| New Reply |
calculate the change of volume from volume expansion coefficient |
Share Thread |
| Jan2-13, 08:05 AM | #1 |
β= (1/v)(∂v/∂T)constant pressure.
What is the v represent? molar volume? If I am given the β and the change of temperature, how to calculate the change of volume? or it is not enough information to calculate it? Thank you. |
| Jan2-13, 08:52 AM | #2 |
it seems like you have enough if the change is relatively small so that you could use deltas:
beta * delta T * V =delta V You'd have to decide on what relatively small means and you have to know what V is. |
| Jan2-13, 09:15 AM | #3 |
Thank you
Question : a container is filled with mercury at 0 degree Celcius. At temperature 50 degree Celcius , what is the volume of mercury that will spill out ? β Of mercury is 18*10^(-5) /Celcius Is this possible to do ? |
| Jan2-13, 10:20 AM | #4 |
calculate the change of volume from volume expansion coefficientWhat is the initial volume? |
| Jan2-13, 05:50 PM | #5 |
The initial volume is not given , so that question can't be solved?
| Jan2-13, 08:14 PM | #6 |
[tex]\frac{d\ln{v}}{dt}=\beta[/tex] Integrating, you get: [tex]v=v_0\exp(\beta(T - T_0))[/tex] where v0 is the volume at temperature T0. |
| New Reply |
Similar discussions for: calculate the change of volume from volume expansion coefficient
| Thread | Forum | Replies | ||
| Please Help! Coefficient of Volume Expansion Question | Introductory Physics Homework | 0 | ||
| Temperature Change and Volume Expansion | Introductory Physics Homework | 3 | ||
| Proving coefficient of volume expansion | Introductory Physics Homework | 2 | ||
| volume expansion problem...wheres initial volume? | Introductory Physics Homework | 2 | ||
| volume expansion and pressure change | Introductory Physics Homework | 8 | ||
