Register to reply
Integral ∫x^3*√(x^2-5) dx
by ruiwp13
Tags: ∫x3√x25, integral
Share this thread:
ruiwp13
#1
Nov25-12, 12:17 PM
P: 40
1. The problem statement, all variables and given/known data
∫x^3*√(x^2-5) dx
2. Relevant equations
∫u.dv=u.v-∫du.v
3. The attempt at a solution
So i tried to change the integral to ∫x*x^2*√(x^2-5)dx and u = x^2-5, then du = 2x, so 1/2*∫x^2*√(x^2-5) . Let u = √(x^2-5) , du = x/√(x^2-5) and dv = x^2 , v = x^3/3. Am I going in the right direction?
Thanks in advance
Phys.Org News Partner Science news on Phys.org
New model helps explain how provisions promote or reduce wildlife disease
Stress can make hard-working mongooses less likely to help in the future
Grammatical habits in written English reveal linguistic features of non-native speakers' languages
Dick
#2
Nov25-12, 12:36 PM
Sci Advisor
HW Helper
Thanks
P: 25,251
Quote Quote by ruiwp13 View Post
∫x^3*√(x^2-5) dx
∫u.dv=u.v-∫du.v
Thanks in advance
You don't need parts. Your first substitution is the one to use, u = x^2-5. Notice that means x^2=5+u.
ruiwp13
#3
Nov25-12, 12:49 PM
P: 40
Quote Quote by Dick View Post
I did that, u=x^2-5, du= 2xdx, x^2=u+5 and I got :
1/2*∫(u+5)*√udu
so I multiplied and I got : 1/2*∫u^(3/2)+5u^(1/2)
1/2*1/5 * ∫u^(3/2)+u^(1/2)
and I got u^(5/2)/25+(2u^(3/2))/3 and It's wrong :/ where did I failed?
Thanks
Dick
#4
Nov25-12, 12:56 PM
Sci Advisor
HW Helper
Thanks
P: 25,251
Just sloppy algebra, I think. Where did the '1/5' come from?
ruiwp13
#5
Nov25-12, 12:59 PM
P: 40
To remove the 5 from 5u^(1/2)
The solution is supposed to be:
x^3/3*(u^(3/2))-2/15*(u^(5/2))+c
Dick
#6
Nov25-12, 01:08 PM
Sci Advisor
HW Helper
Thanks
P: 25,251
'Remove the 5'?? I don't get it. And the given solution looks wrong as well.
ruiwp13
#7
Nov25-12, 01:11 PM
P: 40
Trough wolframalpha the solution is different:
http://www.wolframalpha.com/input/?i...t%28x%5E2-5%29
Dick
#8
Nov25-12, 01:21 PM
Sci Advisor
HW Helper
Thanks
P: 25,251
Wolfram is using u^(5/2)=u*u^(3/2) and pulling out the common factor of u^(3/2).
ruiwp13
#9
Nov25-12, 01:24 PM
P: 40
So where is my mistake?
Dick
#10
Nov25-12, 01:31 PM
Sci Advisor
HW Helper
Thanks
P: 25,251
Start with 'removing the 5'. You can write u^(3/2)+5u^(1/2)=5*((1/5)*u^(3/2)+u^(1/2)). That's not (1/5)*(u^(3/2)+u^(1/2)), if that's what you meant. It's hard to tell how you are grouping things. Use more parentheses to make things clearer.
Register to reply
Related Discussions
Divergence Integral doesn't equal surface integral Advanced Physics Homework 2
Does path integral and loop integral in a Feynman diagram violate special relativity? General Physics 0
Rewrite the integral as an equivalent iterated integral in the order Calculus & Beyond Homework 5
Using polar co-ord. to change double integral into single integral involving only r. Calculus & Beyond Homework 5
Is the ordinary integral a special case of the line integral? Calculus 3
