New Reply
extruding a 2d curve
Share Thread Thread Tools
Nov20-12, 03:00 AM   #1
Hi all!
I would like to extrude a 2d curve in the X-Y plane along the Z direction,thereby wanting to obtain a plane of Z units long.How should I proceed?
Is there a tool especially for this in MATLAB?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Nov20-12, 08:32 AM   #2
matlab or not, if all you want to do is extrude such line in a straight line, all you need to do is add the third dimension (z), add a bunch of consecutive numbers to it z=1,2,3,4... and then simply broadcast the same x,y values along the third dimension.
Nov21-12, 12:32 AM   #3
Ok,I created it for a polynomial function(MATLAB CODE)
x=0:.1:10;
y=0:.1:10;
f=@(x)0.6.*x.^3+1.9.*x.^2+3.*x+25;
y=f(x);
z=zeros(size(x));
for i=0:.1:10
z1=z+i;
plot3(x,y,z1)
drawnow;
pause(eps);
hold on
end
Question:How do I 'fit' a surface through all these curves(assuming the curves are slightly different but parallel)?,how do I use these level curves to make a surface?"
I get an error saying"??? Error using ==> surf at 78
Z must be a matrix, not a scalar or vector." when I insert the command
surf(x,y,z1)
is creating a surface the same as creating a mesh?
Nov21-12, 07:56 AM   #4
first of all, I do not know matlab
second, your z1 variable is a one-dimensional vector only to which you are assigning, one at a time the values 0, 1, 2, 3, etc. Your z variable remains zero since initialized, you never assigned anything to it.
I think you first need to learn how to plot 3D, do an exercise from the user's manual and figure out what x, y, and z need to be.
Nov21-12, 10:46 AM   #5
I am using z1 as the z coordinate,not z.
z1=z+i;
plot3(x,y,z1)
It would helpful if someone can answer the queries above.
Thank you.
New Reply
Tags
interpolation
Thread Tools
Similar Threads for: extruding a 2d curve
Thread Forum Replies
Need help with this Elliptic curve theory (Edwards curve) Calculus & Beyond Homework 0
Area Under a Curve, 3D, with known end points and curve radius Calculus 0
Banked Frictionless Curve, and Flat Curve with Friction Introductory Physics Homework 1
How to convert force displacement curve to stress strain curve Engineering, Comp Sci, & Technology Homework 1
Differential Geometry: Showing a curve is a sphere curve Calculus & Beyond Homework 0
