What is going on inside my magnets?
  • Context: Graduate
  • Thread starter Thread starter RobBer5
    Magnets
The discussion revolves around the behavior of magnetic fields in relation to the grinding of permanent magnets, particularly in the context of creating a diamagnetic levitation system for manipulating microdroplets. Participants explore the implications of changing the size and shape of magnets on their magnetic field strength and the resulting effects on a proposed experimental setup.
  • Experimental/applied
  • One participant notes a minimal change in magnetic field strength after grinding a magnet, suggesting a potential connection to magnetic domains.
  • Another participant questions the assumption that grinding down the magnet would necessarily weaken it, proposing that the arrangement of magnets affects field strength.
  • A participant explains the intended mechanism of diamagnetic levitation, emphasizing the importance of the magnetic field gradient created by the orientation of the magnets.
  • There is a suggestion that the grinding process may not significantly alter the field strength, particularly if the magnets are resized radially rather than vertically.
  • One participant requests data on the relationship between magnet mass and field strength, indicating uncertainty about how shape affects field propagation.
Participants express differing views on the effects of grinding on magnetic field strength and the mechanisms behind diamagnetic levitation. There is no consensus on the implications of these observations or the expected outcomes of the grinding process.
Participants have not reached a conclusion regarding the specific effects of grinding on magnetic field strength, and assumptions about the relationship between magnet size, shape, and field strength remain unresolved.
RobBer5
Hi All,
I'm currently trying to make a diamagnetic levitation system for manipulating microdroplets for my Ph.D. As I was carefully grinding down my magnets to an appropriate size I noticed that the strength of the field didn't change that much. One magnet before the grinding produced a maximum magnitude of ~0.46T and after grinding the field on the same side produced a maximum magnitude of ~0.45T! I measured the field with a Teslameter and ground down the magnets using a file and ethanol for cooling.
Can anyone explain this to me (I'm only a self-taught physicist)? I'm thinking it's something to do with the magnetic domains...
Thanks
You are self taught and doing a PhD?!
Way to go!
Have you told your supervisor about what is happening to your magnets?
Anyway - you are thinking, I imagine, that if you join two small magnets together you should get one magnet of greater strength - so grinding them down should weaken them?
Conceptually: sketch the field lines for two equal strength bar magnets lined up like so:
[N1S][N2S]
... all the lines from the N of 1 go into the S of 2, and all the lines from the N of 2 go into the S of 1. So what happens to the magnet strength close to the poles of the combined magnet compared with the separated magnets?
You know how permanent magnets work right?
Thank you for replying, and yes I know how permanent magnets work. Although it doesn't really answer my question, since I was talking about a single magnet before and after grinding.
I really should have explained about how diamagnetic levitation works (at least how it should work in my case) to save time:
The magnetization of the permanent magnets will be directed in-plane and opposite in direction to each other:
[S1N] [N2S]
The idea is to produce a large field gradient between the magnets. When a diamagnetic droplet/particle comes into a contact with the field it produces a small induced magnetic moment directed opposite to the magnetic field. Using strong enough magnets, the interaction of this moment with the magnetic field gradient provides the force which levitates the droplet/particle. Due to the orientation of the magnets the minimum should lie along a line between the magnets.
Excuse me: I thought the grinding was just to resize the magnets ... if you made them smaller radially I'd expect a decrease in strength near the poles but not smaller vertically.
Grinding is the action of cutting magnets into lots of smaller bits ... and one big bit.
The simplification for illustration purposes is just slicing the magnet in half to get two equal strength magnets.
Isn't the field gradient supposed to be created by the fact you are shoving like-poles together? i.e. not by shaping the magnets? What did you expect the grinding to do to the field? (i.e. what is it you want explained?)
Do you have some reliable data on field strength variance with mass of the magnet? Shape of the final ground magnet would probably have little effect other than affecting field propagation. How or how much I denna ken.
The above are the WAGs of yet another self-taught physicist.
Best of Luck,
Rob
  • · Replies 22 ·
