| New Reply |
Help with calculating vertical jump with kinematic equations |
Share Thread | Thread Tools |
| Nov21-12, 09:28 PM | #1 |
Ok, so I'm using an arduino with an led matrix and a homemade pressure sensor to figure out the height of a vertical jump and then display the info back. First I get the amount of time between when the person left the board and when they land back on it. I then divide the time in half and use the equation:
Yf = 1/2 * g * t^2 substituting g for 386.088 inches per second^2 giving Yf = 193.044 * t^2 My problem now comes in here. I'm doing this inside a room with an 8 foot ceiling for easy reference on how high I am jumping. I'm 6' 1" so when I jump so that my head just barely touches the ceiling my vertical is roughly 23". The arduino, though, is reading a little over 16". My first thought was that the pressure pad was staying down for some time after I jumped, but I recorded a jump and it's working right starting the time right when I leave the pad. In fact I even used the time I got from comparing when I left the ground on the jump and when I landed in the video and got .58 seconds. Using the equations before that gives a little over 16 inches max height (like what the arduino measured). So, does anyone have any idea what's going on here? |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Nov21-12, 10:36 PM | #2 |
Recognitions:
Your center of mass might be in different position relative to your feet when you separate from ground, and when you touch back. If you post the video and mark where you get 23" from on some screen captures, we could probably analyze it further.
| Nov21-12, 10:50 PM | #3 |
Recognitions:
Yes, it's most likely to do with posture, but you're looking for a reason why the time recorded might be too short. So bending your legs ready to land could not account for it. Maybe it's your arms - if you raise them when descending you'll land sooner.
| Nov21-12, 10:52 PM | #4 |
Recognitions:
I think it's the other way around. He was trying not to jump too high, so he might have took off with legs still bent, but landed on straight legs.
| Nov22-12, 12:25 AM | #5 |
I thought about it being posture related also, but when going through the video it doesn't look like that. I'd upload it but it just a recording of my legs and a light on the arduino for comparison of where the algorithms at. On the jump I start with legs bent and jump up--legs extending and toes eventually pointing down. The arduino doesn't recognize me as leaving the ground until my toes come off the board (although I'm not pushing down anymore: this may be where the error is). I go up then land in the exact same manor, feet pointed down, until they touch the board then the rest of my body comes down to absorb the impact. When I begin to touch the board again is when the algorithm gets the total time. It takes very little force (probably about 10 pounds) to trigger the pressure pad.
The measurement for comparison is the top of my head, which should be a fairly accurate recording of how high I'm getting off the ground since that would be highest point I can reach. The two errors I'm thinking of right now is that the difference between being flat footed and having feet extended is causing the error, or it's the one I mentioned earlier where I'm already decelerating before leaving the pressure pad. Thanks for the responses guys, let me know if either of those or anything else seems like a more likely cause. It just threw me off a lot when I started getting these consistently differing results. Edit: Actually looking back at the posts now, the first reason seems like what you were saying k^2 |
| Nov22-12, 03:10 PM | #6 |
Recognitions:
| Nov25-12, 12:05 PM | #7 |
| New Reply |
| Thread Tools | |
Similar Threads for: Help with calculating vertical jump with kinematic equations
| Thread | Forum | Replies | ||
| Impulse of vertical jump | General Physics | 2 | ||
| Calculating velocity, time, and Instantaneous speed using kinematic equations | Introductory Physics Homework | 5 | ||
| Vertical jump vs. weight | General Physics | 16 | ||
| Vertical Jump Kinetics | Mechanical Engineering | 1 | ||
| Gravity and Vertical Jump Problem | Introductory Physics Homework | 0 | ||
