Register to reply
Temperature Concept?
by M. next
Tags: concept, temperature
Share this thread:
M. next
#1
Dec6-12, 08:06 AM
P: 378
what is the difference between emperical and thermodynamic temperature?
Phys.Org News Partner Physics news on Phys.org
Refocusing research into high-temperature superconductors
Neutron tomography technique reveals phase fractions of crystalline materials in 3-dimensions
Tiny magnets, huge fields: Nanoscale ferromagnetic electrodes create chemical equivalent of solid-state spin valve
Philip Wood
#2
Dec6-12, 09:24 AM
PF Gold
P: 944
An empirical temperature is defined as linearly related to some specific property of a substance or system, such as its electrical resistance. So if we had a copper resistance thermometer and a platinum resistance thermometer and calibrated them at the ice and steam point, there'd be no reason to expect them to give exactly the same reading at some intermediate temperature.
Thermodynamic temperature is based, not on the property of a particular substance, but upon the universally applicable Second Law of Thermodynamics. To measure temperatures on this scale we have to have a theory which links readings (on say a gas thermometer) to the thermodynamic scale. It turns out that for gases at very low densities, the thermodynamic temperature ratio is close to the ratio of gas pressures.
Philip Wood
#3
Dec8-12, 12:05 PM
PF Gold
P: 944
M. next: Was this reply of any help? Does it need clarification? If so, where specifically?
M. next
#4
Dec9-12, 04:52 AM
P: 378
Thank you Philip. It is perfectly illustrated, I understood it.
Register to reply
Related Discussions
Pressure and Temperature - Quick Concept Check Introductory Physics Homework 4
Energy required for temperature raise - temperature-dependent specific heat capacity Advanced Physics Homework 3
Energy required for temperature raise - temperature-dependent specific heat capacity Introductory Physics Homework 1
Is The Concept Time Elapsed= Validity A Valid Concept? General Discussion 0
