New Reply
Triplet Paradox
Share Thread Thread Tools
Nov14-12, 12:29 AM   #52
Recognitions:
Gold Membership Gold Member
Triplet Paradox
Ignore your 3rd diagram and follow the suggestions I made in post #38:
Quote by ghwellsjr View Post
I agree, your third graph is implausible.
I have a suggestion: let's change the scenario to one that you can accurately draw graphs for. So let's change the speed of Adam to 0.6c. This will make the redshift Doppler factor be 0.5 and the blueshift Doppler factor be 2.
Adam will go for one year away according to his clock and one year returning. He will emit a flash of light every month for a total of 24, 12 on the way out and 12 on the way back. He will see the flashes coming from Charles at one half that rate on the way out for a total of 6 and for double that rate on the way back for a total of 24 more and a grand total of 30.
Charles will emit 30 flashes during the time that Adam is gone. Since he will be seeing Adam's flashes coming in at one half his rate and since he sees Adam turning around when he sees the 12th flash from Adam, he will be emitting his 24th flash at that moment. Then he sees the flashes coming in at double his rate for 12 more flashes from Adam while he is emitting 6 more. His total is again 30 while Adam's total is 24.
Please redraw your first two graphs using these numbers, make sure the slope of Adam's path is accurate for 0.6c and the rate of Adam's flashes are spaced farther apart by a factor of 1.25 compared to Charles's flashes to take into account his time dilation.
Then after you make those two graphs, make a third graph that is simply an overlay of the first two graphs. This is how you can show the Doppler effect and this one graph will show accurately the perspective of both Adam and Charles in terms of what they see compared to their own clocks.
Nov14-12, 04:06 AM   #53
Recognitions:
Sorry I meant Adam and Bob. oops. Why is it that they both return having aged the same?
Nov14-12, 09:15 AM   #54
Recognitions:
Quote by greswd View Post
You haven't done a correct set of graphs for Adam and Charles. If you do that and then add in a similar graph for Bob and Charles but flipped upside down, then you will be almost there. All you will need to do at that point is extend the light paths for Adam and Bob so that they go past Charles and reach all the way to the other person.
Or did you want to forget about graphs and pick up where we left off in the middle of page 2?
Nov21-12, 10:29 AM   #55
Recognitions:
graphs are very important, special relativity becomes very clear with a minkowski diagram. Plus as Einstein himself said, a geometric understanding is necessary to make sense of his general theory.
Nov21-12, 11:10 AM   #56
Recognitions:
If you're going to make a graph, it has to be done correctly. Your set of graphs haven't been done correctly. If you would do the graphs correctly for Adam and Charles, as I have suggested, and then add in Bob, as a flip side of Adam or a mirror image of Adam, then you will see how Adam and Bob have aged the same amount when they rejoin Charles.
If you don't want to make the graphs correctly, I will. And I will also explain the scenario without the use of graphs.
By the way, your graphs are not Minkowski diagrams, they are simply conventional position versus time graphs. And I'm not saying that simply because you are interchanging the time versus distance axes that is more common for a Minkowski diagram.
Nov21-12, 11:34 AM   #57
Mentor
What is the difference?
Nov21-12, 01:18 PM   #58
Recognitions:
Minkowski diagrams have at least two sets of axes to show how each event has two sets of coordinates for two different reference frames. All of the graphs that greswd presented have only one set of axes corresponding to the frame in which Charles remains at rest and in which Adam and Bob start out at rest and end up at rest.
People were drawing position versus time graphs long before Minkowski or Einstein or Lorentz or even Maxwell. I don't think Minkowski gets backwards credit for all those graphs just because they only have one set of axes.
Nov21-12, 03:21 PM   #59
Recognitions:
That's news to me. Do you have a text book that uses that specific definition?
Nov21-12, 03:51 PM   #60
Recognitions:
Quote by DrGreg View Post
It's very hard to find a specific definition anywhere. Is there an official definition that you can point me to or that you want to provide even without reference?
If someone draws a graph of position versus time, does that automatically make it a Minkowski diagram? Would you call greswd's graphs on this thread Minkowski diagram's?
Nov21-12, 04:15 PM   #61
Recognitions:
I don't have a formal definition either. But I've just looked in Rindler's book Relativity: Special, General, and Cosmological and found a diagram depicting Rindler coordinates against a single set of Minkowski axes which he calls a "Minkowski diagram" (2nd ed, p.269). So to my way of thinking any distance-versus-time diagram that is relativistically compatible (for an inertial frame, and therefore in Minkowski coordinates) is a "Minkowski diagram". Maybe some authors have a more restrictive interpretation but I've never seen that.
Nov21-12, 04:36 PM   #62
Recognitions:
So then if Newton drew a distance-versus-time diagram but he did not show that a traveler's clock was running slower than the coordinate time, then it would not be a Minkowski diagram, correct? Or more specifically, if the diagram shows somehow that the traveler's clock is indicating a slower time than the coordinate time, then that makes it Minkowski? In other words, it doesn't have to explicitly use a second set of axes to show the slower time, it can just do it as points spaced further apart than the coordinate spacing, correct?
Nov21-12, 09:17 PM   #63
Recognitions:
Technically, all displacement-time graphs look the same with reference to one particular frame.
