| New Reply |
Any flickr members here? |
Share Thread | Thread Tools |
| Feb4-13, 10:55 AM | #1 |
I've recently created a flickr's account because of my digital camera upgrade. I know a few of you are using flickr but I'm interested in knowing who exactly. So feel free to post!
My account is http://www.flickr.com/photos/mygzulis/. Out of the 27 photos I posted there, I think only 1 is not that badly taken (the one of the bird in Iguazu falls). I'm a total newbie in photography but my will to learn is great. I noticed that I had not controled the exposure time in any of my photos, it was chosen automatically by my camera with very bad results when it comes to spiders. Previously I thought that the ISO was directly related to the exposure time but it isn't, clearly. |
| Feb4-13, 05:32 PM | #2 |
| Feb9-13, 06:42 PM | #3 |
Very nice photos Maui!
Your trips look really awesome. |
| Feb10-13, 12:02 PM | #4 |
ISO specifies the sensitivity of the camera, i.e. how much light is needed for a correctly exposed image.
The higher the ISO, the less light is needed. At constant aperture this means higher Iso-->shorter exposure time. Some cameras set ISO automatically. For a physicist: photographic aperture is a numerical aperture, i.e. the ratio of focal length to the effective diameter of the lens (diameter of the glass reduced by how much you stop down). How much light you catch depends on the effective area=pi*diameter^2, which is proportional to the NA^2. That's why you get strange values for the aperture 1.4 (approx sqrt(2)) 2 2.8 (approx 2*sqrt(2) 4 5.6 (approx 4*sqrt(2) 8 11 (approx 8*sqrt(2) ... at each step the effective surface doubles. This matches the exposure times, which also double (or half) at each step. So the exposure value stays constant when you close down the aperture by one step, and increase the exposure time by one step. http://www.flickr.com/photos/carsten1968/ |
| Feb10-13, 01:10 PM | #5 |
Now I know I was totally off. I've been playing with my new DMC-tz25. Now I can control the exposure time which very nice, especially for taking a bird in flight or anything that moves fast. I choose to auto adjust the ISO. I think I'm getting it: the shorter the exposure time, the higher the ISO needs to be for the photo not to be too dark. By the way thanks for your explanation. If I'm not wrong, I think you made a slight mistake (effective area=pi*diameter^2 should read effective area=pi*radius^2) but I get the idea. Also thanks for your flickr's page :) |
| Feb10-13, 01:45 PM | #6 |
Of course there is a price for high ISO, signal to noise ration goes down the drain. That means lot's of pea soup noise and less dynamic range and hot pixels, that turn completely white. The smaller the sensor, the worse. That's the problem with the pocket camera's.
I'm not on Flickr, but some of my pics can be found in my portfolio in my signature. Notice that the last pic of the |
| Feb10-13, 03:00 PM | #7 |
Also, did you/the camera choose such a high ISO because of the low light situation? |
| Feb10-13, 03:18 PM | #8 |
The camera is a Canon EOS 7D. I selected the ISO myself to get a good range shutter speed and aperture range (1/100 sec and f5.6) to freeze the hammering hand
| Feb10-13, 03:40 PM | #9 |
By the way your photos are absolutely wonderful. I've sneacked a bit into them, I particularly love the one of the fly over the aphids. Thanks a lot for sharing. |
| Feb10-13, 04:16 PM | #10 |
Thanks, happy to share the full size aphids and fly pic here. But I'm most proud of the dragonfly caught inflight. That was really difficult.
| Feb10-13, 04:26 PM | #11 |
Pretty impressive, you could determine more or less how fast it moves its wings if you take a look at the shutter speed. I notice that its lower wings swings faster than the upper ones (at least in the picture where it moves from the left to the right). |
| Feb10-13, 04:47 PM | #12 |
The credit for that incredibly fast focussing goes mainly to the aforementioned camera. It has a sort of tracking mode. Once it "locks" on a 'target' it's able to follow it and predict where it is when the next picture in the sequence is going to be taken in the burst mode of 8 frames per second. There is a reason for the price of that awesome piece of equipment.
That same principle worked for Candy on full speed.
| Feb10-13, 05:28 PM | #13 |
I think I have a similar mode in my camera, but I never used it yet. I doubt it could be as effective as yours.
1 question: when you use the 8 photos / second, is there any "loss" of quality? I mean, can you take 8 photos per second at full quality? I'm not 100% sure but for my camera I think I'd pass from 12 mega pixels to 2 mp if I do that. |
| Feb11-13, 01:38 AM | #14 |
Every pic is redone, both the focussing and exposure data. No loss of quality. The only issue is, that you should consider, after how many clicks the memory buffer is full, however in full high quality JPG storage, that takes 92 shots.
Notice also the shallow depth of field when using a telelens, making the focussing more challenging even. A small sensor camera is less critical with a considerably larger depth of field. |
| Feb11-13, 02:39 AM | #15 |
What ISO to use depends on a few factors:
- how much light is there? Very little light (like Andre's Blacksmith): High ISO. A lot of light (bright daylight outdoors): Low ISO - Focal length: Tele is much more sensitive to camera shake (even with stabilizers) and therefore needs shorter exposure times. As a rule of thumb, the exposure time should not be longer than 1/(focal length), so for a 300mm tele, set the ISO such that the exposure time is 1/250 sec or faster. Note that at the tele end of your zoom you are generally limited to quite small apertures (like f/5.6 or f/8). That does not leave a lot of margin for playing with aperture vs. exposure time. - Subject movement: For moving subjects you often want to "freeze" the action. That means short exposure times. But then again sometimes you want the opposite. Take a shot, look at what you've got and change exposure time and ISO as needed. ![]() 1952 Buick Eight by carsten de, on Flickr (Canon EOS 5D Mk2, ISO 400, f=28mm, 1/10 sec at f/5.6. This was taken at 8pm with fairly low light) |
| Feb11-13, 03:34 PM | #16 |
Ok thanks guys I understand.
By the way, M. Quack, regarding the photo of the car: I don't understand how it's possible that the back of the car seem to have moved during the exposure time of the camera while the front part has not. I'd understand if the back of the car was out of focus while the front was right on the focus, but it doesn't look like it. It looks like the back is not only blurry but also "moving" (same for the head of the passenger). How is that possible? |
| Feb11-13, 04:53 PM | #17 |
Interesting question, I am not quite sure myself. It must be related to the wide angle. I was focusing at the front of the car and panning along. The car was maybe 3m away. The panning motion was a rotation, so effectively the car was rotated about the focus spot, too, by the same angle. If you are panning with a tele lens, then the angle will be much smaller, so the effect might not show up as much.
This is not some freak accident, there are a couple of other pics that show the same effect. |
| New Reply |
| Thread Tools | |
Similar Threads for: Any flickr members here?
| Thread | Forum | Replies | ||
| 100,000 Members!!! | General Discussion | 71 | ||
| Anyone on Flickr.com? | General Discussion | 3 | ||
| subtle background structure in deep astronomy photos; CSL-1 cosmic string gravitational lens in Capodimonte Deep Field; Millennium Simulation of evolving cosmic structure; AstroDeep group; Murray mesh; www.Flickr.com evolving cosmic structure; As | General Physics | 1 | ||
| Members Day? | Forum Feedback & Announcements | 2 | ||
