| New Reply |
Higgs Field: Perfectly Static Particle is Massless? |
Share Thread |
| Nov24-12, 06:25 AM | #1 |
Like the question says: if a particle is perfectly static with respect to the Higgs field, can we still define mass or is mass then irrelevant?
On another note, (and if I am not mistaken) why does mass not vary with a particle's speed with respect to the Higgs field? IH |
| Nov24-12, 08:37 AM | #2 |
Mentor
Physics is the same in all inertial frames. There is no "perfectly static with respect to the Higgs field".
Every particle has the same mass, just given by its type and independent of its velocity relative to anything else. |
| Nov24-12, 09:09 AM | #3 |
... and the Higgs field itself is the same in all inertial frames. It's a scalar field, uniform in time and space, and looks exactly the same to all observers no matter what their velocity.
| Nov24-12, 08:00 PM | #4 |
Higgs Field: Perfectly Static Particle is Massless?The problem is that this is a very poor analogy. As you have noted, it suggests that the particle's mass should depend on its speed, which isn't true. |
| Nov25-12, 03:48 AM | #5 |
The problem is that there are so many poor analogies used by physicists to explain certain phenomena of non-classical physics, like the universe-with-no-center-expanding-on-a-balloon surface, an object's mass increasing with its relative speed, etc. How about some high-quality analogies for a change... IH |
| Nov25-12, 04:19 AM | #6 |
Hi Islam!
![]() mass is resistance to movement (ie the more mass it has, the more force is needed to move it) so stationary particles aren't affected by the velcro at all, but the heavily-coated particles feel a lot more resistance when they do move, and need to be pushed harder to achieve the same change in speed
| Nov25-12, 06:11 AM | #7 |
Hi there Tim :); well your comment brings me back to the original question: if the particle is stationary, can one talk of/define mass at all? I recall reading somewhere that electron for example 'collide' with the Higgs every 10^-17 cm on average, so if the electron was somehow stopped between 'collissions', can we talk of mass? IH |
| Nov25-12, 07:13 AM | #8 |
The 10-17 cm is a reference to the Higgs BOSON. This is the distance that a virtual Higgs boson can travel before it is reabsorbed. (the Compton wavelength that corresponds to 125 GeV) |
| Nov25-12, 07:55 AM | #9 |
Mentor
- nobody found a better analogy of similar complexity yet - the analogy is fine, but someone (usually not a scientist) used it where it is not appropriate I think the balloon analogy is an example of a very good analogy. Relativistic mass is a bad concept. |
| Nov25-12, 08:31 AM | #10 |
Mentor
It is said that a translation is like a mistress - either beautiful and unfaithful, or faithful but not beautiful. Analogies are the same way: they can be simple, they can be accurate, but usually they cannot be both. |
| Nov26-12, 06:18 AM | #11 |
I understand your argument and can tell you that as a layman I have devoted much time trying to understand many phenomena in non-classical physics; sometimes quantitatively (SR and QM especially), sometimes not. In some cases, as with the Higgs field/particle, common lay analogies are my starting point; this may in retrospect not be an appropriate approach, I grant you that. The issue I have however is that these lay analogies don't come with any type of qualification. They are simplified and therefore appear intuitive when often they are not. I am not against analogies, be they good or bad, so long as I am simultaneously aware of their (sometimes significant) limits. I understand that physicists -like any other profession- enjoy informing the public of their very considerable scientific achievements. Simply, I don't think that adding a dose of qualification (call it realism...) to lay analogies would detract from our fascination with physics. IH |
| Nov26-12, 06:31 AM | #12 |
My reference is at 37:05 mins on this IAS lecture by N Arkani-Hamed: http://www.youtube.com/watch?v=weGgGkt7_48 He talks of an electron moving around and 'banging into' the Higgs field 'condensate' every 10^-17cm. This I trust is equivalent to your statement re this being the distance that virtual Higgs bosons travel. IH |
| Nov26-12, 08:07 AM | #13 |
Mentor
| Nov26-12, 10:05 AM | #14 |
If you think the balloon analogy is a poor analogy, you simply haven't seen a good representation of that analogy. Try this:
http://www.phinds.com/balloonanalogy/ |
| New Reply |
Similar discussions for: Higgs Field: Perfectly Static Particle is Massless?
| Thread | Forum | Replies | ||
| Questions about the behavior of the Higgs particle and Higgs field | High Energy, Nuclear, Particle Physics | 7 | ||
| Does ''Higgs sector'' mean there are many Higgs particle types? | Beyond the Standard Model | 4 | ||
| Motion of a charged particle in a static magnetic field in matlab | Engineering, Comp Sci, & Technology Homework | 0 | ||
| Higgs Field/Particle | High Energy, Nuclear, Particle Physics | 8 | ||
| BRS: Static Axisymmetric "Gravitationless" Massless Scalar Field Solutions | Special & General Relativity | 6 | ||
