| New Reply |
How to calculate pressure and flow rate of an air jet? |
Share Thread | Thread Tools |
| Feb6-13, 06:37 PM | #1 |
Hello,
I have a box with a hole directly connected to a blower inside. I can use the air sent by the blower to give a thrust to the box, in order to move it. I can say the the box is in a room, so open air around the box. The thrust should be 35 N and I have to calculate the pressure and the flow rate necessary to do this. I can choose the diameter of the hole with no particular limits (I think about 1-2 cm or similar). Can anyone suggest me the right formulas to use? Thanks PS: the goal is to choose the right blower, so I need pressure and flow rate for this |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Feb6-13, 10:38 PM | #2 |
Recognitions:
Where is the blower getting the air from?
i.e. it is completely enclosed by the box (apart from the hole already mentioned)? The blower is shifting air from one place to the other. The mass rate that air leaves the hole + conservation of momentum should do for thrust. From the description, the blower vents directly out of the box, not to the inside of the box. The blower should already be rated for air speed by the manufacturer. So what you are doing is putting a flow from a wide pipe into a small one. That would be Bernoulli's principle. |
| Feb7-13, 04:44 AM | #3 |
the blower takes air from the atmosphere and put it outside through a tube (connected to the hole).
but the problem is that i need to choose the right blower to have the thrust of 35 N. i have to define the pressure and the flow rate in order to choose the blower (i can choose the hole diameter as i want). |
| Feb7-13, 05:10 AM | #4 |
Mentor
If the velocity is low enough, you can use Bernoulli's equation to find the velocity pressure and multiply it by the are of the hole to get force. Or you can calculate it via momentum change.
| Feb7-13, 05:19 AM | #5 |
i don't know the velocity, because i don't know which is the blower i will have.
i only know the force to get and the diameter of the hole (because i'm free to decide it). can you write me the way you will follow to calculate pressure and flow rate? thanks a lot for your help |
| Feb7-13, 06:24 AM | #6 |
Recognitions:
Someone may be prepared to do the calculation for free - just for the fun of it - who knows: you may get lucky. You have been given good starting points, use them. Learn about the problem you are trying to solve. |
| Feb10-13, 10:39 AM | #7 |
thanks, I found the solution
bye |
| Feb10-13, 08:05 PM | #8 |
Recognitions:
Well done - you don't want to share and so help someone else in your position?
| Feb10-13, 08:25 PM | #9 |
sure!
Initial data: force F we want to generate, hole diameter d (A is the corresponding area), air density rho I can calculate the pressure delta_p (relative to atmosphere pressure) necessary to generate F: delta_p = (2 * F) / (pi * d^2) Then I can calculate flow velocity V: V = sqrt (2 * delta_p / rho) Finally I found the air flow rate Q: Q = A * V I'm not sure if the process could be adiabatic, so I tried also this way. The numerical results are similar. ADIABATIC CASE I can calculate delta_p as in the previous way. If we have p1 air pressure before the hole and p2 air pressure outside: delta_p = p1 - p2 Then I calculate air density rho1 before the hole: rho1 = p1 / (R_air * T1) Then outside: rho2 = rho1 * (p2/p1)^(1/1.4) I calculate T2 outside: T2 = p2/(rho2 * R_air) Then I calculate the velocity: V = sqrt (2 * Cp_air * (T1 - T2)) Finally the flow rate: Q = F / (rho2 * V) Do you have suggestion to choose the best solution between these 2 ways? As i said the numerical results of Q are very similar in my case. Thanks |
| Feb10-13, 08:46 PM | #10 |
Recognitions:
Cool - you will now get the silent gratitude of 100s maybe 1000s of googlers ;)
| Mar11-13, 10:30 AM | #11 |
| New Reply |
| Thread Tools | |
Similar Threads for: How to calculate pressure and flow rate of an air jet?
| Thread | Forum | Replies | ||
| Calculate Pipe Sized Based on Pressure Differential and Flow Rate | Introductory Physics Homework | 8 | ||
| Calculate the gas flow rate. | Engineering, Comp Sci, & Technology Homework | 1 | ||
| To Calculate end Flow Rate of Water | Mechanical Engineering | 0 | ||
| Flow rate depending on pressure with constant inlet rate. | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Calculate the individual flow rate - based on the pressure drop? | Mechanical Engineering | 0 | ||
