New Reply
Confusion regarding Lie groups
Share Thread Thread Tools
Jan15-13, 04:49 AM   #1
Hello! Im currently trying to get things straight about Lie group from two different perspectives. I have encountered Lie groups before in math and QM, but now I´m reading GR where we are talking about coordinate and non-coordinate bases and it seems that we should be able to find commuting generators, to for example SU(2), by just:
Smooth manifold --> Find a coordinate chart --> use the coordinatebasis in tangentspace --> we have three pairwise commuting generators.
Where does this break down?
Thanks in regards!
/Kontilera
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Jan15-13, 07:43 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
You forgot a step:
Smooth Lie group --> Find a coordinate chart --> use the coordinate basis in tangent space to identity--> extend to a left-invariant vector field
The result in general will differ from the local coordinate frame you started with and so the Lie bracket won't be 0 anymore.
Jan15-13, 09:17 AM   #3
Ah okey, so my misunderstanding is a confusion about the difference between smooth manifolds and Lie groups. My line of thinking was that since every lie group is a smooth manifold (correct?) every coordinate chart will induce a tangentspace basis which will commute pairwise.
In my GR course a coordinate basis is defined by satisfying:
[tex] [e_\mu, e_\nu] = 0. [/tex]
while in my mathematics literature the are defined by being directional derivatives along a set of coordinate axes (given by a chart on the manifold).
But these two statements are very different for Lie groups.
Jan15-13, 10:02 AM   #4
Recognitions:
Yes, I understood your line of thinking. Your error was in forgetting to keep track of how exactly is the lie algebra of a lie group G identified with the tangent space of G at the identity. Namely: if X and Y are two arbitrary vector fields on G, then they restrict to vectors on TeG (and hence induce elements of Lie(G) = {left-invariant vector field on G}), but these induced elements X' and Y' are not going to be X and Y if X and Y were not left-invariant to begin with, and so [X,Y] will not equal [X',Y'] in general.
The two definitions of coordinate basis you mention are indeed equivalent. You can consult Lee Thm 18.6 for a proof. The key is that two vector fields Lie-commute (i.e. [X,Y] = 0) iff their flows commute for all times. Given a basis of Lie-commuting vector field, you can thus compose the flows to construct coordinates.
I don't see in what sense the statements are different "for Lie groups". The statements concern only smooth manifold and are independent of any additional structures the manifold might carry.
Jan15-13, 10:13 AM   #5
Thanks, it doesnt seem obvious right now but I will give it some time.. maybe I come back tomorrow. :)
Jan15-13, 10:27 AM   #6
Last question: So on SU(2) I can find a coordinate basis which will satisfy
[tex][e_\mu, e_\nu] = 0[/tex]
but these coordinate axes will not be left invariant and therefore doesnt say anything about the bigger structure of the group or its Lie algebra.
Jan15-13, 12:01 PM   #7
Recognitions:
Right.
Jan18-13, 06:12 AM   #8
Its getting clearer and clearer for me but I dont really get the dimensions to add up.
Lets take the 2-sphere as an example. The tangentspace can at every point be spanned by derivatives along logitude and latitude - so its 2-dimensional.
But making the identification that our derivative along the longitudinal axis is the L_z operator when we represent this algebra in QM, it seems that we should have a 3-dimensional algebra; L_z, L_y, L_x.
So we have a 3-dimensional vectorspace cosisting of the leftinvariant vectorfields but our manifold and tangentspace is two dimensional.
Is this correct?
(I am thinking of SO(3) as topologically equivalent to the 2-sphere, this is correct, right?)
Jan18-13, 07:39 AM   #9
Recognitions:
mh, no topologically, SO(3) is real projective 3-space RP³. See the very nice explanation of this on wiki: http://en.wikipedia.org/wiki/SO%283%29#Topology.
In particular SO(3) is a 3-dimensional manifold. It has S³ as its universal (2-sheeted) cover.
Jan18-13, 07:50 AM   #10
Yeah, just realized this, glad you verified it. :)
My misstake (which I commited the last time I dealt with SO(3) aswell) is that I reason like this:
"So, I want a group of rotations on R^3. Lets start with the vector (1,0,0), this can now be rotated to every vector on the 2-sphere by using all the elements of SO(3). However we can not rotate it to a vector not lying on the 2-sphere. So it should be a 1-1 correspondense between the elements of SO(3) and the 2-sphere."
Where does this logic fail? :/
EDIT: This logic fails on the problem I brought up earlier I guess.. Obviously the dimensions arent correct, starting from (1,0,0) we can only go along \phi or \theta, but SO(3) is generated by rotation around three diffrent axes.
Jan18-13, 10:09 AM   #11
Quote by Kontilera View Post
Because there isn't a unique SO(3) rotation that yields a given point on the 2-sphere. If I take your (1,0,0) vector and rotate it so it's directed to a given point on ##S^2##, I can now take that vector as an SO(3) rotation axis. Clearly, a rotation by any angle around that vector doesn't move the vector to a new point on the 2-sphere. Thus, these are all distinct rotations in an SO(2) subgroup of SO(3) that all correspond to the same point on the 2-sphere.
The moral is that when you relate the topology of some manifold to a Lie group that acts transitively on it, you have to factor out the isometry isotropy group. So, in this case, ##S^2 = SO(3)/SO(2)##. I don't know about real projective groups, but I suppose that must be equivalent to what quasar987 said.
Jan18-13, 02:42 PM   #12
Right, I´m with you!
As soon as I can find isometries, not including the identity element, I should be careful making my fast assuptions about topological equivalents. :)
I will continue my hiking down the road of GR.
Thanks for the help - both of you!
Jan18-13, 04:57 PM   #13
Oops, sorry—meant to say "isotropy group", not "isometry group"
New Reply
Thread Tools
Similar Threads for: Confusion regarding Lie groups
Thread Forum Replies
Group Theory Question involving nonabelian simple groups and cyclic groups Calculus & Beyond Homework 1
Homology groups from Homotopy groups Differential Geometry 6
Some confusion about Ballentine Sec 3.3 Generators of Gallilei Groups Quantum Physics 4
Groups, Normalizer, Abstract Algebra, Dihedral Groups...help? Calculus & Beyond Homework 12
Wallpaper Groups, Free Groups, and Trees Introductory Physics Homework 13
