Gravitational time dilation and special relativity time dilation
The discussion revolves around the relationship between gravitational time dilation and special relativity time dilation, exploring their equations and potential connections. Participants examine whether these two forms of time dilation are fundamentally the same or distinct, considering both theoretical implications and interpretations.
  • Some participants note the similarity in the equations for gravitational and special relativity time dilation, questioning how they might be connected.
  • Others argue that the two expressions represent different phenomena, with one relating to clocks at rest in a gravitational field and the other to moving clocks.
  • A participant points out that solving for velocity in the gravitational time dilation equation yields escape velocity, suggesting a potential link, though others caution against equating the two formulas.
  • Some express a desire to unify the concepts of time dilation from both theories, suggesting that increased mass and gravitational potential could warp spacetime similarly.
  • Counterarguments emphasize that time dilation is context-dependent and that the two types of time dilation cannot be considered the same, as they arise from different physical situations.
  • One participant introduces the idea that in certain experiments, both types of time dilation can be observed simultaneously, further complicating the relationship between them.
  • There is a discussion about the coordinate-dependent nature of time dilation, with some suggesting that general statements about it can lead to misunderstandings without clear context.
Participants generally disagree on whether gravitational time dilation and special relativity time dilation are fundamentally the same or separate concepts. Multiple competing views remain, with some advocating for a connection and others firmly stating their distinction.
Participants highlight the importance of context and coordinate systems in discussing time dilation, noting that interpretations can vary significantly based on the frame of reference used.
yakmastermax
Looking at the two equations for time dilation they seem very similar
$$t_{surface} = t_{space} \sqrt{1-\frac{2GM}{rc^2}}$$
$$t_{moving} = t_{observer}\sqrt{1-\frac{v^2}{c^2}}$$
I was hoping someone could explain more how they are connected?
I'd like to think that a fast moving object with β near 1 would begin to feel more massive and inertial. Being more inertial the object would then "slow down" as described by general relativity? Is the special relativity expression an extension of general relativity or are the two separate?
Thanks all!
They aren't. They are expressions for two different things.
They are separate.
If you solve for the velocity though you get the expression for escape velocity.
$$v_e=\sqrt{\frac{2GM}{r}}$$
Forgive me for being stubborn, I'm just trying to connect dots
Yes, that's true, but it doesn't mean the two formulas are different ways of expressing the same thing.
The first formula gives the time dilation of a clock at rest at radius r, relative to a clock at rest at infinity.
The second formula gives the time dilation of a clock moving at speed v, relative to a clock at rest.
Equating the two formulas therefore doesn't really make sense: one formula refers only to clocks at rest, the other requires one clock to be moving. The fact that v = escape velocity comes out is just a coincidence.
No problem, that's what PF is here for!
Thanks all!
There's nothing super-obvious that stands out, except that both expressions are in the form
(time dilation ratio)^2 + (something else)^2 = 1
2GM/c^2r is always positive, so it's reasonable to replace it with a square root.
It's sort of suggestive, but as I say, nothing obvious stands out as far as any more direct relationship.
I guess the conclusion I'm hoping to draw is that the two types of time dilation, one due to a velocity approaching speed of light and the other due to the warping of spacetime near great mass densities are actually the same and that the second, described by general relativity, is in fact exactly that: the general description of time dilation.
I'm also drawing on a statement my prof made; As an object approaches the speed of light it becomes more massive. This increased mass and increased gravitational potential would then warp spacetime and explain both the time dilation and length contraction as described by special theory yes?
Sorry, but this is not a valid conclusion. Even on its face it doesn't seem plausible: things can be moving at velocities approaching the speed of light even in empty space far away from any massive objects.
This way of describing what happens is prone to a *lot* of misinterpretation. See further comments below.
No. An object does not warp spacetime to a greater extent just because it happens to be moving very fast in a particular frame. Warpage of spacetime is frame-invariant. This is a key reason why the statement your prof made is prone to misinterpretation, since it invites the incorrect inference that warpage of spacetime is frame-dependent.
yakmastermax said:
I guess the conclusion I'm hoping to draw is that the two types of time dilation, one due to a velocity approaching speed of light and the other due to the warping of spacetime near great mass densities are actually the same and that the second, described by general relativity, is in fact exactly that: the general description of time dilation...
Note that there are experiments where both types of time dilation show up simultaneously (e.g. Hafele-Keating and GPS satellites). The total time dilation is found to be the sum of the two effects (gravitational time dilation is -ve (i.e. a speeding up) compared to Earth clocks, whereas velocity time dilation is +ve (i.e. a slowing down)). Therefore, they cannot be the same thing.
My $.02.
While the two certainly are not the same, they are closely related. But related does not mean "the same" of course.
So while I agree with Peter's criticisms in fine detail, on a broader view I think a diffent point needs to be made.
For instance, if one analyzes an accelerating elevator in an inertial frame, and considers a signal sent from the top to the bottom, one finds a velocity dependent doppler shift between the top and bottom of the elevator, due to the transit time.
But one doesn't find any "time dilation" per se, just a doppler shift.
Applying one of the common variants of the principle of equivalence in an accelerating frame, though, one re-interprets the doppler shift as "gravitational time dilation" due to to the pseudo-gravitational field.
I'm not sure how to word this clearly and informally, but basically because "time dilation" is a coordinate dependent concept, it's only possible to clearly say things about it if one talks in great detail about the specific coordinates being used.
The above example clearly (I hope) serves as a specific example of the slipperyness of the concept of time dilation. It's there for one observer, and not for another.
It's very hard to make accurate general statements about time dilation (or any other coordinate dependent concept) at all, because of it's coordinate dependent nature. One runs the common risk of making the statement thinking about it in one specific context which includes a set of coordinates, and then someone else reads it and has in mind a different context, a different set of coordinates, in which the statement is no longer true.
The way round this is pedestrian, and involves explaining the specific context and coordinates used. One still runs the risk of the result being over-generalized . So, let me put in a gratuitous plug for coordinate independence.
It's at best inefficeint to think about physics in terms that dependent on a specific choice of coordinates (like time dilation), because one has to re-invent the wheel everytime one changes coordinates.
Coordinate independent methods are a much better approach - they're easier to talk about accurately, and one doesn't get stuck trying to re-invent the wheel so often.
Yes you could say you use the principle of the aequivalent inertial frame and compute the Lorentz factor but there is a mix up : your escape velocity is classical and you put in a relativistic formula. You should use Ekinetic_relativistic equals Epotential. With Ekinetic_relativistic equals mc*c*(1/sqrt(1-v*v/c*c)-1)
  • · Replies 79 ·
  • · Replies 54 ·
  • · Replies 27 ·
  • · Replies 103 ·
