Are Both Angles in Young's Double Slit Experiment Equal?
The discussion revolves around the equality of angles in Young's double slit experiment, specifically focusing on the angles represented in a diagram associated with the experiment. Participants are exploring the geometric relationships and properties of triangles formed in the setup.
  • One participant seeks to prove that the two angles (θ) in the diagram are equal and asks for guidance on how to approach this proof.
  • Another participant clarifies which angle in the triangle is referred to as θ, emphasizing the distinction between the angles in the diagram.
  • A participant acknowledges their awareness of the angles but requests hints for starting the proof.
  • One participant proposes a reasoning approach involving parallel and perpendicular lines to suggest that if two lines have an angle θ between them, then corresponding lines parallel or perpendicular to them will also have the same angle θ.
  • The concept of 'similar triangles' is mentioned as relevant to the discussion, although it has not been fully elaborated upon.
Participants do not appear to have reached a consensus on the proof or the relationships between the angles, and multiple viewpoints and approaches are being explored.
The discussion may be limited by assumptions regarding the properties of triangles and the specific definitions of angles in the context of the double slit experiment. The geometric relationships have not been fully resolved or demonstrated mathematically.
Science news on Phys.org
This might help: The small triangle's theta refers to the top angle of the triangle, not the left one. Also, the right angle is right. By that I mean that the angle on the right side of the triangle is a 90 degree angle. This post was an excuse to say that the right angle is right.
Yes I was aware of which angles where which. I just used that picture since it was easily attainable. Any hints as to starting this
Suppose you have two lines A and B that have angle θ between them.
If you have line C parallel to A, and line D parallel to B, then C and D also have angle θ between them, right?
Likewise, if you have line E perpendicular to A, and line F perpendicular to B, then E and F also have angle θ between them.
The phrase 'similar triangles' comes to mind and it hasn't yet been spelled out.
  • · Replies 34 ·
  • · Replies 30 ·
  • · Replies 33 ·
15K
  • · Replies 20 ·
