Thread Closed
What electromagnetic range would disrupt a neodymium magnet?
Share Thread
Jan20-13, 08:05 PM   #1
Hello all,
This is just a question i have... I need to know the frequency (in order to meter it) from an electromagnetic source, and i know that a neodymium magnet will disrupts it. so, i want to know what range the neodymium will disrupt, in order to know what device will need to meter source. Is this possible? or, how can i meter an electromagnetic source if i don't know what frequency is using this source? I have a chinese cheap microwave/EMF detector but seems like won't detect it.
Thanks in advance
As my english isn't perfect, let me know if i wasn't clear enough
PhysOrg.com physics news on PhysOrg.com
>> Kenneth Wilson, Nobel winner for physics, dies
>> Two collider research teams find evidence of new particle Zc(3900)
>> Scientists make first direct images of topological insulator's edge currents
Jan21-13, 07:28 AM   #2
Recognitions:
Gold Membership Gold Member
I'm not sure this is possible. Your magnet doesn't disrupt the EM radiation itself, it actually messes with whatever device your are using to emit the radiation. Either that or your detector. Without knowing the detailed specifics of your devices this may not be possible. And even then it may still not be possible.
Jan21-13, 05:36 PM   #3
Well i didn't put the magnet near the device. It was pretty far (the device is supposed to work as "focus" it's EM emission) i think you are right and it's possible that won't disrupt it, magnet it's probably affecting the target device.
Then it's impossible? should i seek for a "super wide spectrum" frequency detector in order to have some readings?
Jan21-13, 06:08 PM   #4
Mentor
Quote by armoredasm View Post
Hello all,
Thanks in advance
Welcome to the PF.
It would help a lot if you could post some pictures of the setup, along with details of what each device is, and what you are trying to do.
Jan21-13, 08:08 PM   #5
Well i do not own the transmitter device so this is like reverse engineering, a black box situation. i'm trying to do it in order to find the frequency (i know this could be impossible) or a range in order to disrupt it with a a kind of jammer device OR AT LEAST some readings from it's EM emission as i don't even know what range is using.
My detector
Measure frequency range: low frequency:5Hz-400KHz, high frequency: 30MHz-2000MHz.
I used it in order to test common EM radiation, like MW from wireless networks, cellphones, wireless phones etc... and low EM freq as computers, tv's. But as isn't common frequency i probably need something else.
It's not illegal
Jan21-13, 11:03 PM   #6
Recognitions:
You do realize the only way to jam something like this is to send out MORE EM radiation of the same kind right? That's how jammers work. A regular permanent magnet is not going to jam anything. The only thing it might do is possibly mess up your receiver if you get it too close.
What are you trying to jam? Is there a cell tower or radio tower nearby? Or do you not know what it is at all?
Jan21-13, 11:08 PM   #7
Mentor
My detector
It's not illegal
I'm not convinced that what you are wanting to do is not illegal. Thread closed. PM me with a *lot* more details, and I may re-open the thread.
Thread Closed
Similar discussions for: What electromagnetic range would disrupt a neodymium magnet?
Thread Forum Replies
Can a Neodymium Magnet be used as an electromagnet? Materials & Chemical Engineering 6
Force of neodymium magnet inside an electromagnetic coil Electrical Engineering 1
Force of neodymium magnet inside a electromagnetic coil General Physics 1
Neodymium Magnet Polarization General Physics 11
powdered neodymium magnet General Physics 3
