Register to reply
Find the angle of a triangle and x coordinate
by duplaimp
Tags: angle, coordinate, triangle
Share this thread:
duplaimp
#1
Dec29-12, 07:48 AM
P: 33
I have this triangle and I know just the two sides indicated there. How can I find angle theta?
I tried decomposing the triangle in two right triangles and using trigonometry find one side, but I can't figure how to do that using just the hypotenuse
Phys.Org News Partner Mathematics news on Phys.org
Heat distributions help researchers to understand curved space
Professor quantifies how 'one thing leads to another'
Team announces construction of a formal computer-verified proof of the Kepler conjecture
Mentallic
#2
Dec29-12, 07:59 AM
HW Helper
P: 3,540
Quote Quote by duplaimp View Post
There isn't enough information there to solve the problem - unless the bottom length of the triangle is parallel to the x-axis as it looks to be?
If so, there's an angle within the triangle which is also equal to [itex]\theta[/itex] given the property that the two lines are parallel.
duplaimp
#3
Dec29-12, 08:13 AM
P: 33
Quote Quote by Mentallic View Post
Yes, it is parallel. But how can I find that?
And how could I find the unknown side dimension? I would try with [itex]\sqrt{2.80^2 + 7.40^2}[/itex] but it isn't a right triangle
SteamKing
#4
Dec29-12, 09:15 AM
Emeritus
Sci Advisor
HW Helper
Thanks
PF Gold
P: 6,554
There is not enough information to determine the angle theta even if the base of the triangle is parallel to the upper line.
In addition to the lengths of the two sides, you would need to know the length of the third side or one of the angles of the triangle.
Redbelly98
#5
Dec29-12, 09:34 AM
Mentor
Redbelly98's Avatar
P: 12,071
In general: you need to know three of the six variables (3 sides plus 3 angles) commonly used to describe a triangle.
Moreover:
1. Knowing 3 angles is not enough; at least one of the knowns must be a side length.
2. Sometimes 3 knowns is not enough. Knowing 2 sides and their non-included angle can lead to 2 possible solutions, in some cases.
HallsofIvy
#6
Dec29-12, 10:25 AM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 39,565
Given that the lower side is parallel to the x-axis, that angle [itex]\theta[/itex] is the same as the angle in the triangle between the side labeled "7.40" and the side that is not labeled. But, as Redbelly98 said, just knowing the lengths of two sides is not sufficient to determine the triangle.
IF we were given the length of the third side, say, "x", then we could use the "cosine law" [itex]2.8^2= 7.4^2+ x^2- 2(7.4)x cos(\theta)[/itex] and solve that for [itex]\theta[/itex]. But without knowing x, the best we could do is say that
[tex]cos(\theta)= \frac{7.4^2+ x^2- 2.8^2}{2(7.4x)}= \frac{x^2- 6.7056}{14.8x}[/tex]
x must be such that the right side is between -1 and 1, but the angle still depends upon x.
duplaimp
#7
Dec29-12, 02:39 PM
P: 33
I forgot to say that the hypotenuse was determined using the information that it moved 2.80km SW.. so SW is 45 and with that is now possible to find all the other sides. But thanks anyway for the help :)
johnqwertyful
#8
Dec29-12, 06:27 PM
P: 359
Not enough information. You can move the bottom left or right while still maintaining the givens, but have an infinite number of triangles.
Register to reply
Related Discussions
In a Right Triangle you have one angle - how do you find the other? Differential Geometry 2
An angle - why an angle is the ratio of two sides of a triangle? General Math 5
Triangle and dot product to find angle Calculus & Beyond Homework 2
In Triangle EFG find the value of f, if e=7.3cm g=8.7cm and angle E= 73 degrees General Math 1
How to find angle of a curve in xy coordinate plane? General Math 5
