Refraction: Reflection after passing the critical angle
When the angle of incidence exceeds the critical angle, light undergoes total internal reflection, which adheres to the normal rules of reflection. This type of reflection is more efficient than that of ordinary mirrors, which can have reflectivity issues due to light absorption and multiple reflections. Mirrors reflect light at both their front glass surface and their backing, leading to potential image quality degradation from multiple reflections. The light that is not reflected is absorbed by the mirror material, contributing to its overall inefficiency. Total internal reflection in prisms avoids these issues, resulting in nearly 100% reflection efficiency.
rishch
If the angle of incidence is greater than the critical angle then it is reflected back into same medium. Is this reflection normal reflection? (as in it obeys all the rules of reflection, like reflection in mirrors) Or is it a bit different?
Science news on Phys.org
And also, in my book, under total reflection prisms, they've given the advantages of total reflection prisms as-
The reflection efficiency is nearly 100% as against an ordinary plane mirror whose reflectivity is poor.
There is is no problem of multiple reflections in the case of prisms while this problem spoils the quality of images in mirrors.
How can a plane mirror have poor reflectivity? What happens to the light that is not reflected? I thought mirrors reflected all the light.
And what do they mean by multiple reflection?
Total internal reflection follows normal reflection rules.
Mirror absorbs a portion of the light. It also reflects both at the front glass surface and the back surface, that's the multiple-reflection problem the book mentions. Light reflected from the back surface might be reflected back into the mirror again by the front surface, and so on. This will contribute to the absorption losses as well.
By front surface you mean the surface of the glass and by back portion you mean the silver reflecting surface on the back right? Oh and what are co axial rays? (Sorry for adding questions every post)
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
