PeterDonis
Mentor
- 50,142
- 26,173
PAllen said:Actually, what I proposed would reverse the K-S time ordering for arrival events for the 'right half' K-S diagram, while leaving them unchanged for the left half.
Yes, I see that, but the time ordering I was referring to, that imposed by the ingoing null worldlines that hit the singularity, is *not* the same as the K-S time ordering for events on the singularity. In the K-S time ordering, one particular event on the singularity, the one at X = 0 (or U = 0, depending on how you label the horizontal coordinate), has the earliest Kruskal time, and Kruskal time increases going to the left *and* to the right along the singularity. The time ordering I was referring to a is monotonic ordering of events on the singularity: events "to the left" are earlier, and events "to the right" are later. This is the same time ordering as Eddington-Finkelstein time or Painleve time. That is the time ordering that would be reversed on the singularity by starting with surfaces of constant T' horizontal, and then tilting the constant T'' surface up on the right and down on the left.
The reason I'm focusing on this time ordering is that, as should be evident from the fact that it matches E-F time and Painleve time, this is the time ordering of events along any timelike curve in regions I and II of the spacetime. The reason it's different from the K-S time ordering is that the latter time ordering includes curves in all four regions; but regions III and IV are not there in any real case, where a black hole is formed from a collapsing object. So the only curves we need to worry about are those in regions I and II.
Given that, to see the intuition underlying what I said about not being able to reverse the time ordering along the singularity without also reversing it on at least some timelike curve (I said "causal" earlier, but I should have said "timelike"), tilt the K-S diagram 45 degrees counterclockwise, so the "antihorizon" (the past horizon that starts at the lower right and goes up and to the left) is horizontal. Ingoing null rays are now all horizontal lines parallel to the antihorizon, and any timelike curve in regions I and II can be time ordered by the order in which it crosses those null rays, and that time ordering is necessarily the *same* as the natural past to future ordering of proper time along that causal curve. And that time ordering is *also* the same as the "left to right" ordering along the singularity, since that's the order in which the null rays intersect the singularity: the closer the null ray is to the antihorizon, the further to the left it hits the singularity.
Now, look at what surfaces of constant time have to look like in any chart that has the same time ordering as above. These surfaces must be spacelike, as in any chart, and each one must intersect the singularity at the same event as some ingoing null ray. This gives a one-to-one mapping between ingoing null rays and surfaces of constant time, and that mapping relates the ordering of surfaces of constant time to the ordering of ingoing null rays. So any timelike curve in regions I and II must cross the surfaces of constant time in the same order as it crosses the ingoing null rays.
The above seems sufficient to me to show that any chart that reverses the time ordering of events on the singularity, so they go "right to left" instead of "left to right", must also reverse the time ordering along timelike curves in regions I and II.
