Many question about water(condensation evaporation)
  • Thread starter Thread starter kevin_tee
    Evaporation
The discussion revolves around the processes of water condensation and evaporation, particularly in the context of high pressure and low pressure scenarios. Participants explore various factors influencing condensation, including temperature changes, humidity levels, and the behavior of water vapor in different conditions.
  • One participant questions why water condenses when high pressure is applied and then reduced, noting observations from a water rocket experiment.
  • Another participant suggests that temperature changes can explain some of the observed processes.
  • A participant inquires whether water vapor condenses when it is pressurized and then depressurized.
  • It is proposed that compressing air heats it up, and upon expansion, it cools down, potentially leading to saturation and easier condensation.
  • One participant seeks clarification on the statement regarding air saturation and its relation to condensation.
  • A later reply indicates that air above water in a closed vessel eventually becomes saturated, or closer to saturation, even if not fully saturated initially.
Participants express differing levels of understanding regarding the mechanisms of condensation and saturation, indicating that multiple competing views remain on the topic.
Some statements depend on assumptions about temperature changes and the behavior of air in contact with water, which are not fully resolved in the discussion.
Individuals interested in the physical processes of condensation and evaporation, particularly in experimental or applied contexts, may find this discussion relevant.
kevin_tee
Why water condense when high pressure was applied and reduce to lower pressure?(I observe this when I play with water rocket, when I pump air inside there are no vapor, but after I shoot it, there is vapor coming out.)
Does water condense at 100%< humidity?
Does water vapor condense easier when it is heated? (When I boil water, it seems to condense easier)
Are there water vapor semipermeable membrane? (let air pass through, but water vapor can't.)
How many possible ways to condense water?(cooling etc)
Thanks to every comments:smile:
Chemistry news on Phys.org
Some of the processes you observed are easy to explain by temperature changes.
So does water vapor condense when it was pressurize and then depressurize?
Because of temperature changes. When you compress the air, it heats up ans starts to cool. When it expands it cools down, but as it lost some of the heat to the surroundings, it now cools down to the temperature that is lower than the initial one - and water vapor becomes saturated. Quite possible in the meantime the air - which, if I understand correctly the situation, was all the time in the contact with water - became saturated to a higher degree, which means condensation even easier.
Thanks for your reply, but I didn't understand "Quite possible in the meantime the air - which, if I understand correctly the situation, was all the time in the contact with water - became saturated to a higher degree, which means condensation even easier." what does that mean? Thanks again.:smile:
In a closed vessel air that is above water sooner or later becomes saturated. Even if you don't wait long enough to have the air saturated (relative humidity 100%), it still becomes closer to saturation than the air you started with.
Thank you so much
  • · Replies 32 ·
  • · Replies 23 ·
  • · Replies 33 ·
  • · Replies 30 ·
  • · Replies 26 ·
