| New Reply |
Atmospheric siphon effect |
Share Thread |
| Feb1-13, 09:01 AM | #1 |
While I'm at it I might as well ask your help on another question that has been bugging me for a while.
Let's hypothesize a huge "straw" a hundred metres or more in diameter. One end of this straw is at sea level. The other end is at 10,000 metres in altitude. It's obvious that the air pressure inside the straw would equalize, but if (again hypothetically) it could be "started" somehow, would there be a siphon effect which would push the sea level atmosphere up the straw to the stratosphere and would this effect be self sustaining? Thanks again in advance for any assistance. |
| Feb1-13, 09:50 AM | #2 |
No, that isn't how a siphon works. A siphon works because the fluid in the siphon is pulled down by gravity. This creates a suction effect that sucks more fluid into the siphon and the result is the draining of a reservoir that is higher in elevation than the other end of your siphon where the fluid is coming out. A siphon cannot work against gravity.
| Feb1-13, 09:55 AM | #3 |
Ok, perhaps due to the fact that I slept through most of my high school science classes I'm not explaining myself properly. The "straw" is connecting two areas, one with about 100 kPa and the other one with almost zero. Would there be a way to get that atmosphere flowing from the high pressure end to the low pressure end (like a deflating balloon) and have it be self-sustaining?
| Feb1-13, 10:03 AM | #4 |
Atmospheric siphon effecthttp://en.wikipedia.org/wiki/Xylem |
| Feb1-13, 10:09 AM | #5 |
| Feb1-13, 10:13 AM | #6 |
| Feb1-13, 10:16 AM | #7 |
| Feb1-13, 10:31 AM | #8 |
The trees use Sun's energy to evaporate the water, which pulls more water. Without that energy input it wouldn't work continuously. |
| Feb1-13, 10:33 AM | #9 |
| Feb1-13, 10:35 AM | #10 |
Mentor
| Feb1-13, 11:11 AM | #11 |
OK, without addressing each reply individually let me be clear:
a) I am only talking about air not water b) By equalization I mean to the air pressure at that point outside the straw c) Is there any way to get this flow going in some way that I'm not imagining and most importantly be self-sustaining? Thanks to all replies as I appreciate your time and effort! |
| Feb1-13, 11:33 AM | #12 |
| Feb1-13, 11:46 AM | #13 |
Mentor
Let's make this a bit more concrete. A pipe (a rather sturdy one at that) rather than a straw is needed. In fact, a concrete pipe won't do. Our pipe is going to need to be made of unobtanium to avoid the problem of progressive collapse. Suppose we lay the pipe horizontally at sea level so that it fills with air, seal one end, and then hoist the pipe into a vertical position so that the sealed end is at the top. The open end at the bottom is exposed to the sea level atmosphere. Now simply break the seal at the top of the pipe and we should have a siphon, right? Wrong. Air will flow out of the bottom of the pipe as the pipe is being hoisted to the vertical. There will be no air at the top of the pipe to flow out of the top by the time the pipe is vertical and we break the seal. Suppose instead we seal both ends and simultaneously break the seals on both ends once the pipe reaches a vertical orientation. This should work, right? Wrong again. Now air is going to flow out of both the bottom and the top of the pipe, with a whole lot more flowing out of the bottom. You want air going into the pipe at the bottom and flowing out of the top, and that isn't going to happen. |
| Feb1-13, 11:57 AM | #14 |
Ok, fair enough! The answer is clear: No can do! Thanks to all for your valuable input!
| Feb1-13, 12:16 PM | #15 |
| Feb1-13, 12:22 PM | #16 |
Do I get a passing grade? :) |
| Feb1-13, 12:34 PM | #17 |
| New Reply |
Similar Threads for: Atmospheric siphon effect
| Thread | Forum | Replies | ||
| Atmospheric pressure effect on simple mechanisms | Mechanical Engineering | 6 | ||
| Effect of freefall on hydrostatic/atmospheric pressure | General Physics | 8 | ||
| Temperature - Effect on atmospheric pressure. | General Astronomy | 13 | ||
| Effect of Atmospheric pressure on Butane /propane | General Physics | 0 | ||
| what is siphon break and reverse siphon? | Mechanical Engineering | 0 | ||