The distinguishing factor is the transformation from one frame to another.
Now we've learnt about two transformations, Galilean and Minkowskian.
Of course, we may come up with others, but they may not make physical sense.
When transforming between inertial frames, all transformations have to use the worldline as the time axis, and ensure that relative velocity between both frames is the same.
Nov23-12, 11:02 AM   #64
Minkowski diagrams replace the traditional time axis with ct (distance).
This results from transforming the equality for the invariant interval into a 4D expression, via t'=ict.
The benefit is twofold.
Unless one of the coordinates t or x is scaled, you could never graph it to scale!
It reveals what's really being compared. The object speed vs light speed, i.e. vt/ct=v/c.
It's the only variable in the gamma expression, which is the only factor distinguishing SR from pre-relativity physics.
Dec4-12, 02:37 AM   #65
Recognitions:
How do we draw a graph to describe that from Adam's perspective? It is this graph
It shows a highly implausible scenario.
As promised, here are the graphs that I suggested that you make. The first graph is similar to your first graph except I haven't shown dots along Adam's path (black) to show where he receives signals from Charles (blue with yellow signals) because they are uncalibrated:
Similarly, I haven't shown dots along Charles's path (blue) to show where he receives signals from Adam (black):
Finally, I suggested that you overlay these two graphs to get a correct third graph that shows everything, including Adam's perspective:
Note that we can now see Adam's time dilation. Since his speed is 0.6c, gamma is 1.25 and his tick marks are spaced at 1.25 of the coordinate grid. This illustrates that his Proper Time is equal to gamma multiplied by the coordinate time. You can also see that he sends a signal to Charles at every tick but during the outbound portion of his trip, he receives the signals from Charles every other month corresponding to a redshift Doppler factor of 0.5.
Charles is also sending out a signal every month to Adam but since he is stationary in this frame, his Proper Time is coincident with the coordinate time. Still, you can see that he receives signals from Adam every other month at the beginning. His redshift Doppler factor during this time is also 0.5.
Charles continues to see Adam' clock running at 1/2 the rate of his own until he sees Adam turn around when Adam's clock reaches 12 months. This occurs when Charles's clock is at 24 months. From then on, he sees Adam's clock running at twice the rate of his own for a blueshift Doppler factor of 2 so that in 6 more months of his own time, he sees Adam's clock adanvce by 12 months. At the end, he has seen Adam's clock advance 12 months in slow motion and 12 months in fast motion for a total of 24 months.
Meanwhile, Adam has been watching Charles's clock advance at 1/2 his own rate (redshift Doppler) so that after one year of his own time, Charles has advanced by 6 months. When he turns around, he sees Charles's clock advancing at double the rate of his own (blueshift Doppler) so that in the one year that it takes him to return, he sees Charles advance by 2 years for a total of 30 months.
Jan10-13, 05:10 PM   #66
Recognitions:
Sorry for taking such a long hiatus. I was very busy with other matters. Anyway, I understand the diagrams well.
With regards with my rejected 3rd diagram. I found this from UNSW that looks very similar.
http://www.phys.unsw.edu.au/einstein...in_paradox.htm
Jan10-13, 06:32 PM   #67
Recognitions:
Their first diagram looks very similar to my third diagram above because we both combined the signals from both twins to show how they were received by the other twin. That's what I was trying to get you to do but you never did, not even in your third diagram so how can you say yours is similar to theirs?
They did a better job on their first diagram compared to the one shown in post #34 from wikipedia but it's still not perfect. Here's what it should look like:
They show Joe 7 after he receives the signal from Jane 3 but he should be slightly before. Note also how they show Jane 5 receiving the signal from Joe 6 at the same time but she should be slightly earlier. In fact these two situations should show the same relationship because it is a reciprocal Doppler shift.
And their second diagram is wrong, not to mention ridiculous. They should show Joe 2 on the bottom diagonal and they should show Joe 6 on the top diagonal. Here is the diagram for the frame in which Jane is at rest during the outbound portion of her trip:
And here is the diagram for the frame in which Jane is at rest during the inbound portion of her trip:
What they were trying to do is combine the bottom part of the outbound portion of the trip with the top part of the inbound portion of the trip while showing in dotted lines the signals coming from Joe. They did a fairly good job of that but why don't they correctly show the signals going to Joe from Jane? They do show all five of Jane's signals but if they had shown Joe 6 at the correct location he would have received the signal from Jane 2 after the correct position for Joe 6 and it should be coming between Joe 4 and Joe 5 as they indicate in their first diagram.
It is impossible to combine the two parts of the outbound and inbound portions of Jane's two rest frames into one like this. If you're going to do it correctly, you need a much more complicated diagram. You need to show the correct Doppler signals for both twins throughout the diagram, just like all three of my diagrams show. It's so easy to do in an Inertial Reference Frame, why do you feel the need to do it in a non-inertial frame?
Jan10-13, 08:05 PM   #68
Recognitions:
Is this all true if it were two twins and an older unrelated person?
New Reply
Thread Tools
Similar Threads for: Triplet Paradox
Thread Forum Replies
Triplet paradox: where's the error in my logic? Special & General Relativity 18
What is the Triplet state Quantum Physics 24
Triplet paradox General Physics 5
The Triplet Paradox? Special & General Relativity 12
