Equilibrium for diffusion of gases in metals
The discussion revolves around the diffusion of gases, specifically hydrogen, in metals and the potential for hydrogen to move from one metal (hydrogen-permeated) to another (hydrogen-free) when they are in contact. Participants explore the concept of equilibrium in this context, drawing parallels to biological processes like osmosis.
  • One participant suggests that hydrogen could diffuse into titanium from another metal, questioning whether an equilibrium would be reached similar to osmosis.
  • Another participant agrees with the initial premise, referencing diffusion processes in semiconductors and noting the need for good contact between the metals to facilitate diffusion.
  • A different participant asserts that there is indeed a driving force for hydrogen diffusion, even in the absence of a direct contact medium, but acknowledges that kinetics may limit the rate of diffusion.
  • One participant emphasizes that specific conditions, such as temperature and contact between the metals, are necessary for the reaction between titanium and hydrogen to occur, indicating that the process is diffusion-controlled.
Participants express varying views on the conditions necessary for diffusion and the driving forces involved. While some agree on the potential for hydrogen to diffuse into titanium, there is no consensus on the specifics of the process or the necessary conditions for equilibrium to be reached.
Participants mention the importance of contact between the metals and specific temperature conditions for reactions, indicating that the discussion is limited by these factors and the kinetics of diffusion.
hannaha
Hi there,
This could be absolute nonsense but I just got thinking about this. Say you had a certain metal into which a quantity of hydrogen had diffused, and then you placed it in communication with another hydrogen-free metal (say, titanium), would it be possible that the hydrogen would move into the titanium metal, out of the other metal? Coming from a a biology background I was thinking about osmosis (well, any concentration gradient-type process) - does the same apply to gases in metals i.e. would an equilibrium be reached? Or is there no driving force created by the "empty" metal?
Any ideas would be appreciated, thanks!
I understand it just as you suggest, and this is backed by diffusion processes in semiconductors. Not just for hydrogen, but as well for dopants.
You need an excellent contact between the solids so (1) the diffusing species don't need to pass through air in between (2) hydrogen doesn't go away through the slit.
Also interesting: solids have some affinity for the diffusing species, so the equilibrium between contacting solids is not at identical concentrations.
there is a driving force indeed. there is a driving force even for a hydrogen permeated metal in empty space. its just the kinetics that's a problem.
if you weld 2 alloys together, even the alloys start diffusing into one another; however, it may be extremely slow.
there are certain conditions that needs to be fulfilled for a specific reaction to occur. for example for titanium and hydrogen the start of reaction takes place at 300 C. and for the reaction to occur the there must be a contact between the metals in your case. and it will be diffusion controlled process.
i hope it will help u to some extent
  • · Replies 24 ·
