New Reply
Predicting temp. at which defects will set in
Share Thread
Dec10-12, 03:01 PM   #1
Hi,
I am calculating surface energies for different kinds of defects in a bulk solid (e.g. twins, anti-phase boundaries, etc.) Let's say I get something like (just making this up) 1.0 meV/Angstrom^2. How would I calculate the temperature at which an appreciable number of said defect would be present in the sample? Classically, you have something like k_B T energy available per mode. But I get confused thinking about what might constitute a mode when talking about surface defects forming in a bulk crystal.
Thanks for suggestions,
Sam
PhysOrg.com physics news on PhysOrg.com
>> Surprising turns in magnetic thin films could lead to better data storage
>> Novel synthesis technique for high efficiency conversion of source gas to diamond
>> Scientists capture crystallization of materials in nanoseconds
Dec10-12, 06:30 PM   #2
Recognitions:
Gold Membership Gold Member
I'm not aware of any statistical mechanical model that gives "equilibrium" number of "extended" defects (anything different than point defects) at a given temperature. Even the word "equilibrium" may not be appropriate here.
New Reply
Similar discussions for: Predicting temp. at which defects will set in
Thread Forum Replies
Temp to raise fluid temp inside a container - Heat transfer & thermodynamics Engineering, Comp Sci, & Technology Homework 7
Calculate refrigerant temp inside evaporator based on exit temp and pressure Classical Physics 0
Difference between Effective Temp and Actual Surface Temp is due to what? Earth 3
Chemistry: 2 samples of the same liquid but different temp - final temp? Biology, Chemistry & Other Homework 9
