| New Reply |
Implications of the statement "Acceleration is not relative" |
Share Thread | Thread Tools |
| Feb14-13, 08:18 PM | #103 |
Implications of the statement "Acceleration is not relative"See section 6.6 of this lecture http://physics.ucsd.edu/students/cou...61.14jan11.pdf |
| Feb14-13, 09:27 PM | #104 |
Mentor
| Feb14-13, 09:33 PM | #105 |
Mentor
http://math.ucr.edu/home/baez/physic...eleration.html You also cannot apply formulas derived for inertial frames in non-inertial frames. They are both legitimate, but not equivalent. |
| Feb14-13, 09:47 PM | #106 |
Euclidean case In 2D Euclidean geometry, the formula for the length of a curve connecting two points is given by: [itex]L = \int \sqrt{1+m^2} dx[/itex] where [itex]m = \dfrac{dy}{dx}[/itex] is the slope of the curve [itex]y(x)[/itex] This formula is good using any Cartesian coordinate system, provided that the curve is never vertical (it breaks down in that case, because the slope becomes infinite). Finding the path [itex]y(x)[/itex] that makes [itex]L[/itex] an extremum (either a maximum or a minimum), one uses the calculus of variations. The result is that the minimizing or maximizing curve satisfies: [itex]\dfrac{d}{dx} ( \dfrac{m}{\sqrt{1+m^2}}) = 0[/itex] which has the solution that [itex]m[/itex] is a constant. So the curve with constant slope is the extremizing curve (the one making the distance either minimal or maximal--we can prove in this case that it is minimal). Special Relativity case In Special Relativity, the formula for the proper time of a spacetime path is given by: [itex]\tau = \int \sqrt{1-\dfrac{v^2}{c^2}} dt[/itex] where [itex]v = \dfrac{dx}{dt}[/itex] is the velocity of the path [itex]x(t)[/itex] This formula is good using any inertial coordinate system. Finding the path [itex]x(t)[/itex] that makes [itex]\tau[/itex] an extremum (either a maximum or a minimum), one again uses the calculus of variations. In this case, the equation for the extremizing path is: [itex]\dfrac{d}{dt} ( \dfrac{-\frac{v}{c^2}}{\sqrt{1-\frac{v^2}{c^2}}}) = 0[/itex] which has the solution that [itex]v[/itex] is a constant. So the path with constant velocity [itex]v[/itex] is the path that makes the proper time maximal or minimal--we can prove in this case that it is maximal. |
| Feb15-13, 01:32 AM | #107 |
| Feb15-13, 02:04 AM | #108 |
Ehm no, that basic issue was taken care of in Einstein's 1918 paper, by means of an induced gravitational field. According to 1916GR, one may claim that the firing of the rockets doesn't accelerate the rocket at all but that instead this induces a gravitational field through the universe. That field makes that the stay-at home ages the right amount in comparison with the traveler. However, that solution opened a can of worms that nobody wants - so much, that it has been mostly ducked in the literature. |
| Feb15-13, 07:27 AM | #109 |
Mentor
| Feb15-13, 07:53 AM | #110 |
| Feb15-13, 08:33 AM | #111 |
The equivalence principle is about this notion of gravitational field: there is no difference (other than the variation of [itex]g[/itex] with location) between the effects of a [itex]g[/itex] due to gravity and a [itex]g[/itex] due to the use of accelerated cooridnates. |
| Feb15-13, 08:40 AM | #112 |
Mentor
[EDIT: stevendaryl made essentially the same point, but faster!] |
| Feb15-13, 10:02 AM | #113 |
| Feb15-13, 10:35 AM | #114 |
Mentor
My point remains, that the "gravitational field" he refers to by "A gravitational field appears, that is directed towards the negative x-axis. Clock U1 is accelerated in free fall, until it has reached velocity v. An external force acts upon clock U2, preventing it from being set in motion by the gravitational field. When the clock U1 has reached velocity v the gravitational field disappears" is the field from the Christoffel symbols and it is entirely determined by the choice of coordinates. I have not read all of Einsteins writings, but I believe that this is the meaning he usually attributes to the term. If you believe that he refers to something besides the Christoffel symbols then please be explicit about what mathematical term you think he intends and why. |
| Feb15-13, 12:08 PM | #115 |
| Feb15-13, 05:56 PM | #116 |
