| Thread Closed |
limit : alternate defination |
Share Thread | Thread Tools |
| Nov27-12, 09:55 PM | #1 |
1. this is my attempt to redefine limits in such a way that it remove's following problems. for only defination skip to point 7. 2. limit textbook defination : assuming f(c) is not defined . lim (f(x)) at c is deduced by taking value of x as close to c as possible but not c. 3. the problem 1: 'as close to as possible', what does that even mean ? how much close is possible ? how do you determine that ? is x + ((x-c)/2) close enough ? the inclusion of the term 'possible' without defining what does it mean mathematically is annoying . why would even we used used the word 'possible' ? it seems like the statement ask how much one is capable of getting x close ? so overall i hate 'possible' and the aim of this post is to remove that 'possible' . 4. the problem 2: since i dont know which when is closest, i dont know when i am wrong . since the only way to prove i am right is to prove that i cannot be wrong, so i dont know if i am right. lets say f(c) = 0/0 but lim (f(c)) = L , then according to current limit defination nothing => [ [ b =/= L] => [ lim f(c) =/= b ] ] 5. there are variables (x), when they change from one value (x_1) to another value (x_2), they go through all the value between x_1 and x_2. they dont skip a value. for example speed (s) of a ball when increases from s_1 to s_2 then s takes all values in real subset [s_1,s_2]. lets call such variable natural_variable . 6. lets define a variable y = ((x^2) - (a^2))/(x-a) AND domain_x = R . but turns out y(a) = 0/0 . however it is not a problem or contradiction or paradox . but you cant say [ y is natural_variable ] which is a problem because natural_variables are to be studied . or in other word y has to be a natural_variable or to be made into one. so to solve this we need to make sure, i. nothing implies f(a) = 0/0 ii. assign a value to f(a) , otherwise it would still be a non natural_variable. 7. limit, alternate defination : assign lim (f(x)) at c in such a way that for every x f takes all value between f(x) and ( lim f(x) at c ) within x and c. 8. limit, alternate def - mathematical version : [ lim f(x) at c = L ] <=> [ for all x in domain_x, domain_y_x n R = domain_y_x, where domain_y_x is set of all values of f(x) between x and c ] NOTE: i. n is set intersection sign ii. examples of domain_y_x domain_y_1 for c = 2: x_i belongs to [1,2] => (domain_y_1 for c equals 2) = {f(x_1), f(x_2), ... , f(x_n-1), L} domain_y_1 for c = 0 x_i belongs to [0,1] => (domain_y_1 for c equals 0) = {f(x_1), f(x_2), ... , f(x_n-1), L} 9. so new_lim proves why we cannot assign lim f(x) at a = 1 if f(x) = ((x^2) - (a^2))/(x-a) . because f(x) is not equal to 1/2 between 0 and 1 -a but should have because f(0) > 1/2 > f(1-a). so here it is. the redefination serves its purpose. i hope it helps anyone having those problems. any comment/contradiction is welcome. |
| Nov27-12, 10:12 PM | #2 |
Welcome to Physics Forums. I recommend you install a spell checker in your browser.
You claim to redefine the concept of "limit of a function". I implore you to reread (and understand) the actual definition first, because none of your criticisms from points 3 & 4 apply. |
| Nov28-12, 07:42 AM | #3 |
"but should have because"- "should have" what? (And, by the way, you are consistently mis-spelling "definition".) |
| Nov28-12, 08:28 AM | #4 |
Mentor
limit : alternate definationHere's a definition that's equivalent to the epsilon-delta definition: Let c be any number such that every open interval that contains c also contains a member of the domain of f. f is said to have a limit at c if there's a number y such that for every open interval A that contains y, there's an open interval B that contains c and is such that f(B) is a subset of A. The number y is called "the limit of f(x) as x goes to c" and is denoted by ##\lim_{x\to c} f(x)##. Here f(B) denotes the set of all f(x) such that x is in B. |
| Nov29-12, 12:09 AM | #5 |
