| New Reply |
Probability of 0 bit in ASCII text files |
Share Thread | Thread Tools |
| Nov25-12, 08:37 PM | #35 |
Probability of 0 bit in ASCII text filesP(MSB)=P(MSB |H0)P(H0) + P(MSB |H1)P(H1) (Let Hi be the event that there are i MSB bits in N, for i = 0, 1, 2, 3….. ) where P(MSB |H0) stands for conditional probability of MSB bit in N given it is H0 which equals 0 (no MSB) and P(MSB |H1) stands for conditional probability of MSB bit in the N given it is H1 which equals 1/7 (one MSB); But it is little different from the point of N=8A+B. right? I could not figure out the computation. |
| Nov25-12, 11:08 PM | #36 |
Recognitions:
Are we done with the N≤8 case? |
| Nov26-12, 12:20 AM | #37 |
Just can`t quiet figure out how N=8A+B works. |
| Nov26-12, 02:34 PM | #38 |
Recognitions:
See what gaps you can fill in here: Prob that this includes A+1 MSB's = ....?; if A+1 MSBs, prob that all N bits are 0 is ...? Prob that this includes A MSB's = ....?; if A MSBs, prob that all N bits are 0 is ...? Adding this up, prob that all N bits are 0 is ...? |
| Nov27-12, 05:48 AM | #39 |
Analysis: Since the N bits are drawn consecutively from ASCII, there is only 1 character (out of 2^256), which is are all 0. So only 1 MSB. Thus, the Prob =1/2^256. Others seem to follow the conception , or I misunderstood your point? Question: 1) Pr[0] in ASCII (assume each character appears with same ratio) equals = 1/8+1/2=5/8. Is it OK? 2) Successive 7 bits are drawn at random from ASCII bits (e.g. no bias of character distribution), what is Pr[0] in the 7 bits? Successive 4 bits are drawn (same condition with above), what is Pr[0] in the 4 bits? So, say, Successive N bits are drawn (same condition) , what is Pr[0] in the N bits? Analysis: Do you think it is same case? remember you explained that N/8*2^-N + (1-N/8)*2^-(N+1) . Does the formula apply to the case of 2). Shed some lights on please. |
| Nov27-12, 02:26 PM | #40 |
Recognitions:
If the N bits include A MSBs then how many non-MSBs do they include? What is the prob that the A MSBs are all 0? What is the prob that the non-MSBs are all 0? So what is the prob that all N bits are 0? |
| Dec1-12, 12:55 AM | #41 |
Now, say, two N consecutive bits are taken (or two groups) (N1=7, and N2=4). So the prob is different in following cases in comparing of same amount of 0`s? 1st case: (in N1=7) Pr[0], Pr[00],..,Pr[0000] =? 2nd case: (in N2=4) Pr[0], Pr[00],..,Pr[0000] =? |
| Dec1-12, 02:17 PM | #42 |
Recognitions:
| Dec1-12, 10:15 PM | #43 |
I meant the prob of 0 within N1 =7 consecutively drawn from ASCII . In other words, say, now we have a group of bits consists of many N1, each of which is consecutive 7 bits drawn from ASCII. what is Prob[0], Prob[00] in the group respectively? 2nd case. another group of bits with same condition, where N2=4. What is Prob[0], Prob[00] within the second group respectively? Is (N1)Prob[0] = (N2)Prob[0] right, or should it be unequal? |
| Dec2-12, 12:18 AM | #44 |
Recognitions:
| Dec2-12, 12:34 AM | #45 |
(N1=7)Prob[0] = (N2=4)Prob[0] (N1=7)Prob[00] = (N2=4)Prob[00] (N1=7)Prob[000] = (N2=4)Prob[000] .... |
| Dec2-12, 02:10 PM | #46 |
Recognitions:
To be completely clear:
If you choose N consecutive bits, the probability that the first R of those bits are all zero (R <= N), depends only on R. It cannot depend on N. Further, if you choose N consecutive bits, then choose R consecutive bits from those N, the probability that the first R of those bits are all zero depends only on R. (This seems so obvious that I worry that I have not understood the question.) |
| Dec2-12, 08:40 PM | #47 |
take R=2 bits from N1 & N2 respectively, what is prob that they are two 0 bits. 1st. (N1 case) : {(9X/16)C2 * (7X/16)C5 } / xC7. 1st. (N2 case) : {(9X/16)C2 * (7X/16)C2 } / xC4. Seems it depends on N too. |
| Dec2-12, 08:52 PM | #48 |
Recognitions:
| Dec2-12, 09:03 PM | #49 |
X: number of ASCII bits , from which N is taken. Pr[0] = 9/16. xC7 : The number of combinations of x , taken 7 at a time. |
| Dec2-12, 09:11 PM | #50 |
Recognitions:
| Dec2-12, 09:54 PM | #51 |
Pr[0] = 9/16. X: number of ASCII bits , from which N is taken. case: N1=7 & N2=4 . Assume N is taken from X bits, which is ASCII. Other definitions should be clear |
| New Reply |
| Thread Tools | |
Similar Threads for: Probability of 0 bit in ASCII text files
| Thread | Forum | Replies | ||
| How read text files on CASIO fx-9860GII SD? | Calculators | 2 | ||
| several ascii files, read, write, average? | Programming & Comp Sci | 5 | ||
| Read multiple binary files to ascii | Programming & Comp Sci | 0 | ||
| Fortran 90 question about reading files with text | Programming & Comp Sci | 1 | ||
| indexing a lot of text/pdf files | Computing & Technology | 1 | ||