Before I say what I was looking for, I will accept a good deal of the criticism in recent posts. I have made some overly broad and not well thought out statements, resulting in errors. I realized that as I went through the mental exercise of constructing the spacetime diagram for the twin paradox, rather than accepting it as a finished product. In my previous post, I asked for a SR solution of the problem in which the non-inertial rocket is always at rest. I don't recall anyone presenting such a solution. My sense is that my calls for such a solution have been rebuffed. Every SR solution that I have seen has the rocket in motion. Certainly, in every SR spacetime diagram I have seen, the rocket is in motion; it is the reversing motion of the rocket which produces the knee in the rocket's worldline, and thus the difference in proper times. The article discussing acceleration in special relativity also speaks of the accelerating object as in motion. (http://math.ucr.edu/home/baez/physic...eleration.html) I, in my rocket, claim that I am not in motion. I have been sitting in my rocket in the same position throughout the episode. You claim that I will be younger than my twin at the end of the episode. As proof, you present to me a diagram that shows me in motion. I reject it. I categorically deny that the diagram applies to me. The diagram shows me in motion; I have not moved. I do not deny that my experience has been non-inertial. I do not deny that the experience of my twin has been inertial. I do not even deny that I have experienced "proper acceleration", because you have told me that I can experience proper acceleration while remaining motionless. I deny that I have been in motion. Therefore, I insist on a solution that does not put me in motion. What would a diagram of such a solution look like? There would have to be a point representing my position and time at the beginning of the episode, another point representing my position and time at the end of the episode, and a (possibly curvilinear) path that connects the two points. Whatever the shape of the path, the value of the position coordinate must not vary from the beginning to the end of the path, because I do not move. It is maintained that SR can be used to solve this problem. I will attempt to draw the spacetime diagram. For convenience, I'll make my time and position axes orthogonal, in the usual manner with time positive toward the top of the page. And as usual I will set my starting position and time at the origin. Because I do not move, my worldline must be parallel to the time axis; in this case it will be coincident with the time axis. I realize that this is the worldline of an inertial object. I am not inertial. It doesn't seem right that my worldline should be inertial, but that's how it must be, because I do not move. Now to draw the earth. The earth is moving in my frame, and inertial in its own frame. I cannot find any worldline that will satisfy both conditions, and also meet me at the end of my worldline. I cannot complete the spacetime diagram. Being unable to represent in a spacetime diagram the perfectly legitimate scenario of myself at rest throughout the episode, and the earth reversing, I conclude that SR is not suitable for solving the problem. I may be wrong in my conclusion, as has been claimed. If so, I would like to see a SR solution which has me in one position throughout the episode. |
| Feb15-13, 06:10 PM | #117 |
| Feb15-13, 06:14 PM | #118 |
| Feb15-13, 09:14 PM | #119 |
Mentor
Another, more accurate, way to say it is that your coordinate lines are bent. So lines of constant coordinates are not straight lines and straight lines don't have constant coordinates. A similar thing happens, e.g. in polar coordinates. Since the coordinates are curved the equation r=mθ+b does not represent a straight line. |
| New Reply |
| Thread Tools | |
Similar Threads for: Implications of the statement "Acceleration is not relative"
| Thread | Forum | Replies | ||
| In binary can we have a value with "deci" "centi" "mili" or more lower valued prefix? | Computers | 14 | ||
| "Gravitational field" vs. "acceleration due to gravity" | Classical Physics | 2 | ||
| The terms "absolute" and "relative" | Special & General Relativity | 13 | ||
| Universe not accidental: Is this Steinhardt statement "rather pathetic"? If so, why? | Cosmology | 114 | ||
| Checking Chadwick's statement about the mysterious "neutral radiation"? | Advanced Physics Homework | 4 | ||
