| New Reply |
Could a man hold sustained flight using sound? |
Share Thread | Thread Tools |
| Nov24-12, 06:39 PM | #1 |
I was reading an article on Acoustic Levitation http://science.howstuffworks.com/aco...evitation2.htm and near the end it said
I know I'm asking a lot of questions so I don't expect all of them to be answered but it's just something I've been wondering for a while now. Also if you could tell me how you got to your answers that would be great. Thanks! |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Nov24-12, 08:06 PM | #2 |
Recognitions:
That is a super-power, so we are thinking in terms of constructing a vehicle of some kind that uses soundwaves for propulsion - preferably a flying machine.
Cannot think of any reason off the top of my head that it is not possible in principle - sound is just a pressure wave after all and you know shock-waves (high amplitude sounds pulses) can move things around and even lift people off their feet. See: http://www.engineeringtoolbox.com/so...ure-d_711.html ... for a starting point. Seriously doubt such a machine would fit into a backpack - even with a flight-suit. It would certainly be illegal to operate one over built-up areas. The SST produces a sonic boom that can shatter windows but does not knock people over ... you are speculating about something much more powerful. |
| Nov24-12, 09:26 PM | #3 |
Astro_Will,
You are attempting to mix fictional fantasy stories with real natural science. Levitation of tiny objects is possible for some light-weight objects if they are trapped in an "acoustic standing wave node" (you may Google that phrase). This mechanism does not apply the sort of thrust you are asking about where a human’s voice would generate enough thrust for a man to fly. Experiment with a powerful acoustic emitter (speaker, for example). Using a sound source and a powerful audio amplifier, energize the speaker. Then hold a flat plate near the speaker’s output. Try to measure the force exerted on that plate. Reverse the measurement: try to measure the recoil force the speaker causes while emitting high power sound. Results in both cases: NONE. Therefore, no human, no matter how loud his voice may be, could propel himself to fly. Cheers, Bobbywhy |
| Nov24-12, 10:03 PM | #4 |
Hmm, I'd never thought about. There might be some clever way to do it, but I sure can't think of one. Sound waves are pressure waves. So you get a pressure that moves an object in some direction, but a millisecond or so later you get rarification (reduced pressure) that moves the object in the opposite direction, so it cancels out. If you were moving at the speed of sound then you could "surf" a pressure wave, but if you yourself are producing the sound then it will never catch up to speed-of-sound you.
That levitation seems to be like this. You have a standing wave, so there are static regions of pressure that are more dense than the object being levitated. Areas of air that are more dense than a human body are not going to happen. If there is a lot of thrust coming out of his mouth, why doesn't it blow his head off? Even if it didn't, why doesn't he tumble end over end? You might have more luck having this sound reduce something's mass. Uh, maybe the frequency is so high it disturbs the strong force in something's atoms. But that would be a lot more likely to cause some ungodly explosion. I don't see any way to do it. |
| New Reply |
| Tags |
| sound |
| Thread Tools | |
Similar Threads for: Could a man hold sustained flight using sound?
| Thread | Forum | Replies | ||
| Time of Flight using flight path and radius (Kepler's Equation) | Engineering, Comp Sci, & Technology Homework | 4 | ||
| Your view on rat race and sustained progress | General Discussion | 4 | ||
| 12 volt generation of a sustained arc | General Engineering | 19 | ||
| sustained interference patterns | Introductory Physics Homework | 2 | ||
| Forced Self-Sustained Oscillator | Classical Physics | 0 | ||