[ [ for all open interval A [ y belongs to A ] => [ for at least one open interval B [ c belongs to B ] AND [b_i belongs to B] AND [ f(B) = {f(b_1),f(b_2), ... , f(b_n)} ] AND [ {f(b_1),f(b_2), ... , f(b_n)} is subset of A ] ] ] => [ lim f(x) as x goes to c is y ] ] ... [1] so lets prove [ lim f(x) as x goes to c is y_0 ] assuming [ [ lim f(x) as x goes to c is y ] AND [y =/= y_0] ] but statement [1] will help us do that provided we prove [ for all open interval A => [ for at least one open interval B [ c belongs to B ] AND [b_i belongs to B] AND [ f(B) = {f(b_1),f(b_2), ... , f(b_n)} ] AND [ {f(b_1),f(b_2), ... , f(b_n)} is subset of A ] ] ] -> prove [ for at least one open interval B [ c belongs to B ] AND [ {f(b_1),f(b_2), ... , f(b_n)} is subset of A ] ] assuming [ [ y_0 belongs to A ] AND [b_i belongs to B] AND [ f(B) = {f(b_1),f(b_2), ... , f(b_n)} ] ] {f(b_1),f(b_2), ... , f(b_n)} is not an interval because [ [{f(b_1),f(b_2), ... , y , ... , f(b_n)} is interval ] AND [ y =/= y+0 ] ] => [ {f(b_1),f(b_2), ... , y_0 , ... , f(b_n)} is not interval ] in other words you cant prove [ {f(b_1),f(b_2), ... , y_0 , ... , f(b_n)} i interval ] -> so you cant prove the original statement [ lim f(x) as x goes to c is y_0 ]. this solves : the problem 1 because it does not rely on phrases like "as goes to" , "as approaches to" or "as close to as we like" or "as close as possible" ( and at least 3 out 4 of them has been used multiple times in , stewart calculus 5e) , and the problem 2 , it says why you cant prove otherwise . i think its equivalent to what i said . however it be good if i come across this definition earlier. ------------- For every real ε > 0, there exists a real δ > 0 such that for all real x, 0 < | x − p | < δ implies | f(x) − L | < ε it will still be correct if i replace L with L_wrong. For every real ε > 0, there exists a real δ > 0 such that for all real x, 0 < | x − p | < δ implies | f(x) − L_wrong | < ε so it does not solve problem 2 mentioned in point 4. in other words, i need an definition/statement/algorithm which would either tell me 1. why L is correct limit ? or/and 2. why L_wrong is wrong limit ? ------------- or in other words, f(c) is not defined means (0/0 , infi/infi etc ), limit is what i said above ("textbook definition") . and if f(c) is defined then limit is what you would usually do following usual operations. ------------- "f(x)= g(x)/h(x) and consider cases where g(x)-> 0 and h(x)-> 0" however/so i can use this too. i think its matter of syntax. ------------ ------------ i took the safe route and define it something else. however i am not saying [ x is natural_variable ] => [ x is not continuous variable ] but in future i might say [x is natural variable ] <=> [ x is continuous variable ] . ------------- ------------- ------------- domain_y is the set of variables that we get from f after we put every variable in domain_x into f. [ domain_y is real interval ] <=> [ y is natural_variable/continuous_variable ] the aim of the limit is to keep the domain_y a real interval. domain_y_x is the set of {f(x_1),f(x_2) , ... , f(x_n)} where x_i belongs to the real interval taking x and L as endpoints. [ for all x in domain_x, [ domain_y_x n R = domain_y_x ] ] since A n R = A <=> A is real interval.so above is equivalent to [ for all x in domain_x [ domain_y_x is real interval ] ] equivalent to [ [domain_y_(x_1) is real interval ] AND [domain_y_(x_2) is real interval ] AND ... AND [domain_y_(x_n) is real interval ] ] assuming domain_x = {x_1,x_2, ... , x_n} so [ [ lim f(x) at c = L ] AND [ domain_x = {x_1,x_2, ... , x_n} ] ] <=> [ [domain_y_(x_1) is real interval ] AND [domain_y_(x_2) is real interval ] AND ... AND [domain_y_(x_n) is real interval ] ] so if you could prove this [ [domain_y_(x_1) is real interval ] AND [domain_y_(x_2) is real interval ] AND ... AND [domain_y_(x_n) is real interval ] ] then if you could prove for a L then L is limit. -------------- 9. So new_lim proves why we cannot assign lim f(x) at a if f(x) = ((x^2) - (a^2))/(x-a) to a/2. because then we cant prove [ domain_y_0 is a real interval ] ------------- "as close to we like " "as close to a number as we like " "as close to as we please" "as approaches to" "taking a number sufficiently close" "a->b" "by taking a small number" # there "by taking a large number" # that i know right that is at least used in books like stewart 5e, wikipedia , marsden calculus 1e . there reference is not just limited to calculus. the real problem any statement that have these phrases are 'useless' statements, they prove anything true or false. ------------ nor am i trying to start a new calculus like a religion . i am just trying to deduce a equivalent statement that solves the problems , since i think have, i am here for a peer review . ------------- ------------- |
