New Reply
Natural Vibration of Beam - Algebraic Query
Share Thread Thread Tools
Dec7-12, 04:16 PM   #1
Folks,
Just wondering what the author is doing here, given
##\displaystyle \left (\frac{2EI}{L^3} \begin {bmatrix} 6&3L\\3L&2L^2 \end {bmatrix} -\omega^2 \frac{\rho A L}{420} \begin {bmatrix} 156&22L\\22L&4L^2 \end{bmatrix} \begin {bmatrix} W\\ \theta \end {bmatrix} \right )=\begin {bmatrix} 0\\ 0 \end {bmatrix}##
He proceeds to set the determinant of the matrix above to 0 to obtain a quadratic characteristic equation in ##\omega^2##
The equation being
##15120-1224 \lambda + \lambda^2=0##, where ##\displaystyle \lambda=\frac{\rho A L^4}{EI} \omega^2##
Using wolfram http://www.wolframalpha.com/input/?i...%7D%7D%29+%3D0 (Z=EI)
I dont see how he arrives at this quadratic expression or how he determined ##\lambda## ...thanks
PhysOrg.com
PhysOrg
mathematics news on PhysOrg.com
>> Mathematicians analyze social divisions using cell phone data
>> Can math models of gaming strategies be used to detect terrorism networks?
>> Mathematician proves there are infinitely many pairs of prime numbers less than 70 million units apart
Dec7-12, 04:27 PM   #2
Quote by bugatti79 View Post
Folks,
The equation being
Ah, I have it. The first equation in the alternative form in wolfram gives the clue.
Dec8-12, 11:33 AM   #3
Folks,
The equation being
Why do we have ##\displaystyle \lambda=\frac{\rho A L^4}{EI} \omega^2##? Why isn't it some other combination of units? In other words, what should the units of lambda be?
If we do a units balance on this to which I calculate
##\displaystyle\frac{\frac{kg}{m^4}m^2m^4 }{\frac{\frac{kgm}{s^2}}{m^2}m^4}\frac{rad^2}{s^2}=\frac{rad^2}{m}## where ##\rho## is the mass density per metre...thanks
Dec8-12, 12:38 PM   #4
Recognitions:
Homework Helper Homework Help
##\lambda## should be dimensionless. You can tell because the quadratic equation involves different powers of ##\lambda##, so it can't have dimensions.
Are you sure that ##\rho## is a linear mass density? It looks like it should be kg/m3.
Also, keep in mind that "radians" are dimensionless units (they have dimensions of length/length).
Dec8-12, 01:06 PM   #5
Quote by Mute View Post
Not sure I understand this. For example on a slight tangent of topic if we consider a 1 dimensional bar element whose interpolation function is a quadratic in x which is the distance along the bar in metres...
##u_h^e(x)=c_1+c_2x+c_3x^2## This is not dimensionless...
Well this problem stems from the Euler-Bernoulli Beam Theory and the book states that ##\rho## is "mass density per unit length" so isnt that kg.m^3/m=kg/m^4?...
Dec8-12, 01:12 PM   #6
Ah, I think I know what you mean. The LHS of above is not 0 so dimensions are allowed.
Its when an equation is set to 0 with different powers of ##\lambda## like you say, that they must be dimensionless, right..........?
thanks
Dec8-12, 03:44 PM   #7
Math 2012
Recognitions:
Agreed, since the mass of the beam appears to be ##\rho A L## in your matrix equation.
##\omega## is the angular frequency in radians/secons, not an angle in radians.
Dec8-12, 04:05 PM   #8
Recognitions:
The difference with this example is that your coefficients ##c_i## each have different units to compensate for the units of the different powers of x.
In the quadratic for ##\lambda##, you assigned no numbers to the numerical coefficients, and since you were following a book that appears to have left all dimensionful quantities as variables, I assumed those coefficients were dimensionless. Are the coefficients supposed to have units?
The book says that word-for-word? That is a very confusing statement. One usually says "mass per unit length" or "mass per unit volume", but I have not heard "mass density per unit length". I think it must be a typo or something. Even if we were to take that at face value, is the density a linear density or a volumetric density?
Quote by AlephZero View Post
Yes, I was not referring to the angular frequency as a whole, only the factor of radians that remained in bugatti79's calculation, so I mentioned that radians are actually dimensionless.
Dec9-12, 02:05 PM   #9
Not sure I understand what you are saying about the numerical coefficients? The coefficients of ##\lambda## and ##\lambda^2## are -1224 and 1 respectively, right?
Yes. That is all the book says as above. So perhaps it is a typo....
I have never heard of a volumetric density...
New Reply
Thread Tools
Similar Threads for: Natural Vibration of Beam - Algebraic Query
Thread Forum Replies
Natural Vibration of Beam - PDE Differential Equations 5
ALgebraic Topology Query (Hatcher) - Not Homework Topology and Analysis 3
[Vibration analysis] Timoskenko beam Vs.Euler-bernoulli beam ? Mechanical Engineering 2
natural vibration General Physics 1
