differential and square of differential
by rsaad
Tags: differential, square
rsaad
rsaad is offline
#1
Nov22-12, 08:54 AM
P: 77
Hi
I often see the following in books but I do not understand how they are equal. So can someone please tell me for what conditions does the following equality hold?
([itex]\frac{dy}{dx}[/itex]) 2 = (d2 y)/(dx2)
Phys.Org News Partner Science news on Phys.org
Better thermal-imaging lens from waste sulfur
Hackathon team's GoogolPlex gives Siri extra powers
Bright points in Sun's atmosphere mark patterns deep in its interior
JJacquelin
JJacquelin is offline
#2
Nov22-12, 09:11 AM
P: 744
No, generaly this equality doesn't hold.
For example :
y=x
dy/dx = 2x
dy/dx = 2
(dy/dx) = (2x) = 4x
2 is not equal to 4x
The equality (dy/dx) = dy/dx holds only for one family of functions : y = - ln(ax+b).
It doesn't hold for any other function.
Millennial
Millennial is offline
#3
Nov22-12, 09:28 AM
P: 295
The equality that does hold is [itex]\displaystyle \left( \frac{d}{dx} \right)^2y = \frac{d^2y}{(dx)^2}[/itex], which is usually abbreviated (somewhat abuse of notation) as [itex]\displaystyle \frac{d^2y}{dx^2}[/itex].
HallsofIvy
HallsofIvy is online now
#4
Nov22-12, 11:20 AM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 38,881
Quote Quote by rsaad View Post
Hi
I can't help but wonder where you "often see" that? As others said, it is certainly NOT "generally" true. [itex]d^2y/dx^2= (dy/dx)^2[/itex] is a "differential equation". If we let u= dy/dx, we have the "first order differential equation" [itex]du/dx= u^2[/itex] which can be written as [itex]u^{-2}du= dx[/itex] and, integrating, [itex]-u^{-1}= x+ C[/itex] so that [itex]u= dy/dx= -\frac{1}{x+ C}[/itex]. Integrating that, [itex]y(x)= \frac{1}{(x+ C)^2}+ C_1[/itex]. Only such functions satisfy your equation.
JJacquelin
#5
Nov22-12, 12:42 PM
P: 744
Quote Quote by HallsofIvy View Post
Integrating -1/(x+C) leads to -ln(x+C)+c = -ln(ax+b)
Millennial
#6
Nov22-12, 03:07 PM
P: 295
Quote Quote by JJacquelin View Post
He probably got confused and differentiated instead. Anyways, the identity given in the OP is not generally true, actually, it is almost surely false, given the family of functions that can be defined on R2.
HallsofIvy
#7
Nov23-12, 08:13 AM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 38,881
Yeah, I confuse very easily! Thanks.
oay
oay is offline
#8
Nov23-12, 01:00 PM
P: 220
You do get sloppy very often, Halls. Shape up!
Register to reply
Related Discussions
Problem regarding '+ or -' with squares and square roots in a differential equation Calculus & Beyond Homework 2
differential eq with square root numerical Differential Equations 8
Minimal Surfaces, Differential Geometry, and Partial Differential Equations General Math 0
square of a differential form Calculus & Beyond Homework 0
Square-root and differential equations Calculus & Beyond Homework 4