| Nov29-12, 12:49 AM | #6 |
Mentor
1. When you mention b_i the first time, you haven't defined it. 2. f(B) is usually not finite, so the notation f(B) = {f(b_1),f(b_2), ... , f(b_n)} is inappropriate. You can however write f(B)={f(x)|x is in B}. I don't think your computer code style makes it easier to understand the statement, but I'll show you a way to rewrite it. [ [ for all open interval A [ y belongs to A ] => [ for at least one open interval B [ c belongs to B ] AND [for all b that belongs to B [f(b) belongs to A]] ] ] <=> [ lim f(x) as x goes to c is y ] ] ... [1] Suppose (to obtain a contradiction) that f(x) has two limits y and z (with y≠z) as x goes to c. Let A be an arbitrary interval that contains y but not z. (Such an interval exists, since we can define ε=|z-y|/2, and take A=(y-ε,y+ε)). Let B be an interval that contains c and is such that f(B) is a subset of A. (Such an interval must exist since we have assumed that f(x)→y as x→c). Now let A' be an arbitrary interval that contains z and is disjoint from A. Now there is clearly no interval B' that contains c and is such that f(B') is a subset of A', because every interval B' that contains c will also contain members of B, and f takes them to members of f(B), which is a subset of A, which is disjoint from A'. This contradicts the assumption that f(x)→z as x→c. I recommend that you try to prove that the epsilon-delta definition also ensures that limits are unique. Since that definition is very similar to mine, the proof will be very similar to mine. |
| Nov29-12, 02:08 AM | #7 |
| Nov29-12, 02:16 AM | #8 |
2. We can prove: if Lwrong also satisfies the property, then L = Lwrong. Edit: |
| Nov29-12, 05:29 PM | #9 |
| Nov29-12, 06:24 PM | #10 |
Mentor
If this is the result of "more fundamental assumptions" then those assumptions are not valid and should be thrown out. Further, you have something pretty incomprehensible; namely |
| Nov30-12, 07:24 AM | #11 |
when i read for this version of epsilon delta definition
[ for all x [ δi is the ith element of set (0,∞) ] AND [ εi is the ith element of set (0,∞) ] AND [ [ 0 < |x - a| < δ1 ⇒ |f(x) - L| < ε1 ] OR [ 0 < |x - a| < δ2 ⇒ |f(x) - L| < ε1 ] OR ... OR [ 0 < |x - a| < δ∞ ⇒ |f(x) - L| < ε1 ] ] AND [ [ 0 < |x - a| < δ1 ⇒ |f(x) - L| < ε2 ] OR [ 0 < |x - a| < δ2 ⇒ |f(x) - L| < ε2 ] OR ... OR [ 0 < |x - a| < δ∞ ⇒ |f(x) - L| < ε2 ] ] AND ... [ [ 0 < |x - a| < δ1 ⇒ |f(x) - L| < ε∞ ] OR [ 0 < |x - a| < δ2 ⇒ |f(x) - L| < ε∞ ] OR ... OR [ 0 < |x - a| < δ∞ ⇒ |f(x) - L| < ε∞ ] ] ] => [ limx->af(x)=L] and i am sure ( still i have to prove though but first please tell me if this form is actually the epsilon delta limit ) that it proves L1 and L2 is limit for same funtion at same number, even if L1 ≠ L2. however if i read this [ for all ε < 0, for at least one δ < 0 f([a-δ,a+δ]) ⊂ [L-ε,L+ε] ] or [ for all ε < 0, for at least one δ < 0 f([a-δ,a+δ]) ⊂ f([f-1(L-ε),f-1(L+ε)]) ] assuming f-1(L-ε) and f-1(L-ε) is unique but since [ for all ε < 0, for at least one δ < 0 f([a-δ,a+δ]) ⊂ f([f-1(L-ε),f-1L+ε]) ] is always true irrespective of L which means it can prove two different limit for same function at same number. so i am going with [ for all ε < 0, for at least one δ < 0 f([a-δ,a+δ]) ⊂ [L-ε,L+ε] ] which basically says f([a-δ,a+δ]) has to be a real interval otherwise limit is wrong which is what i said, "lim f(x) at a can be anything you have to make sure that f range remains/becomes a real interval" or more formally [ f(domainf) ⊂ R ] assuming f has only one hole (undefined value) and [ for at least one δ < 0 f([a-δ,a+δ]) ⊂ R ] assuming f has any number of hole and i think its better and more easy to translate in to what we are trying to achieve. 