Micro USB OTG Cable: Can I Use a Female-to-Female Adapter?
  • Thread starter Thread starter trollcast
    Cables Micro Usb
The discussion confirms that to connect USB devices to a tablet, a Micro USB OTG (On-The-Go) cable is essential. A female-to-female USB adapter does not suffice, as it does not provide the necessary functionality to switch between master and slave roles. The OTG cable allows devices to communicate effectively by designating one end as the master and the other as the slave, enabling seamless connectivity between various USB devices.
  • Understanding of USB device roles: master and slave
  • Familiarity with Micro USB OTG technology
  • Knowledge of USB device connectivity standards
  • Basic concepts of how tablets interact with USB peripherals
  • Research the specifications and compatibility of Micro USB OTG cables
  • Explore the differences between USB master and slave devices
  • Learn about USB device communication protocols
  • Investigate other types of USB adapters and their functionalities
Tablet users, hardware enthusiasts, and anyone looking to connect multiple USB devices to their tablets will benefit from this discussion.
trollcast
I'm looking at getting one of these for my tablet but would a female to female USB adapter on the end of the USB lead that came with my tablet work the same?
Thanks
Computer science news on Phys.org
From what I've read you do indeed need the OTG cable. It is a standard.
Yup, you need the OTG cable.
In the beginning when things were simple, every USB device was built either as a "master" or a "slave" device, depending on what it did. For eaxmple a desktop computer would be a "master", but a memory stick or a USB printer would be a "slave".
A network of USB devices only works properly if there is exactly one "master" device.
That simple "master/slave" idea doesn't work with devices like tablets, which might sometimes need to function as a master and sometimes as a slave.
The OTG cable fixes the problem by by making one end of the cable look like the master device and the other end like a slave, independent of what devices the cable is plugged into. In other words, you can connect "anything to anything" and it "just works."
