symbolized by a partial differential equation in an abstract multidimensional space. Only the experiment of an observer forces the atom to indicate a position, a colour and a quantity of heat. All the qualities of the atom of modern physics are derived, it has no immediate and direct physical properties at all, i.e. every type of visual conception we might wish to design is, eo ipso, faulty. An understanding of 'the first order' is, I would almost say by definition, impossible for the world of atoms" — Werner Heisenberg Philosophic Problems of Nuclear Science, trans. F. C. Hayes (1952), 38. |
| Nov23-12, 07:21 PM | #16 |
If the the repulsive force between 2 protons,is mediated by the creation and exchange of virtual particles,and this field of virtual particles is the barrier,then you have just as much uncertainty about the position and strength of the barrier,as you do about the position and momentum of the protons.
| New Reply |
| Thread Tools | |
Similar Threads for: What is the physics behind quantum tunneling
| Thread | Forum | Replies | ||
| Quantum Tunneling in a Scanning Tunneling Microscope | Quantum Physics | 5 | ||
| Quantum Tunneling | Quantum Physics | 9 | ||
| Quantum tunneling | Quantum Physics | 18 | ||
| quantum tunneling | General Physics | 3 | ||
| Quantum tunneling | General Physics | 26 | ||