2. i mean , f(B)={f(x) | x is in B } f takes them to members of f(B) ? [ lim x/x at 0 is 1 and lim (x^2-x^1)/(x-1) at 1 is 2 and ... ] . because i already said i am not trying to break down the whole calculus . but if you believe [the deduction ⇔ [ lim x/x at 0 is 1 and lim (x^2-x^1)/(x-1) at 1 is 2 and ... ] ] and [ epsilon-delta ⇔[ lim x/x at 0 is 1 and lim (x^2-x^1)/(x-1) at 1 is 2 and ... ] ] and [ [ [ statementA ⇔ statementB] AND [ statementA ⇔ statementC ] ] ⇒ [ statementB ⇔ statementC] ] then [ the deduction ⇔ epsilon delta ] . or better forget i said f(c) = 0/0 , instead i say f(c) is undefined and thats is only what i meant actually as you can see i have not used f(c) = 0/0 anywhere else . what i meant by [ [ b =/= L] => [ lim f(c) =/= b ]] is [ [ [ b =/= L ] and [ lim f(x) at c = L] ] => [ lim f(x) at c =/= b ]] however this is always true. which is why you might thought is meaningless. however what i actually wanted to say is [ replacing_statement => lim f(x) at c = L ] and [ L =/= Lwrong ] and [ replacing_statement =/> lim f(x) at c = Lwrong ] |
| Nov30-12, 08:23 AM | #12 |
Mentor
The set of rational numbers is countable, but the set of real numbers is not. An interval of real numbers is not countable. In general, if f is a function and x is a member of the domain of f, then f(x) is called the value of f at x, and it's common to say that f takes x to f(x). That's how I use the word "takes". For example, the function ##f:\mathbb R\to\mathbb R## defined by ##f(x)=x^2## can be described as "the function that takes every real number to its square". In particular, it takes 3 to 9. Edit: It's probably just confusing for you to have to look at two different definitions, so I suggest that you focus on the epsilon-delta definition for now. If you want to discuss my definition or other equivalent definitions, I suggest that we do it after you have understood the epsilon-delta definition. |
| Nov30-12, 08:53 AM | #13 |
Mentor
Since you really seem to want to see the definition of "f(x)→L as x→a" in computer code style...
Code:
For all ε
if ε>0 then there's a δ such that
δ>0
and
for all x [ if 0 < |x − a | < δ then |f(x)-L| < ε ]
| Nov30-12, 09:05 AM | #14 |
| Nov30-12, 09:41 AM | #15 |
in this statement [ [ 0 < |x - a| < δ1 ⇒ |f(x) - L| < ε1 ] OR [ 0 < |x - a| < δ2 ⇒ |f(x) - L| < ε1 ] OR ... OR [ 0 < |x - a| < δ∞ ⇒ |f(x) - L| < ε1 ] ] or even more better ( hoping that it would priotize your response better ) ignore this whole statement in the previous post [ for all x [ δi is the ith element of set (0,∞) ] AND [ εi is the ith element of set (0,∞) ] AND [ [ 0 < |x - a| < δ1 ⇒ |f(x) - L| < ε1 ] OR [ 0 < |x - a| < δ2 ⇒ |f(x) - L| < ε1 ] OR ... OR [ 0 < |x - a| < δ∞ ⇒ |f(x) - L| < ε1 ] ] AND [ [ 0 < |x - a| < δ1 ⇒ |f(x) - L| < ε2 ] OR [ 0 < |x - a| < δ2 ⇒ |f(x) - L| < ε2 ] OR ... OR [ 0 < |x - a| < δ∞ ⇒ |f(x) - L| < ε2 ] ] AND ... [ [ 0 < |x - a| < δ1 ⇒ |f(x) - L| < ε∞ ] OR [ 0 < |x - a| < δ2 ⇒ |f(x) - L| < ε∞ ] OR ... OR [ 0 < |x - a| < δ∞ ⇒ |f(x) - L| < ε∞ ] ] ] => [ limx->af(x)=L] 1. using AND,OR comes under logic. it helps to say what we want say to in more flexible form . 2. using square brackets are needed to show exactly which statements are joined by AND OR => because A => B AND C could either be misunderstood as A => [B AND C] or [ A => B ] AND C i never said [ epsilon-delta ⇔[ lim x/x at 0 is 1 and lim (x^2-x^1)/(x-1) at 1 is 2 and ... ] ] is true. i said if you think it is true. |
| Nov30-12, 10:15 AM | #16 |
to generalize following statement [ lim x/x at 0 is 1 and lim (x^2-x^1)/(x-1) at 1 is 2 and ... ] [IGNORE] please ignore this in my previous post its not what i wanted to say. [ f(domainf) ⊂ R ] assuming f has only one hole (undefined value) and [ for at least one δ > 0 f([a-δ,a+δ]) ⊂ R ] assuming f has any number of hole [/IGNORE] |
| Nov30-12, 10:59 AM | #17 |
Mentor
| Thread Closed |
| Thread Tools | |
Similar Threads for: limit : alternate defination
| Thread | Forum | Replies | ||
| Defination of E D and P fields | Classical Physics | 15 | ||
| Percise defination of the limit of a sequence problem | Calculus & Beyond Homework | 1 | ||
| plz tell me defination | Linear & Abstract Algebra | 3 | ||
| stress concentration sensitivity definition | Engineering, Comp Sci, & Technology Homework | 1 | ||
| What is the definition of 1 meter? | General Physics | 10 | ||
